Question about Teac PD-H300 CD Player
TEAC H300CD Player
My CD player has recently had trouble loading some CDs, not all though. Occasionally it takes time to read the track info, then it can't load the first (or some other selected) tracks. It happens with shop purchased CDs and CD R that i have recorded. Any ideas?
  • Dave Thumb Aug 29, 2007
    Thanks - tried cleaning the lens, no real improvement so off to a repair shop with it.
    Brigadier General:
  • 6,966 Answers
Hi, Your particular brand/model was made in the very early 2000. It is possible that the eye (optical lens) is already weak and would need replacement or calibration. You may want to try and clean the lens hopefully improving the reading capability. Some users of CD players use a PC CD cleaner to clean the eye (pls read the instructions) though this can be done by going inside the unit). Probably your best bet is to seek the services of a qualified professional. Hope this be of some help and give you ideas. Pls post again how things turn up and/or if you need further information. Good luck and kind regards.
Posted on Aug 04, 2007
SOURCE:
Is the CD player replaceable if we can get the correct CD replacement? I've tried to get the info from TEAC and they don't answer my email.
See if you can get the exact unit on the cheap on ebay. Teac obviously does not give a rat's a-- about your dilemma .
Your laser assembly is fubar and not repairable - not cost effective.
Time to move on after 9 years of use.
Aug 02, 2015 | Teac Audio Players & Recorders
The cd player goes into a "skipping" "playing really fast" mode occasionally. Esp. 3rd track, 1st cd. Always has.
It's having trouble reading the CDs. The thing that reads it could be dirty. But try a different cd. The CD player is getting old and if there is even a small scratch it will be hard to read it. A new CD player would be the way to go
Mar 14, 2013 | Audio Players & Recorders
Is there a setting that allows the cd player to automatically start playing a cd when power is applied? my player seems to do this sometimes, but not when power was recently applied... only when it has...
CD Player can play CDs automatically and for this you need to set the clock and timer first and put the player in stand by mode.
Remember there should not be any power failure and if there is any power failure then clock and timer will be reset and player cannot play the cds.
Aug 16, 2010 | Teac CD-P1440 CD Player
Will not read the disc
The optical lens assembly is damaged at this point. the lens has burned out and the tracking/load motor seems to be faulty as well. replace the optical lens asap.
Jun 02, 2009 | Onkyo DX-C390 6-Disc CD Changer
My teac dvd/cd player wont play some cds
Probably a codec problem on the notebook. rather than a drive problem. Try a 3rd party media player such as Real Player or Quicktime
Feb 15, 2009 | Teac CD-Rewritable W28E CD-RW Burner
Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Nov 28, 2008 | Denon Dns1000 Table Top CD Player CD...
DVP-NC85H - - Shuffle play among several CDs
You should refer to your Product's Operation Manual for help on this. Also, you may goto www.sony.com for more info.
Apr 29, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Copying CDs to MP3
You need to edit the tag information before you transfer them to the MP3 player.
You can right click on the track and select rename or, Properties>Summary Tab and then make the changes then transfer to the device.
If you are using Windows Media Player to RIP the tracks, there is an option to "GET CD INFO" from the internet to save you a few steps.
Best of Luck.
Nov 01, 2007 | Audio Players & Recorders
CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Aug 12, 2007 | Teac PD-H300 CD Player
TEAC CD-P1260
Identical problem with my 4-month old player. I mailed the unit to the repair shop noted on their web page (Montebello, CA). They "re-soldered a loose connection" and made a "mechanical adjustment". I got the player back in two days. It now works fine (again). Under warrenty; no charge.
Jul 02, 2007 | Teac CD-P1260 CD Player
Teac PD-H300 CD Player Logo
1,002 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
