Question about Black & Decker Kitchen Appliances - Others
How to open a electric kettle
Hello since I bought the electric kettle I do not know how to open it to wash it, could you tell me. Thank you
Electric kettle switches on and off every 10 seconds and doesnt boil
Hello Tobi. Is it still under warranty?
If yes send it back (don't tell them about the milk thing!)
If not I sugest you bin it... You've knackered the thermostat me thinks... :-(
May 28, 2016 | Kitchen Appliances - Others
Which is the best electric kettle?
You can go for Cuisinart electric kettle, I have been using this kettle for a few years now. Never had a problem, it is easy to use and wash. It is a cordless electric kettle has stylish design and stainless steel body.
You can check GroomNStyle, for best electric tea kettle reviews and information.
Jul 28, 2015 | Kitchen Appliances - Others
Krups Tea Kettle isn't working. I believe the problem is in the handle. It doesn't heat the water.
hello,
the handle has noting to do with the heater what you need to check on is the connection from the power supply if the connection is alright then you will have consider the element it is the heat provider connected to the wire it means that it is weak it need to be replace with a better one the element is in silver colour you can get it in any technical store/shop around you.
thank you
Jun 10, 2010 | Krups Stainless Steel Electric Kettle...
Why does the water boiled in this kettle smell and taste chemically? Any boiled in a plastic kettle in my home is fine.
hello,
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
Jun 01, 2010 | Morphy Richards 43072 Cordless Electric...
Kitchen Appliances - Others Logo
65 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
