Question about Samsung Computers & Internet
How can i connect my samsung ps51d450 to my pc? i dont know where to start do i need a network adaptor or is it built in?
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: have Eee pc with windows7. wifi connection looses connection every few minutes.Network adaptor problem
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Posted on Sep 12, 2012
Does the asus cm5571 have wireless capabilities
Hi there
According to this webpage which gives the specs for the Asus, it does not have wireless capability built in
http://www.cnet.com/uk/products/asus-essentio-cm5571-br003/specs/
It can easily be used with a wireless network connection either by adding a wireless network PCI adaptor, or a USB wireless network adaptor. Neither of these are expensive and the USB adaptor is often preferred as it only needs a spare USB port on the machine and the computer does not need to be opened up as it does for the PCI adaptor.
Hope this helps
Aug 29, 2014 | ASUS Computers & Internet
Engenius wireless lan usb2.0 adapter driver
A lan adaptor driver is fixable by downloading from the network site of the USB 2.0.
important notes
1. Lan adaptors are outdated versions incompartible with recent operating systems. Acquiring a new USB device or even wireless modems are the latest alternatives to lan computer connections of the past. Modern wireless modem connection have built in installation kits,also present is the computers capability to recognise to integrate to a network.
Dec 21, 2010 | Computers & Internet
How Can I Get My Ps2 To Go Online What Parts Are Needed
You need the Network Adapter and you have to sign up and pay money/ month
http://au.ps2.ign.com/articles/366/366021p1.html
f you are hooking it up to a DSL cable/modem,
1. Remove the sticker covering the network connector on the Network Adaptor and
plug your Ethernet cable in the connector labeled NETWORK.
2. Plug the AC power cord for the PlayStation2 system into an electrical outlet.
3. Turn on the PlayStation2 system and start the Network Adaptor Start-up Disc.
If you are hooking it up to a router:
1. Remove the sticker covering the network connector of the Network Adaptor.
2. Connect an Ethernet network cable from the NETWORK connector of the Network Adaptor to an available LAN port of the router.
3. Connect the WAN port of the router to the DSL or cable modem.
4. Connect a personal computer (not pictured) to an available LAN port of the
router. Use a web browser on the PC to set up the router to reach the
Internet.
5. Follow the specific instructions that come with the router. There is no additional installation for switches.
If you are hooking it up to a LAN:
2. Connect an Ethernet network cable from the NETWORK connector of the Network Adaptor to a wireless Ethernet bridge.
3. Connect the WAN port of the wireless router to the DSL or cable modem.
4. Connect a personal computer to the router. Use a web browser on
the PC to set up the router to reach the Internet.
For pictures, see the thread here:
http://www.funadvice.com/r/3js7klmkua
May 20, 2010 | Sony PlayStation 2 Slimline Console
Need driver for Acer ethernet adaptor
try going to the acer support page and looking for the driver download----also, you can try driverguide.com. they are all free downloads and you might find it there
Apr 25, 2010 | Dell Intel Ethernet Adaptor 0000921206...
Can i use a usb adaptor on the c700
Your laptop should have a built in network card and 10baseT network port, if your laptop does not have a built in network card you can use either a PCMCIA network card or a USB network adapter. Your desktop computer may not have a network card, you will need to purchase a network card and install the drivers.
To connect the two computers together you only need a cross over cable. If you use a hub you can connect two or more computers together using standard 10baseT network cables.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Aspire 5050 network adaptor not found ??
ok, the problem is that your wireless adapter of your notebook has not been installed yet. locate the cd that comes with your notebook and install the wireless adapter.
Dec 22, 2008 | Acer Aspire 5050-3242 Notebook
Aspire web connections
To go wireless:
1.- check if your wireless device is working
2.- If not you have to turn it on
3.- Select your wireless network (control panel>>network connections>>wireless networks)
4.- Connect to the network (is the network is pass protected you will prompt for a password)
If above doesn't help, please describe better your issue
Sep 25, 2008 | Acer Aspire 1360 Notebook
No wifi
You need to get a wireless adaptor your laptop did not come with wireless built in. You can get a USB adaptor or a PCMCIA adaptor. Either will work but the pcmcia adaptor will be a little faster
Have a look here
http://www.google.com/products?hl=en&q=pcmcia+wireless+card&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
Hope that helps
Aug 25, 2008 | Compaq Presario Notebook
Hmmm....any ideas..
Check in control panel - system - device manager - hardware to see that there is no conflict on the built in network adaptor - click on the network adaptor properties to make sure it is enabled and working.
Mar 12, 2008 | IBM ThinkPad A21m 2628 Notebook
DO I have wireless?
Hi, im sure the PCG-K315M dont have a built in wireless card, You can buy a Usb wireless card for about 20-30 pounds from any shop. If your laptop did have wireless onboard there should be a switch on one of the sides of the laptop,
Have a good christmas
John
Dec 11, 2007 | Sony VAIO PCG-K25 Notebook
Computers & Internet Logo
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
