Question about Pool & Spa
When pump is running looks like dirt is getting returned to the pool
Heyward de filter,hayward multie funtion valve heyward pump tristar in ground pool
  • 7,482 Answers
Change or clean your filter
Posted on Apr 25, 2013
  • 4 Answers
SOURCE: d.e. earth pool filter returning dirt to pool
The flow tubes inside the filter canister are torn and letting dirt pass. The repair is simple and can be done by someone with a few hand tools. Download the manual for the filter here:www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
You'll only need to replace the ones that are ripped, and the cost runs about $3 - $5 each. Search around on Google for a supplier or try a local pool dealer.
Posted on Jun 30, 2009
protek480
  • 1723 Answers
SOURCE: My pool pump is 2 months old. It is a Hayward 1hp
The capacitor is probably bad. It's under the cover on the side of the motor, Take a look and smell it. A motor shop has them, or Grainger
Posted on Jul 03, 2009
  • 93 Answers
SOURCE: hayward filter problem
YOUR HANDLE IS NOT SEATING IN THE RIGHT POSITION THERE IS A SPROCKET UNDER HANDLE THAT MAY BE DAMAGED TRYSETTING HANDLE TO DIFFERENT POSITIONS SEVERAL TIMES IT MAY HAVE DEBRIS UNDER IT MAKE SURE PUMP IS OFF.TAKE HANDLE ASSEMBLY OFF AND CHECK SPOCKET
Posted on Aug 06, 2009
SOURCE: air in filter on hayward above ground pool.
This is common the first 30-60 seconds after turning the filter on. The filter is purging its self of the air, sometimes algae or small debris will shoot back into the pool as well.
If it is constantly getting air then replace your o-ring on the that clear cover (Strainer Cover) make sure you use a lubricant, and like djtc66 said re-wrap all threaded areas with teflon tape.
Posted on Sep 04, 2009
jharwell668
  • 640 Answers
SOURCE: hooking up filter to pump and pool
This website contains a copy of the owners manual for the S180T pool filter. It should have all of the information that you need.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
It is in PDF format. let me know if you have any trouble opening it.
Posted on May 24, 2010
How do I remove elbo/check valve on ec65. Seems to be really stuck on.
the main drain should be on suction side of pool system (unless it was converted to be a return for safety reasons) since it is on the suction side of system, it is impossible to have DE entering pool at this point.
May 10, 2015 | Hayward EC65 Extended Cycle DE In Ground...
Is there another solution to fixing the spider gasket on my heyward filter other that replacing the whole valve assembly? Are there any home remedies out there.
I would try to change the gasket first ... be sure you look at the gasket BEFORE you remove it so you can put the new one in properly. Typically, it is the gasket that goes and not the valve. Remember, you can only turn the handle in a clock wise direction - never backward. or is that counter clock wise ... :-)
Dec 06, 2012 | Hayward SAND FILTER, PRO SERIES
I found a bowl shapped button with cloth attached on one side inside my Heyward DE filter, when I was cleaning. It says EC-1272, Any idea what it is. Is it a filter part?
I had the same problem. Sent email to Hayward and here's the response I received:
It sounds like the check valve has come apart. This prevents the D.E from leaking back to your pool after the equipment shuts off. You can go to www.haywardnet.com/locator to find a list of dealers who can assist you with getting a replacement. Thank you, Ben
Jul 18, 2011 | Hayward EC-40 DE Pool Filter with pump
My Haward perflex EC-40 filter allows DE and dirt back into the pool whenever we start it up or vacuum.
There's a hole in the filter allowing DE and dirt to pass. Find hole and repair or buy new. I just bought new grids off of ebay, great deal. I payed $112 for complete set by Unicel and saved over $100 My filter is a Hayward DE4820
Jul 08, 2011 | Hayward EC-40 DE Pool Filter with pump
I have Hayward EC-45 filter leaking DE into pool via return line every start up. Checked all troubleshooting causes (tube tears, bad gasket, cracked tube sheets, loose bolts, o-rings, etc. All looks OK to...
If D.E. is returning to the pool, it's usually because you have a tear in the grids or the backwash valve is not working properly and returning D.E. back to the pool.
Aug 24, 2010 | Hayward 1.5 Hp Northstar High Performance...
Have voltage to the Hayward Tristar pool pump but it won't run!
SOUNDS LIKE YOU HAVE A BAD BREAKER.. THIS IS A GRAVY FIX.. I SEE A VOLT METER IN YOUR FUTURE YES ITS ONE TO CHECK 230 V AC .. YOU LOCAL CAR PARTS STORE HAS THESE CHEAP .. ASK HOW TO USE IT AND YOUR OFF.. WHAT WE ARE LOOKING FOR IS 230 240v IN THAT RANGE ON THE 2 WIRES ON THE BACK OF THE MOTOR... OR EVEN THE TIMER.. NO?.....BREAKER NO? REPLACE BREAKER... BREAKER YES.. CHECK TIMER CONTACTS .. don't forget to prime your pump after a repair !!!!!!!!.. did i help ? well then please vote.. I got to get back to fix'n the pool pumps here in Florida ... Jay .. PPRG
Jul 08, 2010 | Hayward TRISTAR INGROUND POOL PUMP - 2 HP...
We have aEC-65 hayward pool filter with a 1HP motor why does the pump slow down run at higher pressure ?
I believe that this particular model is a DE pool filter. Is that correct? If you are operating with a media other than DE, let me know. Assuming that you ARE using DE:
1. You DE could be coated to the maximum with pool dirt algae, etc. To correc this problem, you need to bump the filter.
2. You could have an overcharge of DE. To remedy,
Bump-Drain-Recharge.
3. Restriction in return line caused by small
eyeball fitting. To correct, change to a larger sized fitting.
4. You could have a partial closed valve on a return line. You will just need to open the valve.
5. Make sure that your pump strainer basket and pool skimmer basket are not clogged.
6. Make sure that your pump impeller valves are not clogged.
May 25, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
My DE pool filter stops working after an hour? please help
Is your pool green? This will cause the filter to plug up. When you say stops working do you mean no water flo, passing dirt or are we talking about the pump not moving water? Can you clarify this problem some?spellcheck.gif
Aug 16, 2009 | Hayward EC-40 DE Pool Filter with pump
D.e. earth pool filter returning dirt to pool
Jun 08, 2009 | Hayward EC-40 DE Pool Filter with pump
Pool & Spa Logo
32 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
