Question about GE Superadio III AM/FM
Radio does not work when it is plugged in,but does work battery
Milwaukee heavy duty job site radio.. it will not work when it is plugged in,but it will work off of my 18 volt drill battery.the catalog #49-24-0200
  • 4 Answers
Mine has a bad transformer, but I am having a hard time finding a replacement. This is due to the fluctuating voltage of the job site generator.
Posted on Oct 28, 2009
Charger dont work on 2790 20 jobsite radio?
clean all contacts, on the battery and the charger. I use a pencil eraser if you can get in to the contacts. If it still does not work, it's time for a new charger or battery. The chargers are not heavy duty and fail much more often than heavy duty business radios.
Aug 02, 2015 | Radio Communications
Radio wont work
Check to fuse.. there may be one inside
Apr 21, 2014 | Milwaukee Tool Milwaukee 49 24 0280 Radio...
Job site radio work turn on seems there is no power going to radio. When plug in there is no sign of power in the radio. I have replaced the cord end and that didn't help.Any ideas?
probably the transformer, if it works on the battery but not plugged in thats the most likely cause. I have the same problem and will repost if the transformer replacement works. Cheers
Oct 02, 2011 | Milwaukee Tool 49-24-0200 AM/FM Radio
How do you set the clock on a milwaukee radio
turn the radio on, push the MEM button display window will flash turn the tuning knob clockwise to set hours and counter clockwise to set minutes push the MEM button and hold 5 seconds to set time. Hope this helps, if I have solved your problem would you please vote accordingly and thank you.
Jun 10, 2011 | Milwaukee Tool Milwaukee 49 24 0280 Radio...
How to set time on milluakee job site site radio.
Go go this link and look in the second paragraph under "Using Your Radio"
http://www.protoolreviews.com/reviews/power-tools/cordless/radios-generators-vacuums/milwaukee-jobsite-radio-2790-20
The numbers at the end of the link are the model number. If yours is not that model, the fix may still work.
Ringbearers
Apr 08, 2011 | Audio Players & Recorders
Milwaukee tool 18 volt nimh battery won!t charge
If the battery pack is more than 2 years old its time for a replacement. The typical charge/discharge life cycle of a rechargeable cell is 500 - 700 times and the shelf life is about 3-4 years from the date of manufacture. If the charging indicator lights up when you dock the battery on to the base and still does not work after 5 hours - its due for a replacement.
Apr 08, 2011 | Dewalt Accessories Batteries 18 Volt
Drill dies smoke from handle
coulsd be a burnt switch or battery, take a look at the battery contacts and then remove battery and look at the contacts on the switch,
Oct 27, 2010 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Need forward/reverse switch for older red and metal heavy duty 1/2 inch 7amp milwaukee drill serial number 0007196072.
Link to find parts list:
http://www.milwaukeetool.com/CMS/Diagrams/54-10-4006.pdf
You can google the 23-66-1020 part number and find numerous suppliers.
RECALL NOTICE!
Milwaukee is providing a no-charge warranty service to owners of 1610-1, 1630-1 1/2" Compact Hole-Shooter Drills and
1670-1, 1675-1 1/2" Hole-Hawg® Drills. We are taking this action because under certain circumstances the switch of the drill
may stick in the "on" position, which could lessen control of the product, posing a risk of injury to the operator.
1610-1, 1630-1 1/2" Compact Hole-Shooter Drills and 1670-1, 1675-1 1/2" Hole-Hawg® Drills within the serial number
ranges shown below and sold between May 30,2000 and February 27, 2001 are affected.
Nameplate Catalog Number Serial Number Range
1610-1 700B400200013 thru 700B400480097
1630-1 718B400230057 thru 718B400480118
1670-1 472B400200061 thru 472B400440188
1675-1 413B400190567 thru 413B400522000
Drills listed should be inspected for the presence of a 23-66-1020 Switch with a date code within 0 0 2 1 t h r o u g h 0044.
If the unit contains a subject dated coded 23-66-1020 switch, please return drill to the nearest Milwaukee factory Service Center
or Authorized Service station for no-charge warranty replacement of the switch.
Affected switches carry a manufacture's four [4] digit date code of 0 0 2 1 t h r u 0044 imprinted on its body.
If nameplate has an 'X' stamped into the tool's nameplate, next to the catalog number, the tool has been repaired and the
defective switch has already been replaced.
If you need assistance in locating the service facility nearest you or have questions please call 1.800.729.3878
Oct 05, 2010 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Put drill in revcerse and the chuck comes loose dropping the bit out
Yup, that is what happens. You can lessen that by really cranking it down, but it is an issue with most hand tightened chucks, and does not indicate a mechanical failure. I sometimes miss my old, heavy Milwaukee wrist-breaker with the keyed chuck. If it is just too much to live with, you could get a drill with the click in hex chuck or put a Jacobs keyed chuck on your hammer drill.
Anyway, I hear where you are coming from and share your frustration.
Regards, Farmerbear
Sep 09, 2010 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
My milwaukee radio just quite working ? why ?
may be there is something wrong with the male end you plug into the wall or the cord itself
Aug 20, 2010 | Milwaukee Tool Milwaukee 49 24 0280 Radio...
GE Superadio III AM/FM Logo
491 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
