Question about Coleman Powermate 5000 Portable Generator 6250 Max Watts In Box
Carb settings for Techumseh 10 hp - Coleman Powermate 5000 Portable Generator 6250 Max Watts In Box
How to adjust governor controls on 13 hp techumseh engine fitted on 45 in cub cadet snowblower
At the base of the governor arm is a screw, loosen the screw and move the arm approx, 90 degrees. Allow the engine to come to a steady idle then tighten, the move the throttle up and check for a smooth exceleration. it may take a little back and forth but this should get you there.
Feb 17, 2015 | Cub Cadet Garden
HOW DO I AJUST MY GOVERNOR ON MY TECHUMSEH 10 HP
Buy a new governor spring. That is what sets the governor speed.
Feb 16, 2015 | Garden
HOW DO I AJUST MY GOVERNOR ON MY 10 HP TECHUMSEH
This is a great place to start donyboy73 on youtube does pretty thorough set of videos on these
Feb 16, 2015 | Tecumseh Snowblower Snow Blower Starter...
New coil no spark
more than likely the carburetor jets are plugged up. This is a common thing to happen
the jet is located on the bottom of the float bowl if it is a Techumseh engine
Use a stiff wire to clean through all 4 bore holes of the jets
carb cleaner in a spray can is needed as well
Jul 09, 2011 | Mantis 2-Cycle Tiller
I need to know how many turns it takes to get the carb ajusted correctly on my 5 horsepower techumseh engine
Their is no exact amount of turns if it is running turn screw until motor runs smooth if not running turn in til seated than turn out 1 1/2 turns and start motor than turn usually out a little till engine runs smooth
Apr 24, 2011 | Garden
Have to choke to keep running
this is not hard to do here is what you need , 1 can of carb cleaner anykind will do , a 10 mm rench to remove the bowl 7/16 socket . now remove the carb take a good look where the spring is before you take the carb off it muct go back in the same hole , now that you have it off take the bowl off remove the float place to the side here is the fun part look in the carb you will see some small hole spray them this will clean all of the old gas out if you can let it set for about 10 min then do it again blow out with air if you have one nothing else to do but reinstall this works most of the time ...Good Luck..
Aug 16, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Toro Recycler with Techumseh enging will not start
Make sure it can breath. Check the airfilter element. If its oil soaked replace it. Sounds like this engine cannot breath. This engine is set ,there are not jets to replace. Champion Plugs are not the problem FIRE IS FIRE . Fresh Gas if it aint less than 30 days old it aint fresh. Todays designer fuel goes stale quickly.
Jun 27, 2009 | Garden
Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Coleman Powermate 5000 Portable Generator 6250 Max Watts In Box Logo
83 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
