Question about Sony STR-DE597 Receiver
STR-DE597 Display is not visible
For a few years now my receiver has been working without problems. Recently I found that when the receiver was turned on it immediately went into Protect Mode, however, and I was able to resolve that issue. In resolving that issue I encountered another, that being the display is not visible when the unit is on. When I turn the unit on, the display is visible for 1 or 2 seconds, then it goes out. Everything else on the receiver appears to be working correctly. How can I get the display to become visible?
  • Anonymous Feb 14, 2009
    I have the same problem with the STR-DE597. For quite a while now, the display area has been totally dark. The amber indicator lights on the mode switches are fine, but the green tuning & setup display is gone.
    This started several months ago when I pulled the unit out of the cabinet for cleaning and then placed it back. When I turned it back on, it was black.
    Probably not repairing, but still operates - just a pain to work with. Anyone have any suggestions on what can be done? I've tried the "reset" suggested, but no luck.
    Thanks!!
  • 71 Answers
Try a complete RESET by completely switching OFF mains power and leaving for at least 40secs. before commencing a new setting-up procedure.
Let's know if this does work it back to normality!
Posted on Feb 29, 2008
SOURCE:
I have had my Denon AVR-485 for a few years without a problem, just recently when you turn it on it shuts down within a few seconds. Any suggestions?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 21, 2011 | Denon AVR-485 Receiver
My camera worked very recently, as I took pictures on a camping trip. However, a few days later after getting back, I've found that it refuses to turn on. If I turn it to either Video or Photo, the light...
Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 07, 2010 | Kodak EasyShare CX6200 Digital Camera
How can i get the dts sound field to work. Shouldn't it automatically switch to that sound field. I have a samsung bluray dvd that hooked up to it.  The dolby pro logic and pro logic 2 indicator...
If you are playing media that has both dolby digital audio and dts audio, your player and your receiver will decode the first audio codec listed first by default unless you select it otherwise yourself. If your remote or receiver has an A.F.D. (auto format decode) button, press it until your display shows that the sound source is dolby digital or DTS, whichever sound mode it was you wanted when you started your DVD.
Dec 12, 2009 | Sony STR-DE597 Receiver
Nothing shows up in the display. This has only been recently after a power glitch. The display lights when a call is made or received.
I unplugged the base unit from the wall for more than 10 minutes. Sometime after I plugged it back in (not immediately)the display re-appeared.
Nov 16, 2009 | Panasonic KX-TG2631 Cordless Phone
Player turns on and immediately goes to a blank screen!
i had the exact same problem and that means that its just getting old and u probably need a new one
Jul 09, 2009 | SanDisk Sansa e270 MP3 Player
Audio protect keeps turning off my receiver (sony STR-DE597)
That is the common symptom of the defected STK-IC in power amp.section that busted already or just a loose connection.First try to resolder the pins of STK-IC and also all component parts joint in power amplifier section if its works! if not that is the time you replace it, so it works normal again.
Hope it may helps you...
Jun 08, 2009 | Sony STR-DE597 Receiver
Computer won't boot up
i tell you m idea....first, maybe there is no operating system like windows or etc...second maybe your hard disk is not detecting or its damage,third, check the bios setup for the drives..it can help to solve the problem
Mar 03, 2009 | Dell Inspiron 531s Desktop Computer
Dark display on Sony STR-DE597 receiver
Check for bad solder connections on the display itself. If none use a voltmeter and check dc voltage on the first and last pins of the display. should be about 20v dc. If you don't have the dc voltage check for a bad transistor or resistor in the power supply. It could also be other thing but this is where you should start.
Feb 15, 2009 | Sony STR-DE597 Receiver
Sony STR-DE597 Receiver Logo
186 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
