RCA RT2911 1000-Watt Home Theater System
Flashing power indicator light
SeattleTimE
  • 3 Answers
SOURCE: not powering on
I solved this problem on my HTS3410D.
Inside there are two circuit boards, the power supply board and the audio/video board.
  • First, unplug your unit and let it sit for a few hours.
  • Now open the unit up, and unplug all of the connectors going to or from the power supply board. You can easily tell which board is the power supply board because it's the one the power cord plugs into.
  • Unscrew the four mounting screws that hold the board to the case.
  • Using a pair of needle-nose pliers, squeeze the two white plastic clips that hold the board to the case (one at a time), while gently lifting the board away from the case.
  • Now that you have the board out, feel the tops of all the capacitors (they look like this). Healthy capacitors should have a totally flat top. (There is probably one that is covered in some sort of heat shrink, so you can't feel the top.)
  • One capacitor most likely has a slightly bulging top. That is the culprit.
  • Using a soldering iron, carefully remove the busted capacitor, making sure to note which side the stripe is on.
  • Buy a replacement capacitor at Radio Shack or www.digikey.com that has the same capacitance (e.g. - 1000uF) an equal or greater voltage, and an equal or greater maximum temperature.
  • Insert and re-solder the replacement capacitor in the same orientation as the one you took out, then trim the excess leads.
  • Reassemble your system, and you're done.
The capacitor that died on mine was 1,000uF, 16V, 105°C. It was located fairly close to where the power cord comes in to the board. I replaced it with a 1,000uF 50V capacitor, and the system powered right up like a champ. The entire process took me about an hour.
I hope this helps some other people have similar results.
Posted on Mar 20, 2008
SOURCE: rca rt2770 home theater universal remote code
hehehe i just found it mebbe i will tell u mebbe i will jk this is it either - 0790,1913,31023,31609,31254 mebbe one of those will help. the first one worked for mine. i take it u know how to program the remote
Posted on Jul 02, 2008
  • 3 Answers
SOURCE: no sound though home theater when watching tv
There is an orange button on the remote, half way down in the middle. I belive it has orange lettering and says something like "TV-?" press that, and the sound should start to come through your speaker system. You can then use the original remote that came with your TV and turn the sound off on the TV to use just the theatre system. I noticed that if you use the TV speakers in conjunction with the theatre system, that it echo's.
Posted on Nov 26, 2008
SOURCE: need to program 311w U. remote to RTD215 home theatre
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Posted on May 03, 2009
SOURCE: push power protector showing up in sony dvd home theater system
Always be the audio amplifier IC damaged
Posted on Jun 24, 2010
How do i program rca home theater
How to Setup a RCA DVD Home Theatre System RTD325W ...
? 10:31
https://www.youtube.com/watch?v=20dRIj8KWPU
Jan 28, 2012 - Uploaded by TheHandofOdd
Just how to setup and get the optical cable working for those who need help.
RCA Home Theater System Set Up - YouTube
? 5:37
https://www.youtube.com/watch?v=j0UhnbrjJto
Sep 14, 2012 - Uploaded by gangstafly5000
The RCA hooked up to 43' plasma Samsung. ... RCA Home Theater System Set Up. gangstafly5000 ...
RCA 5.1 Surround Sound 1000 Watt HOME THEATER ...
? 13:06
https://www.youtube.com/watch?v=1xfEmkwCwyA
Oct 18, 2014 - Uploaded by bigtruckseriesreview .
I bought recently rca system home theater and makes strong fan.... +Aiden woodruff Change he settings to surround, and make sure all of the ...
How to Set Up an RCA Home
Jan 13, 2016 | RCA Televison & Video
Rca rt2911 beeps
Try with an hdmi cable . I think
Mar 04, 2013 | RCA rt2911 1000-watt hdmir home theater...
I Just recently bought this have it hooked up to my Computer through a Digital audio Coaxial cord . The problem is this 600 - Watt system is emitting less power than the 300 watt one it replaced that was...
Audio power is relevant only between the amp and the speakers. Check the volume setting of the source and any audio settings in the PC.
SPDIF is not Red and White. If anything it is a single coaxial RCA connector.
Wattage specs for comparison are pure fiction at this level. 10% distortion fudges the number upward.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RT2910-Home-Theater-Systems-manual/id/23699ag100/t/2/
Defeat any bass enhancement in the source until you figure out the level issue.
Mar 23, 2011 | RCA RT2910 Theater System
Need manual for RCA 250 watt home theater system model RTD 315W
Register at retrevo.com and download it for free. "RCA RTD300" finds it.
Feb 08, 2010 | RCA RTD300 DVD/VCR Home Theatre System...
RCA 5.1-Channel 250 Watt Home Theater System - Model RTD209
Unit was working fine,took a movie out,put in new one,but would not play.Tried hitting open button ,unit will not respond,all other functions working ok.
What could be the problem,is it worth fixing?/Is there a reset button somewhere on unit?
Oct 27, 2007 | RCA RTD209 System
50 people viewed this question
 Grubhead
Grubhead
