LCD Won't Power On
I have a Toshiba 46HL167 that no longer turns on. Instead the power light blinks 3 times, pauses, then blinks 3 times again.
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Blinking of power light is fault indication. From the number of blink that occur at one time switch ON, you can get an idea about the faulty circuit side. These are called blinking codes. To know more about these blinking coded, visit the site. It has details about blinking codes to many brand TVs. Pull up older posts. If you check the site in Timeslide option, which can be selected from the dropdown list at the top left side of the display window, it will make search easy.
Posted on Apr 23, 2013
ctf1800
  • 4402 Answers
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Posted on Feb 26, 2008
hemantraj
  • 638 Answers
SOURCE: my KDF-55WF655 power led blinking red six times.
oh ho try a hard reset mostly u will solve.
Posted on Jun 13, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Panasonic PT-53TW53G
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Posted on Apr 18, 2010
SD Tech
  • 14553 Answers
SOURCE: My tv will not come on. The power light blinks 3
YES, IT is short protection and 98% chance one of the resistors that protect the convergence circuit is bad.
Good news here:Set is fixable and total parts cost will be under 25 dollars (seller I know on Ebay).
If you want to confirm this: with set unplugged, remove back cover and locate the two heat sinks with fins that have two of the STK-392-110 convergence chips---look at all the light blue resistors in front of them---I bet you find one white in the middle--gone.
Set detects no voltage and a short and shuts down--3 blinks code.
I have start to finish, step by step instructions for this repair that tell everything you will need and how to do the repair--the instructions are based on my own experience doing this repair in these sets hundreds of times.
If photos and info here help and you want the step by step (I can not give my email here.....)rate this solution as very helpful as I am doing this here for free.
SD TECH
cd48042.jpg Chips look like this but metal in your set will be silver.
protect resistors in front will be light blue in color and most will be marked 2.2 which means 2.2 ohms is value.
SD TECH
Posted on Aug 23, 2010
seanb003
  • 144 Answers
SOURCE: standby light blinking 10 times pause and blinks
This blinking is an error code. If you contact Sony, they will provide help. Search Google for error code info.
Posted on Jan 11, 2011
Testimonial: "can also check this website for info on blinking codes http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721"
Why won't it turn on?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Dec 14, 2015 | Toshiba REGZA 52RV530U LCD TV
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Had my toshiba regza 42rv530u since March 2009 a few days ago it cut off and will not come back on, the yellow light flashes at the bottom of the tv, 3 blinks pause 3 blinks etc....
try resting your tv. power off it press and hold av select botton and then power on your tv wait few minutes and it will rest your tv.... if not used the same wy holding menu botton instead.
May 30, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
I have a toshiba 42HL167. Love it but recently when the power is off iget a repeating blinking yellow light. Blinks 3 times pauses blinks 3 time pauses blinks either 2 or 3 times then stops for 25 seconds...
Yes. The Yellow LED blinking 3 times is a normal boot-up, but if it keeps doing it -- it needs the firmware "update" (which is more like a reload because it got corrupted.) The problem is, no one talks about how to do that. (there is a PDF and firmware on toshiba's website, but it lacks some crucial details.)
My friend gave me his 42HL167 after this problem started after a power event during a storm and I managed to fix it by reloading the firmware.
I posted instructions on my website at:
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Once I figured out some of the facts, it was a breeze...
Nov 06, 2009 | Toshiba 42HL167 42 in. LCD Television
Sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Jul 31, 2009 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
My toshiba 42HL167 won't turn on
Try this fix from the toshiba website. Q. I have no picture or sound, but I have a blinking power light?
Models: LCD-2007
REF:FAQLCD00090
1. Try resetting the TV by disconnecting the power for 30 seconds and then plugging it back in. If this has no
effect, try moving the TV to a different power outlet that has been tested and is known to be good.
2. If your unit continues to fail, please contact our Customer Solutions Department at 1-800-631-3811 Monday
through Friday, from 8 a.m. until 7 pm CST for a local Toshiba Authorize Service Station Hope this helps you with your problem.
Feb 27, 2009 | Toshiba 42HL167 42 in. LCD Television
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
