Network blocked I forwarded port 43594 on my router but when I run a check it says its closed and I need it open.
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 82 Answers
You might try using a port trigger instead. That way the port will open when needed instead of having it open all the time.
Posted on Jan 11, 2014
2 Suggested Answers
amusedgeek
  • 787 Answers
SOURCE: firewall trouble shooting
Restart your computer and immediately start pressing F8
A list should appear, select Safe Mode with Networking
Try Runescape and see if it updates, if it does there is something running n your system that is blocking the conection.
If it cannot update we need to know if you have a router or gateway and it's make and model.
Posted on Oct 05, 2008
Why can't I print on cloud print with my canon inkjet mp830. It keeps saying "printer offline"
Hi, you may find that opening port 5222 in your router settings corrects this for you. This is due to Google Cloud Print (GCP) needing to poll your printer, if the port is not open then GCP will not get a response from your printer, therefore will show it as offline.
It is also possible that your firewall is blocking communications so you would need to open the same port (5222) in your firewall / antivirus software.
Warning: Ports are often closed on a router to help prevent unauthorized access to your home network. Opening any additional ports on your router may decrease the overall security of your network.
  1. To use port forwarding first determine the local IP address of the computer or device you are forwarding the port to.
  2. Open your router configuration / settings menu.
  3. Once in the router configuration locate the port forwarding settings, often in a section such as Applications & Gaming or Port forwarding. I would suggest that if you are having difficulties with this to refer to your router documentation or call their support line.
  4. You will only need to open port 5222.
  5. Give your new rule a name that you will recognise.
  6. Next enter the port number 5222, if you are asked for Externet and Internet enter 5222 in both.
  7. The protocol is TCP.
  8. Next is the IP address of the computer.
  9. Don't forget to check the enabled box if there is one and save changes.
If you have any issues with this I would suggest Port Forward web site where specific instructions should be available for your router.
Tom
Jan 10, 2014 | Canon PIXMA MP830 All-In-One InkJet...
My x-box tells me to open port to connect, i cant get it to work. bungie net tells me to open port 802.11 n not b or g . i cant make it work,x-box tells me my nat is not open. please help. thanks ...
The Linksys router, like any other router, will block "unsolicited" traffic from the Internet coming "into" the router (for "forwarding" to your computer that is "behind" the router).
So, you need to access the web-server "inside" the router, from a computer that is "behind" the router, and you need to modify the "blocking" of the router's "firewall", to "allow" (instead of "block") traffic from the Internet to a specific port-number.
You'll also need to "forward" that port-number to a specific computer "behind" the router.
Compare to a secretary that receives telephone-calls for several managers in the office.
When somebody calls the office, the secretary may look at the caller-ID, and may choose
to *NOT* pickup the telephone, i.e., to "block" the incoming call. Thus, none of the telephones
on the desks of the managers will ring -- they will not receive any notification that the secretary
has "blocked" the call. Or, the secretary may recognize the caller-ID as being that of the spouse of one of the managers, and may just "forward" that incoming call to the correct manager.
The secretary needs to know which of the telephones is associated with the spouse of the caller, so that the "correct" person responds to the incoming call.
The secretary is doing the 'NAT' ("Network Address Translation") to correctly do the "forwarding".
Similarly, the router needs to be configured to do the 'NAT' correctly.
Jul 13, 2011 | Linksys Computers & Internet
Im trying to chang the nat setting on my valet m10 router to open to all xbox 360 to run live
You need to setup port forwarding read below.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
For Linksys Router.
You have opened the set up interface of the router. You will see Application and Gaming TAB at the top.
If you click on that tab you will find different Sub tabs.
Click on Port Triggering => Here you can open the port numbers for the network.
Click On Port forwarding if you want to open the ports for a special device in the network.
Click Save settings once you open the ports on the router.
For D-link router
You will see Network settings in the left hand side panel of the page.
Click on Network settings and go to the Advanced TAB at the top.
Now you will find the option. Pot Forwarding in the left hand panel.
Here you can open the ports on the router.
BELKIN wireless router
Click on Virtual Servers under Firewall in the menu on the left
Click Enabled. Type a general description of the application i.e.. Remote Desktop. Type the port(s) specified by the program manufacture for both of the Inbound port fields. Select TCP, UDP, or BOTH for the Type.Private IP address: Enter the IP address of the computer you want grant access too. Type the port(s) specified by the program manufacture for both of the Private port fields.Click the Apply Changes button.
NETGEAR Router.
Click on Port Triggering under Advanced menu.
Change the value of Port Triggering Timeout as 20 Click on Add Service. Specify a Unique/User Defined name under Service Name. Ex: Mails, VPN. Specify the Service User as Any (if all the computers in the network are port triggered or if a single computer on a network is port triggered specify the IP address of the computer). Select the Service Type of the port to be triggered
Ex: TCP . Specify the Trigger Port (The port to be triggered). Select the Connection Type of Inbound Connection. Specify the Starting and Ending Port for Inbound Connection. Click Apply to accept changes. Your router is now set up for port triggering..
http://www.youtube.com/watch?v=fYwd0YkXdY0&feature=related
Jan 20, 2011 | Computers & Internet
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
How do I open ports 500, 4500, 53, and 52428 on Dell TrueMobile 2300 wireless router. Need to open them for Verizon Network Extender
1.Open the router interface by checking the default gateway
2.Under FIREWALL, you can find an option that would say "Virtual Servers"
3.Enable these ports, along with their types(TCP/UDP/Both) and assign an IP address that your Verizon Network Extender is going get( you to set that manually on the verizon device)
Save the changes and the ports will get forwarded!
**Note: In this case, DMZ under FIREWALL will NOT work!
Jan 18, 2010 | Dell Wireless 2350 Router
Port Forwarding on NB7Plus4W router
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
For example ,
You have a Linksys wireless router and you want to open the ports for the X-box.
Some of the recommended port numbers for different applications :
IMAP ==> 143 SMTP : 25
HTTPS ==> 443 HTTP : 80
DNS ==> 53 FTP : 21
SNMP ==> 161 TELNET : 23
XBOX ==> 53, 80-88, 3074
PS3 ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
WII ==> 28910, 29900, 29901, 29920, 80, 443
VPN ==> 1723, 500, 443-447, 10000-20000
World of Wars ==> 3724, 6112, 6881 - 6999
Click Here for more info
Nov 22, 2009 | NetComm NB5PLUS4W Wireless Router
Settings on Linksys router for the DCS 5220 to view remotely and settings on Securicam
Configuring your Linksys router for remote desktop is a task that's needed before you can access your computer from outside the network. If you plan to connect to your remote desktop machine from the Internet, you need to configure the router to allow traffic to the PC. Linksys is a common router used on home networks for wireless and LAN configurations. Configuring your router to allow port forwarding to a remote desktop only takes a few steps through the graphical user interface.
  1. tep 1 Open your browser window and type the IP address of the router in your address bar. This opens a window for the username and password needed for access to configure the router.
  2. Step 2 Click the "Applications and Gaming" tab on the opening screen. This opens a window with a list of ports of which you can open for access on your network.
  3. Step 3 Type "Remote Desktop" in the application textbox.
  4. Step 4 Enter "3389" in the "Start" and "Stop" port ranges. This port number is specific to the remote desktop application.
  5. Step 5 Leave the value of "Both" in the protocol listbox.
  6. Step 6 Type the IP address of the internal machine on your network. The IP address is the machine running remote desktop. When traffic from the Internet reaches the router, it forwards the request to this IP address.
  7. Step 7 Check the "Enabled" checkbox and click "Save Settings."
  8. Step 8 Close the browser window.
Nov 14, 2009 | D-Link DCS-5220 Network Camera
Dose this router work as a firewall switch?
It is not possible to close all the ports on the router.
you can open other ports.
by default port 80 is open on the router.
On the router there is no such setting to close the port.
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
I need to open a port to use utorrent
first u download a software called ultra surf from anywhere on the net...then this software will search for most suitable port and it will open it for u...
OR
simply u can change the port no. between ' 6880-6889 ' in the preference option in utorrent....I think this will solve ur prob...KSHITIJ
Jun 17, 2009 | D-Link GamerLounge DGL-4300 Router...
Firewall trouble shooting
Oct 02, 2008 | Computers & Internet
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
