Question about Nintendo Wii U
How do I fix error 102-1021 with the Wii U
The wireless router that I am using is a verizon hard wired in the box.
  • 61 Answers
SOURCE: wii wired connection for internet access?
Sorry to be the bearer of bad news but the Wii does not come with an ethernet cable port. It is only Wi-Fi capable.
Posted on Mar 30, 2009
  • 34 Answers
SOURCE: Wii Wi-fi Internet Connection
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Posted on Mar 06, 2009
fliiskater11
  • 53 Answers
SOURCE: wii wireless connection error 51330
get a new router
Posted on Feb 07, 2010
SOURCE: trying to connect wii wireless through my westell
It appears that the wii wants to work with wap security not wep. Need to go into the router with the 192.168.200.1 gateway. Next o to the security tab. Set up wap2 security password. On the drop down menu choose tkip and aes (both) setting. On the wii I would clear out the wireless settings and then set up a new wireless connection. Search for said and choose your router. Hit connect and enter your password. Save settings and have the wii connect, should get a connection successful message. Grab some popcorn and enjoy Netflix.
Posted on Jun 10, 2011
  • 823 Answers
SOURCE: I cannot establish a wireless connection to my wii
Find the name and password for your network on the bottom of your modem. S/N or WEP is usually the password.
Go to yoru Wii, open up setup for your wireless network. Enter the name and password from your modem in this area and save it. Then choose connect. This should solve your connection problem. Then go to websites and enter in "Netflix" in the search area. Make sure you have already set up your netflix account on a regular pc through the internet first. Log into your account and start choosing movies.
Posted on Jul 17, 2011
How to fix error code 51099
This is the error code when the wireless card on your Wii is having trouble connecting to the wireless network. It could be the SSID (wireless network ID) was input incorrectly, or if you have used this before, it might also indicate a problem with the router.
If your other devices are connecting OK, I would reset your wireless connection and create a new one for your Wii.
While you didn't mention any specifics about your router or which wireless adapter you are using for your Wii, but if you continue to have problems you may want to use a different wireless security.
If you want to try this but don't know how, please re-post and make to provide the brand and model # of your router and wireless device.
We used a wired adapter for our Wii and it works perfectly.
Nov 28, 2011 | Nintendo DSi Black Console
Tip
How to fix Wii Error Code 52130
To solve this error, try to manually setup the Wii console using your network IP settings.
To do a manual setup of the Wii console using your network IP settings :
  • On a PC, click Start > Run > type CMD and press Enter > type IPCONFIG/ALL and press Enter. On Windows Vista, click Start > type CMD in the Start Search box > click on CMD icon > type IPCONFIG/ALL and press Enter.
  • Locate IP settings and use them to manually set the Wii console.
  • Restart your wireless router by unpluging the power from the wall and plugging it back in. Try to connect the Wii console to the internet.
You may also try to disable the wireless router security or firewall. Try again to connect the Wii console to the internet.
on Aug 26, 2010 | Nintendo Wii Console
Error code 52130
This error is caused by a wireless router firewall issue.
Aug 12, 2011 | Nintendo Wii Console
My wii will not connect to wireless internet error code 52030
If you get an error code of 52030 on you Wii console, this indicates a problem with your Wii communicating with your wireless router. There are a couple things you can try/check to help fix this problem.
1 - Try using a different channel on your router and update your Wii to take to the router on that channel.
2 - If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
Feb 28, 2011 | Nintendo Wii Console
I am trying to update my wii so i can get netflix. i keep getting an error code of 32002. how can i fix this?
If you get an error code of 32002 on you Wii console, this indicates a problem with your Wii communicating with your wireless router.
There are a couple things you can try/check to help fix this problem:
1.Try using a different channel on your router and update your Wii to take to the router on that channel.
2.If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
3.Make sure the MTU values on your router match those entered on your Wii.
Also note that if you make changes to your wireless router and you have a computer that uses that router too, you'll need to update your computer to match the new settings on your router.
Feb 03, 2011 | Nintendo Wii Console
I am trying to get my wii to hook up to my verizon wireless internet and am unable to get it to accept the ssid on the broadband box, any suggestions?
Make sure that the encryption type is wep, wpa or wpa2 personal. These are all the wii supports.
next follow this guide.
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
if that guide does not work for you then get up to part 5 and select MANUAL SETUP and follow the instructions there. following this link http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/manual.jsp
depending on the verizon wireless internet you are using could matter. if this is DSL and you have the westell 7500 then you should be ok. if you are regular dsl adn you have YOUR OWN router added on then you need to make sure in the router wireless b/g is enabled and not N or b/g/n hybred.
if you are usign verizon wireless's new access point object you will be out of luck for it uses a vpn dial in protocol.
Jan 19, 2011 | Nintendo Wii Console
Error code 52130
Jan 07, 2011 | Nintendo Wii Console
Error code 52130
Nintendo Wii U Logo
1,648 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
