Question about Brother P-Touch 1750 Label Maker
My ptouch 1750 gives me an error message that says "no tape!" but i have tape installed. help!
  • 168 Answers
Hi, Make sure that the cartridge is installed and that there is no slack with the ribbon. You can turn the tape by advancing the tape in the center of the cartridge wheel, IN THE DIRECTION of the arrow on the cartridge. You can advance the tape by pressing 2 buttons: CODE and Space
Also if you installed a new cartridge, make sure that you removed the safety cover.
Hope this helps.
The owners manual can be found at this address:
http://www.ptouchdirect.com/ptouch/manual/PT1750.pdf
Have a good day.
Mac =)
Posted on Mar 13, 2014
P-Touch Model PT-65 Home and Hobby Label Maker - Loaded a new cartridge and it will not feed through
Sir/Madam
Its Very Easy To Fix This Issue,Just Follow Few Simple Step and You Solve Your Problem By Your Own,
Read Below Instruction,
1Turn off the label maker before installing the tape.
2Press the part marked as "<<" and lift the cassette cover.
3 Position the tape into the slot. Make sure to feed the end of the tape under the tape guides.
4Check that the lever is up before closing the cover; the cover will not close if the lever is pressed down.
5Close the cassette cover.
6 Press the power key to turn on the device. If using an AC adapter, plug the adapter into the wall then press the power key.
7Type a sample to test if your installation was successful.
Read more: http://www.ehow.com/how_7526530_install-tape-ptouch-label-maker.html#ixzz2pMqUU0oU
Jan 02, 2014 | Brother BRTPT65 PT-65 Label Maker Printer
"no tape" error
I found 2 helpful manuals from brother that you may want to checkout. they explain exactly how to install the cartridge:
http://www.ptouchdirect.com/ptouch/manual/PT1000.pdf
http://www.ptouchdirect.com/ptouch/manual/PT85.pdf
Feb 18, 2013 | Brother P-Touch PT-2400 Label Tape OEM...
I need help to change the tape on my p-touch 55 brother labeller
Hello. here is the owner manual http://www.ptouchdirect.com/ptouch/manual/PT55.pdf
Just look at the section entitled "installing/changing the cassette tape". Regards, Joe
PS kindly rate my answer. Thank you.
Jan 24, 2010 | Brother P-Touch 1180 Label Printer
Ptouch 2400 on windows 7
Your only choice is to go to this page:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_index.html?reg=us&c=us&lang=en&prod=2400eus&dlid=&flang=English&os=44&type2=-1
Try installing the software and if it doesn't allow the install or it does and you still can't use it then you know that ptouch isn't supported in windows 7. The software for that ptouch on that page is for windows xp but its worth a shot anyway.
Nov 26, 2009 | Brother P-Touch 2400 Thermal Label Printer
Error message HP Officejet 7310 "remove and check cartridge on right. Removed cartridge, checked it (nothing), installed it back - still same message. Installed new original HP cartridge - still same...
Can you find a friend with a similar HP printer, i.e., one that accepts the same model-number of ink-cartridge? If the cartridge gives the same error-message in the other printer, it's time to responsibly recycle your "dead" cartridge, and give the brand-new cartridge to your friend, for his/her usage.
Nov 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Doesn't print anything
My P-touch has the same issue. There is a U-shaped spring wire that pushes one of the rubber wheels so it presses the tape against the element that "writes" on the tape. A small piece of plastic that holds the spring in place broke off so the spring can't do it's thing. CA glue (superglue) would not work, I am trying to find a parts source now, it is easy enough to replace.
Mike
Jun 15, 2008 | Brother PT-1750 Thermal Label Printer
Label Maker HELP!! Brother ptouch 1180
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Computers & Internet
SONY TSL-S9000L error message
Hi RIO,
I need a little more information to better assist you with your problem. What Operating System are you running and how old is this unit?
Is this the first time you are using this device?
Also look at the event viewer for info on the actual error, which could help to better explain what the problem might be.
--Roadhawk
Nov 24, 2007 | Sony TSL S9000L (TSL-S9000L) DAT Tape...
Brother P-touch labeling system PT-1750
You dont. This machine was designed to waste your money and raise Brothers profits.
Oct 04, 2007 | Brother PT-1750 Thermal Label Printer
Brother P-Touch 1750 Label Maker Logo
642 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
