Hp 8500 printer error code 0003
Wants me to restart, done that but no change. Went to hp help which thought it was power related. Did everything they asked but still comes up with same error msg.
  • 2072 Answers
SOURCE: Maintenance kit for Xerox 8500
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
Posted on Jan 15, 2008
SOURCE: error 5700 displayed on copier screen
Hola tengo un proble con la Impresora Canon, se me atasco la hoja en la bandeja de atras y luego lo jale duro, ahora me sale un "error" es el " 5700" y no puedo hacer nada, alguien me puede ayudar alguien tiene el kit de mantenimiento, que me lo pueda mandar, max_el_diablillo@hotmail.com
Posted on Sep 21, 2008
SOURCE: Canon IR3300 showing the error code E000602-0003
ERROR CODE E000602-0003 what i do
Posted on Feb 08, 2010
pineworks
  • 4041 Answers
SOURCE: cannot get rid of error msg
Hello there
There may still be some thing there jamming it so try this.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 18, 2010
  • 55 Answers
SOURCE: HP 8500 all in one printer: error 0x61011bef
0x61011bef is a general error that the chipset in the printer gives instead of a "carriage jam " error message.
Double check inside the printer as well to ensure that there is no bits and peices stuck insde the printer where the carriage assembly ( where the printheads sit) check to make sure that moves freely.
as well as clean the rollers on the back of the printer... silly yes but it has been know to cause an error if there is built up paper dust on them
Posted on Mar 27, 2010
Phaser 8500 error code 19,003.48:64663
19.003:48 is the error code 64663is the number of pages the unit has printed. the error indicates a power difference of +- 20% when trying to drive the printhead. The issue is the Electronics Module (System logic and power) or the Wave Amplifier (Printhead Controller). Both of the parts are fairly easy to replace. If it is the wave amp it is a somewhat affordable part.if it is the EM you should replace the printer. It isn't worth the fix.
Dec 12, 2013 | Xerox Phaser 8500/DN Printer
Hp officejet pro 8500 error messages
This seems to be Hardware issue. However we can give it a try.
Disconnect the power cord from back of the printer ( Do not turn off power ). Hold the Power and Cancel button and connect the cord and release the buttons after 2-3 seconds
Regards,
Sean
Apr 22, 2013 | HP Office Equipment & Supplies
I have a new hp officeet pr 8500 printer but on start up the screen displays error code 0060 and then goes blank. how to fix?
This error means there's an ink leak in your printer. HP recommends that you turn the printer off (using the power switch at the back of the printer), wait 20 minutes and turn the printer on (condensation may be causing error and the printer needs time to dry).
Mar 12, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
ERROR CODE e000602-0003 HOW TO CLEAR THE ERRROR APPEARING ON THE SCREEN OF CANON IR 6000
This is HDD related problem, try : turn off copier pres 1 and 9 (hold it ) then turn on the copier. That initalizes the hdd defragmentation. if does not help, you need to change the hdd and "fill" it with system software.
Apr 23, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
HP Color LaserJet 8500dn - Error Code 54.2 Carousel Cycle Power is preventing me from printing. I recently changed the magenta toner and it clicked in normally, but the error code came up. The manual says...
Even thought the cartridge clicked in normally, there is a problem with it. If you still have the old one, put it back in, if the error clears, you know the new toner is no good. If the flap doesn't lift or is binding it will stop the carousel from spinning, a 54.00.02 is a cyan toner error. If you have another toner you can try that also. I know they aren't cheap, but a lot of refurbished toners can do this out of the box.
Apr 09, 2010 | HP LaserJet 8500 Color Printer
Error code E000001-0003 canon clc2620n
it is a fusing/fixing error try this on the control panel press * with head 2&8 together *with head >copier>function>clear>err>ok turned off/on the machine hope this help
Oct 01, 2009 | Canon Office Equipment & Supplies
Error code E000740-0003
hi the error code means tah lan card cannot be read and faulty check the harnes betwen it and the PCB if its ok change the card thanks.
May 20, 2008 | Canon imageRUNNER 2200
Fault code
arrwup.gifDescription An error has occurred related to the Electronics Module 50 V Power Supply. The clutches operate at 50 V. The Head Maintenance, Deskew, and Pick clutches are drawing too much power indicating a short in the supply or one of the components connected to it.
Mar 13, 2008 | Xerox Phaser 8500/DN Printer
jasbo
jasbo
