Question about Vehicle Parts & Accessories
I need to know how to remove and replace the driver's door lock/actuator mechanism on a '96 BMW 750il.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 128 Answers
It shoud be a couple bolts holding it on? Am i wrong?
Posted on Sep 14, 2013
3 Suggested Answers
  • 231 Answers
SOURCE: The security alarm on my 1996 BMW 750iL goes on
2 most likely causes are: 1: a faulty hood switch.Check for the switch around the microfilter housings near the strut towers. 2: a faulty interior sensor. If you are sitting in the driver's seat. Look directly above your head in the center of the car. Pull the cover at the edges. You should see a sensor inside the cover. Unplug the sensor and retest your system.
Posted on Mar 10, 2009
luke_bradfor
  • 662 Answers
SOURCE: Have a 96 VS holden calais the drivers door
aaahhh...im glad i have someone that gives enough information to solve your proble,......the short answer is the drivers door lock motor.......the info that you provided proves that the remote is communicating with the vehicle, and that the wiring is good and sound......the part that you ned to know and understand is that door lock motors come in 2 main types. Master and Slave.
The back doors are slaves and they do what the master tells them, self-explanatory.
The front doors are masters. On the calais, there is an option for 2 stage unlocking, where one press of the remote opens the drivers door only, and the second press, unlocks the rest commanded by the passenger door, which is a master.
The master door locks have a remote section and a hardwire section. The hardwire section works because unlock/lock of the drivers door commands all the others but the remote section (electric motor - push/pull) is not working, hence it wont work by itself.
get yourself a 2nd hand drivers door lock motor and this will fix all your problems
hope this helps
Posted on Jun 11, 2010
Passenger door open
BMWs have solenoid actuated door locks (electric box that sits on top of the door latch - some years integrated into latch) that electrically "deadbolt" the locks. The door panel will have to be removed with door locked/closed (may result in damage to panel), electrical mechanism removed from latch, and latch manually unlocked. It's a very effective theft deterrent system, but when it fails, it can be a severe pain. The failure is quite common; they should almost be a regular service/replacement item on BMWs.
Hope this helps,
-Scott
www.EuroPartsPlus.com
Aug 12, 2014 | BMW X5 Series Cars & Trucks
How to reset door lock on 93 BMW 750il
I would call the dealer and ask the parts guy he may know and won't try to sell you service. if not that you can look in a chiltons repair manual at a auto parts store.
May 25, 2014 | 1989 BMW 750i
BMW 530 d m sport front door does not lock/unlock with fob, actuator in door is making correct noise have felt up inside door with door card levered off at bottom (could not remove fully did not want to...
before going to repair shop, sit in car and use fingers to try to move physical door part to lock and unlock. if moving freely, use fob lock and unlock driver's door.. if other doors will lock and unlock with fob then your door panel will have to come off. share your results with your mechanic.
Mar 03, 2018 | BMW 530 Cars & Trucks
I need to know how to remove the drivers door panel to access the door lock actuator
You did not mention your year or model, so I cannot help you very much, but these instructions are for one of the most common body styles out there so they may be of help. http://www.frontiernet.net/~papi/Speaker.htm
On anything since the mid-1990s, nearly all of the electronics in the door are contained within the actuator, so snapping in a new one will fix about anything that can go wrong. Just make sure that the new one is in the correct 'mode' (locked or unlocked) to match the door lock state when you try to snap it in so all the holes line up with the lock mechanism and it snaps down straight.
May 19, 2011 | BMW 318 Cars & Trucks
How to remove the in door of a 1990 bmw 325i? And also the drivers door will not lock when i turn the key the other doors lock but the drivers door doesnt how should i go about fixing that?
Sounds like you need to replace the power door lock actuator for the driver's door.
E30 Models
  1. Remove the door panel and the water shield.
  2. Disconnect the wiring from the actuator. Remove the screws and pull the actuator off the linkage.
  3. When installing, move the actuator and linkage to the locked position.
  4. Connect the linkage to the actuator and loosely install with the screws.
  5. Compress the actuator drive to take out any play in the linkage and tighten the screws.
  6. Test the locks and install the door panel.
E36 Models
  1. Remove the door panel and water shield.
  2. On the front doors, remove the guide rail nut and pull the guide rail down. Disconnect the wiring and the linkage from the actuator.
  3. On the rear doors, remove the window and the access panel. Disconnect the wiring and the linkage from the actuator.
  4. Remove the 3 bolts holding the latch and actuator to the door structure.
  5. Install in reverse order using threadlocker on the bolts.
Mar 16, 2011 | 2003 BMW 325
Describe how to replace a 96 camry rear passenger door power lock actuator
You will need to remove the door panel, mounted inside the door you will find the lock actuator, it should have a rod connecting attached to the lock cylinder, also there should be an electrical connector. Disconnect the rod and the electrical connector and remove actuator from the door.
Mar 10, 2010 | 1995 Toyota Camry
Power door locks will not unlock the door
if problem is mechanical you will need to remove inner door panel and lube lock mechanism if its electrical you need to test for power at the lock actuator which is inside the door panel the power will switch from one pin to the other depending on wether you are locking or unlocking if you have power to both pins when pushing switch both ways actuator is bad you can remove actuator a nd use manual lock till you can replace with new
Jun 07, 2009 | 2001 Ford Explorer Sport Trac
1990 BMW 750il Auto Transmission Switch Problem
have your bmw dealers check switch it might need to be replace.
May 08, 2009 | 2007 BMW 750Li Sedan
I have a 2003 Tiburron with a bad drivers side door lock actuator
what is wrong exactly? Because i bought a new lock actuator thinking it was that part, but it wasn't. It was actually the lockrod piece on the lock (above the drivers handle). That was broken. It could be that. Go to Hmaservice.com Register with them. They always help me with troubleshooting
Mar 29, 2009 | 2003 Hyundai Tiburon
Vehicle Parts & Accessories Logo
908 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
