Question about Ovens
Gaffers sattler I have an old gaffers and sattler wall oven with the model number partially scrubbed off, the part i can read is 053-***3-111. I am trying to replace the thermostat and the marking rubbed off the old one since it took so long to find the new one, new thermostat part number is 993-321, any idea how to re wire this thing without the diagram and without frying my new part?
  • Stephan Apr 22, 2013
    after a bit of searching im thinking the serial number is 053-18253-111 and model # R92KA-3W...not 100% but it looks correct.
SOURCE: Need wiring diagram for old 1960's General Electric Wall Oven
55de40b.jpg Hopefully this will help. Don't know if it is the same model, but it is a 60s GE built in oven.
Posted on Jan 10, 2009
  • 10865 Answers
SOURCE: We have a 37 year
Hi. Take the screws out around the frame and the oven will slide out of the cabinet. good luck.
Posted on Feb 04, 2009
SOURCE: old thermador 1950s wall oven, will not turn
Did you find a solution to this? I have the same problem.
My email ...tgl@hotmail.com
Posted on Jan 05, 2010
SOURCE: NEED A WIRING DIAGRAM FOR A GE
Click on the link below to view the wiring diagram for your electric oven
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=216042
Posted on Jul 07, 2010
SOURCE: HEATING ELEMENT GAFFERS & SATTLER BUILT-IN
our 1985 gaffers and sattlers oven would not turn off tonight. Any idea? Its Propane oven
Posted on Nov 22, 2010
How do I turn off the timer on my gaffers & sattler wall oven?
Try rebooting the oven; unplug it for 90 seconds, or flip the circuit breaker off for 90 seconds, then back on.
Apr 17, 2016 | Ovens
I have a 1965 gaffers & sattler wall oven with the oven on the top and the broiler on the bottom. It began having issues lighting even though the pilot light was on. Now the burner doesn't light up at...
My Mom has a 1965 Gaffler & Stattler Mark 21 wall mount oven, it had the "Same Problem", People may tell you that the flame switch is no longer avalible but I found a universal fit flame switch at Applance Parts Center, I took the old part in and had it matched up, with a minor modification to the thermal sensor mounting bracket, "drilling a larger hole and lightly crimping it", it's a perfect fit, "problem solved". You may want to try cleaning the pilot light area with a small wire brush first, if that dosn't work try a jumper wire on the two terminals of the flame switch, if that works then replace the flame switch.
This operation can be done without removing the oven from the wall mount, just remove the two screws from the panel at the inside rear of the broiler, you will find the flame switch behind the panel it has two screws two wires a thermo leed and a sensor tip that goes up to the thermo sensor mounting bracket above the pilot light, the thermo sensor mounting bracket has one screw and a nut behind it, you will also need to remove one end of the 1/4" pilot gas pipe in order to remove the thermo sensor mounting bracket, When your done puting it back togather, check for gas leaks using soapy water in a spray bottle, a dish soap solution works great, also check your vent pipe connections.
After I cleaned the dust and grease out of this old thing, the 45 year old clock and timer started working again.
My Mom is very happy, try and find new oven to fit the cutout and vent, we saved a lot of $$$,
"Good Luck".
Nov 18, 2010 | Ovens
Repair or buy new oven.
replace the element....they are not that expensive.
Jul 20, 2010 | Ovens
HEATING ELEMENT GAFFERS & SATTLER BUILT-IN OVEN
Dec 22, 2009 | Ovens
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
Ovens Logo
88 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
