Question about Singer Sewing Machines
Kenmore 158.321 how to change needle?
  • 29 Answers
Loosen the screw that holds the needle in place, pull the old one out, pay attention to which way the flat bit is facing, push the new needle in as far as it will go with the flat part facing the same way as the one you pulled out, tighten the screw and your done. The flat bit 9 times out
Posted on Apr 25, 2013
  • wyrm_book
    wyrm_book Apr 25, 2013
    Loosen the screw that holds the needle in place, pull the old one out, pay attention to which way the flat bit is facing, push the new needle in as far as it will go with the flat part facing the same way as the one you pulled out, tighten the screw and your done. The flat bit 9 times out of 10 will face toward the back.
What should your tension be set on sewing machine for when sewing a 2-sided baby fleece blanket?
Sewing fleece presents some special challenges. For one, it dulls needles quickly, so change out the needles frequently. Sometimes a walking or rolling foot may be helpful.
http://www.sewsimple.com/articles/sewing_with_fleece
12 Tips for Sewing With Fleece
Tips and Tricks For Sewing Fleece Robes
Working With Fleece
Fabric Tips Sewing Fleece National Sewing Circle
Sep 07, 2017 | Kenmore Sewing Machines
After I broke a needle on my Kenmore sew machine 385 17622090 I installed a new needle but now my bobbin thread won't catch. Very frustrating
possible that when the needle broke ,the needle/hook timing was changed
take it to a sewing machine repair shop and have it checked and adjusted
Jul 24, 2017 | Kenmore Sewing Machines
What is normal tension settings on a kenmore model 158.12112
The tension depends on what you are sewing but usually a 4 -5. Also make sure thread and needle are the correct size for the materials you are sewing. and make sure needle and bobbin are threaded correctly and that needle is not, blunt or bent. :)
Mar 21, 2017 | Kenmore Sewing Machines
Needle threader on kenmore embroidery machine worked yesterday but I changed foots and needle threader won't move forward to engage the needle.
take the foot off & put it back on again making sure it's connected correctly,,also make sure the foot is not damaged in some way
Nov 04, 2010 | Kenmore 19005
Kenmore sewing machine #16227 needle thread making big loops on wrong side of fabric. Changed needle, cleaned, adjusted/readjusted and readjusted needle and bobbin tension. Will sew a decent stitch...
It is most likely because you have it on a type of stitch but did not switch the didstance that you want the zig zag to be. Just change you stitch or your distance.
Nov 20, 2009 | Kenmore Sewing Machines
Stitches are skipping, bobbin problem?
Here are a few things to try. One of these should fix your problem.
* Re-thread your needle
It may be threaded incorrectly (backwards).
* Change your needle
Your needle may be blunt, bent, or otherwise damaged.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and
thinner fabrics, smaller needles. You may also need a larger needle if
you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit
fabrics and a sharp needle for wovens (or a universal needle for either).
And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot
It may be too light for your fabric.
* Change your thread
If your upper thread and bobbin threads are different types, try using the same thread for
both. And use a good quality, brand name thread.
* Adjust your thread tension
It may be too tight or too loose.
* Re-thread your machine
It may be threaded incorrectly.
* Change your needle plate
Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
* Reinsert your needle
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the
flat side away from the bobbin, but consult your machine’s manual to be sure. I know you said you checked this already but it might not hurt to double check it.
Important Note:
After changing your needle plate, check to make sure your needle aligns perfectly with
this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which
could be dangerous. And make sure to change your needle plate back for zigzag and other wide
stitches.
Hope this helps.
Sep 15, 2009 | Kenmore Sewing Machines
Have you changed the needle? If you have sewn for many hours it may just be a matter of a new needle. Be sure to use flat back kenmore or kenmore compatiable needles...no Singer (too long).
Sep 29, 2008 | Kenmore 19233 Computerized Sewing Machine
Tye of needles
you can use schmetz, i actually prefer them
Jan 20, 2008 | Kenmore 19233 Computerized Sewing Machine
Thread caught up around bobbin!
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Nov 12, 2007 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
80 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
