2010 charger a/c
My a/c doesn't turn on
  • 31 Answers
When you turn the ac on, do you hear a click from the engine area? Find the ac compresor (should be top and front of motor with a belt attached) turn on cac and see if the plate in the middle of the compressor (where the belt is attached) is now moving. If not, the compressor is not engaged. Find fuse box, look on diagram for ac component and ensure it is ok. If good, check other fuse box under the hood for any additional fuses for the ac. If ok, find the low pressure safety cutoff . It will be located on one of the ac lines with 2 (maybe 1) wire coming off. Unplug this and using another piece of wire, connect those two terminal so it is in a 'loop' (do not use bare wire!) If this does not start the compressor, you could have a switch problem when you turn it on or a bad compressor. Do not buy a compressor until last resort as it will be expensive to purge system, vacuum it down, replace drier and freon.
Posted on Apr 22, 2013
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
My acer laptop suddenly shutdown then it didn't turn on,the led of the charger is blinking,what is the problem?
you may have had a surge on your charger, i'd unplug it and try a different outlet. After you unplug it, remove the battery for about a minute, then when at the new location plug the battery back in and then the charger. see if that works. if it doesn't it's possible that your charger just died. Did you happen to look and see how much battery you had available when it died?
May 14, 2012 | Computers & Internet
I was using my psp while it was charging and the charging light turned off, so i naturally assumed that it was fully charged. But a few minutes later the battery died and it wont charge when i plug it in....
Have you tried to remove the battery and put it back in and try to turn it on. Try removing the battery and putting the charger in and starting the PSP. If it starts, it might be the battery. If it doesn't, it's either the plugin for the charger or the PSP is just dead. If it does start with the charger, try putting the battery back in, if it charges awesome. If it doesn't the battery might be dead.
Sep 27, 2011 | Sony PlayStation Portable (PSP) Console
I've borrowed a friend's Garmin for a trip and when I use the car charger, it doesn't display anything. Once I disconnect, it becomes visible again. I'm going on a long trip and worry. ...
Assuming there is power at the cigarette lighter jack - turn the Nuvi off - then connect the charger. It should display charging battery or charging complete.
If nothing - does it charge with the wall charger? If so check the fuse in the car charger - it's usually in the tip of the charger which can be turned to get the fuse out.
Jul 05, 2011 | Garmin Nuvi 660 GPS Receiver
Nikon Coolpix L110 camera was bought for me for Christmas 2010. Worked fine at first, but now seems to be having problems. Batteries don't last. I just bought new batteries in Feb/March this year...
You have to charge the batteries for nearly 8-10 hours. Brand new batteries also require a full recharge of 8-10 hours.Not only making sure the batteries are charged, have you changed the battery in the menu under type of batteries.
Download this manual :
http://www.nikonusa.com/pdf/manuals/noprint/L110_ENnoprint.pdf and go to page #114
Buy EN-MH2-B4/MH-73 Kit (4 Rechargeable Batteries + Charger)
Jun 14, 2011 | Nikon Coolpix L110 Digital Camera
Why does my Nokia phone say "charger not supported?
That error message usually occurs when using an unsupported third party charger. An example would be if you bought a cheap "knock off" charger that doesn't supply the correct voltage to the phone. These messages can sometimes occur in error when using an official or supported charger.
If you're sure you're using a supported charger, there is something you can try to fix this error. First, unplug the charger from the phone and the power outlet. Turn off the phone and then remove the battery. Wait about 15 seconds and insert the battery again. Turn on the phone, and plug in the charger to the power outlet and the phone. The phone should now charge.
If it's still not working, you'll need to try to get a new charger. Sometimes, if the phone is still in warranty, you can get the charger replaced for free if it is defective.
Jun 01, 2011 | Nokia 2626 Mobile Phone
Just bought a usb cord charger for my nikon coolpix s203 and its been dead fir a couple of days and I wont turn on
You left your camera on for a couple of days? I'd think your batteries are completely drained. The S203 doesn't charge batteries via the USB port. Try charging the batteries overnight using the supplied MH-63 charger.
If that doesn't do it, please reply to this post and we'll go on from there.
May 13, 2011 | Nikon Cameras
Heating & Cooling Logo
244 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
