Question about Ovens
Tornado facts - Ovens
Tornado turbo chef Oven give f3 fault after16 secs
the most complicated error for this oven ... this error affects ur micorwave system .... this requires a tech to check ur unit
Sep 05, 2014 | TurboChef TORNADO Electric Oven
Can u cook air fried chips in the turbo.tornado oven
Yes any thing that is not greasy as it will block the catalytic converter
Jun 02, 2012 | TurboChef TORNADO Electric Oven
TurboChef Tornado is showing error Close door P _ _. How do i fix this?
The primary switch is broken most likely. Take off the right cover and look past the control board and see of that switch is broken. its only a couple dollar part.
Jan 20, 2012 | TurboChef TORNADO Electric Oven
Turbochef tornado electric oven overheating and smoking one transformer is working fine but the new one is overheating
If transformer is looking burnt then replace it . It will show you F3 code once the transformer is. Totally burn. Tell me if you need help . I am tech for turbochef
Oct 14, 2011 | TurboChef TORNADO Electric Oven
F7 code
HELLO the F7 fault code means that you have opencircuit in the , ir thermocouple which is in the bottom element or the thermocouple for the top cc element,
May 02, 2010 | TurboChef TORNADO Electric Oven
I have both a tornado and a C3. I am getting a F2
for the f2 low temp verify the high-limit thermostat is not tripped. inspect the mags, make sure they are not loose. Also try inspecting the ir element washer look for corrosion or signs of arching. Is your wave cover damaged or missing. Sorry to say this generally is a factory trained fix because its usually because of an rf leak
Oct 09, 2009 | TurboChef TORNADO Electric Oven
Ovens Logo
16 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
