Question about Refrigerators
Amanda SXD2252L where is the water filter located
Trying to replace the water filter on my fridge/freezer put it in vertical and tried to turn to the horizontal position to lock in place wont turn and don't want to use excessive force any advise plz
Amanda,
I have had to use pliers before in putting those in. Just be careful that you try not to force beyond the horizontal. Also, try pushing in while turning, sometimes that helps.
Jun 06, 2015 | Refrigerators
Amanda refrigerator w/ ice and water in door. Button for water is stuck and keeps running every time we close the freezer door all the way
You have an obstruction in the door that is pressing the water button. Look for that where the water line is . This is probably a physical problem.
Feb 10, 2013 | Refrigerators
I have an Amanda double Door refrigerator with an ice & water dispenser. The ice machine unit's dose not dispense ice cubes,
If the unit is making ice and the water will work from the door but the does not dispense, you will need to replace the "auger motor". Here is the part to order.
Nov 28, 2012 | Amana 22 cu.ft. Side-By-Side Cabinet Depth...
Can't locate the water filter. water has a bad taste
The base grille water filter is located below the freezer
compartment door. Depending on your model, you may have a filter that is installed behind the base grille or a filter that is installed through the base grille.
May 23, 2009 | Kenmore Refrigerators
Same problem
F/02 = Long Drain check the drain hose for kinks or check the electrical connections at the pump..Also check the filter for foreign objects(you need to remove the 3 screws in the lower panel ) twist open the filter and see what is stuck inside have a towel or 2 ready to catch the water ThenPress Pause/Cancel twice to clear fault
Apr 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My amanda washing machine
My amana washing machine will not unlock
Mar 21, 2008 | Washing Machines
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
