Question about Poulan Pro " Pro" Self Propelled Mower
Throttle mechanism will not move.
The throttle mechanism on the engine will not budge. My daughter, who owns the mower said it suddenly started "acting up" and stopped working. It appears that she may have broken one of the plastic cable clamps trying to get the throttle linkage to move. I pulled the cable from the upper clamp and tried to pull the cable by hand and it wouldn't budge. I the disconnected the lower cable attachment. I then tried to manipulate the throttle mechanism with no cable at all and it still wouldn't budge. I even tapped on it with a small ball peen hammer, again with negative results. What can the problem be.
  • 31 Answers
Try 'break free' or any kind of penetrating spray around the throttle. Give it 15 min to soak in and try it again. Make sure you are pushing/tapping on the moving part and not the stationary piece. Should be another linage from there to the actual carb. Check that it is free and moving easily. Cable problems usually are inside the cabel,rust etc that binds the cable but you should be able to move the actuator w/a pliers with the cable unattached. Good luck
Posted on Apr 22, 2013
wireguy212
  • 1627 Answers
SOURCE: lawn mower engine stops while pushing
sounds like the float is set too low or you need to clean the carb.check the fuel filter and tank screen also.
Posted on Jul 29, 2009
  • 15 Answers
SOURCE: Mower blades locked
You may have broke the flywheel key. if that broke it will not start. The key is important for the proper ignition timing. They break so you dont damage the crankshaft. It may be a big job if you dont know your way around a small engine.
Posted on Apr 22, 2010
SOURCE: Poulan 550 Series push mower won't pull start
Poulan 550 series self propeeled mower. Mower starts and stops running after 10 seconds. Gas tank full. Filter cleaned.
Posted on Sep 17, 2010
  • 16 Answers
SOURCE: I have a two year old Craftsman 650 series mower
Well you have done everything that there is to do. What did you set the gap between the new coil and the flywheel?
You may want to try the old plug to see if the new plug is bad. Would not be the first time that I have seen a new plug that was bad. Do you have a spark plug checker? It will show any spark as it jumps a gap.
Posted on Apr 25, 2011
  • 640 Answers
SOURCE: I apologize if this post sounds familiar. The
Two things likely happened, but one is real bad and I think that both probably happened here. The lesser of the two is a sheared flywheel key, which explains why it will not start. The greater is a bent shaft which is why it is so hard to turn even with the spark plug removed. To check for the bent shaft, remove the spark plug and tip the deck enough to get a good look at the blades and turn the blade. If there is a wobble of any kind then the shaft is bent. Also if the shaft is bent, with a push mower it is not cost effective to repair unless you are willing to do it yourself.
Posted on Aug 17, 2011
Testimonial: "Thanks for the advice. I will remove the flywheel and see whats there."
Why does the mower have to be full throttle to start it, to make it move at all, and to stay running at all?
this could be a few things as to cause :
1- throttle cables stretch as they get older , if marking on throttle says "run" it might really be choke on carb - looking down carb body(air clean off) with engine off move throttle to choke the choke butterfly should shut off (choke does have small hole in it) the butterfly should not be just barely moving or half way it needs to be closed all the way
2- modern fuels leave deposits inside of carbs if machine is left to set for long times (weeks) these deposits don't just get washed away when the engine is started again either , they must be chemically or mechanically flushed away by either a carb cleaner (chemical) or taking carb apart and cleaning it totally out (inside and out) -these deposits cause poor carb performance and even non working engines
a method to keep from having to do this often , is to install a fuel shut off valve in the fuel tank ( might already have one there you just gotta look for it) and when your done with machine shut off the gas valve and allow it to run out of gas dry !
Sep 22, 2015 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
My briggs and stratton engine throttle cable and throttle body wont engage,always wide open
Are you sure it's not a new style Briggs that uses the 'throttle cable' just as a shut off? Many new mowers on;y start and run at High Speed
Jul 05, 2013 | Briggs & Stratton Garden
Cub cadet 1515 will not throttle down after engine is started
check throttle cable see if it lose or broken if loose tighten it broken replace it
May 29, 2013 | Garden
Toro 6.5 model 20016 throttle stuck open
I believe that is the governor spring you are referring to. YES it needs to be replaced, before you sustain permanent engine damage.
May 21, 2013 | Garden
Throttle is stuck tight can't budge it. I have already lubricated it. Any suggestions
Get a second person. Have them actuate throttle (gently) at the lever. Feel if cable is stuck or throttle tang on motor is stuck. You haven't lubed the right spot or waited long enough or used strong enough oil. Try liquid wrench. Take needlenose pliers and try to move throttle lever at the closest point to the motor while helper is trying to work the throttle. Go easy, don't break it. It'll come.
Apr 10, 2013 | Garden
Cub cadet lawn mower suddenly decreases power at full throttle
check the spring tension on the carb linkage
May 11, 2012 | Garden
Craftsman Riding Mower (24 HP 42 in cut Model 289254) with throttle issue. Very slow in 6th gear
follow the throttle cable all the way down to the engine. Have some one move the throttle up and down to see if the throttle plate is opening and closing all the way. You can loosen the screw holding the throttle cable and move it back and forth to see if it will allow the throttle plate to open and close correctly. It may have slipped when the assembler tried to tighten it.
Mar 10, 2012 | Craftsman Garden
I have A Scott Bonner lawn mower ,high performance,overhead cam, SX 4000, 4 stroke.I am finding it very difficult to start the cold mower every time I go to mow the lawn.It takes me about half an hour of...
Hi and welcome to FixYa, I am Kelly.
The symptoms you describe are typical of debris in the fuel bowl of the carb. I am going to assume for the moment that it is a similar to a Briggs and Stratton engine. Engine model type and serial information is what we work with to resolve engine problems regardless of the mower brand. I note you said it was a Scott Bonner SX4000 engine. I am also assuming that you have the 18 inch GreenKeeper like this one:
http://www.rovermowers.co.nz/www/rover/Home.nsf/13a851504c93cb754a257821000cfc6b/$FILE/28045.pdf
I do not have access to Scott Bonner Engine parts or technical data but if you clean out the fuel float bowl and it is still hard to start then the choke function of the engine is not working. Your engine has a "Bowl drain" screw on the bottom of the carb float bowl for removing carb debris or water in addition to a bowl nut.
Most likely due to the throttle cable needing and adjustment so that the choke is closed when choke is selected. Adjustment of the throttle cable is as simple as losening the clamp screw (Do NOT remove it) on the side of the carb throttle control and moving the throttle to STOP then re-tightening the clamp retaining screw. This should allow your choke to move full closed when selected. You may have to experiment with full throttle and STOP throttle control positions with the clamp screw loose but not removed to see which position will give you full throttle, choke and STOP. After each adjustment you MUST tighten the clamp screw to test the throttle cable travel on the the throttle plate. Beleive it or not... the person that assemble the mower made the intial throttle adjustment. It may have never been tested before you got the mower.
If you still have problems.... this is the brief way to start an engine that has choke problems. Remove the spark plug and squirt a splash of gas into the spark plug hole and then re-install the spark plug. Just don't over-do the splash of gas and if your messy wipe off the excess so you do not start a fire. (This method always works but you occasionally foul a spark plug with too much gas)
Thanks for choosing FixYa,
Kelly
Feb 01, 2011 | Garden
Our mower is lacking power, on full throttle it appears as though its not getting enough fuel to allow it to get maximum revs. I changed the fuel filter and also put a tap in the fuel line, and I installed...
If it starts and runs fine, the first thing I would do is to check if the throttle cable sleeve has slipped where it connects to the carb. I have seen a few of these tractors where the cable was not tightened well enough and it slipped.
I don't have a picture of your actual motor. But here is a picture of the clip that holds your throttle cable tight. toolboxhero.jpgFollow the cable from the handle on your dash down to the motor. Find this clip on the side of the motor. Now: Move the throttle back and forth until you see how the cable moves the throttle mechanism. Does the cable extend to give the engine full throttle or shorten?
You want to move the cable so it gives the engine more throttle. I personally do this with the engine running but don't do this yourself unless you are comfortable doing so. So loosen the bolt and move it only about 1/8 inch at a time.
If you don't feel comfortable doing this call 1-800-4MY-HOME and have a Sears tech come out and work on it.
Let me know if you have any more questions.
Jan 10, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have mower with briggs & stratton engine starts & idles fine pushing throttle forward it just stays on idle throttle appears to have full movment can you help
Make sure the throttle cable moves when you move the throttle. Tighten cable to coupling if necessary.
Mar 19, 2010 | Garden
Poulan Pro " Pro" Self Propelled Mower Logo
142 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
