Question about Cell Phones
Helpme My hyndai elantra starter is not starting
  • 31 Answers
Probably need a new starter gear if sounds rough. Do you have an automatic or manual trans? Get some one to push the car and then put it in gear. This should move the engine a small amount so the starter gears are now in a different location and it might wtart. If manual trans, push fast and let out the clutch in 2nd gear with the key on. Should start or again move the engine enough to use starter. Hope it helps
Posted on Apr 22, 2013
2002 Hyndai Accent occassionally will not start
check your starter sometimes the solenoid gets stuck if this is the case you will need to replace the starter.
Feb 18, 2010 | 2002 Hyundai Accent
Where is the fuel filter on a 2000 hyndai elantra
If it's anything like the 2000 Hyundai Accent (which it probably is) it is mounted on top of the gas tank. First make sure you have a tank that is less than half full (8lbs per gallon), then jack up the car and place jackstands in a secure place. Then place a jack and 2x4 under the tank. Remove the 2 straps and slowly lower the fuel tank, it's most likely on the passenger side on top of the tank.
Jan 06, 2010 | 2000 Hyundai Elantra
I have hyndai elantra 2001 automatic sometimes hesitant to start.
Sounds like a fuel pressure problem. Check/inspect your electrical connections to the fuel pump (power & ground). Also, connect a fuel pressure gauge to the fuel line at the fuel injector rail - leave it connected so if and when you have this problem again, you will be able to determine if the cause is fuel pressure/pump.
Sep 06, 2009 | 2001 Hyundai Elantra
Hyndai elantra 2003 what happens if you overflorw
Drain some out !! And re-fill it..
Over fill will blow out seals & gaskits and causemajor leaks..
When you are filling it.. The car should be running in park.. The dipstick messures in pints - not quarts..
Rate well ;o)
Jul 22, 2009 | Hyundai Motor 2003 Elantra
Fuses for dome lights 2001 Hyndai Elantra
b-alarm 10a fuse located in engine compartment fuse box,fuse gives power to dome and map lights.
Jul 01, 2009 | 2001 Hyundai Elantra
What type of maintenance is require for hyndai elantra 2004 72606 miles?
Check your owners manual. If you don't have one the dealer can order one for you.
Jun 10, 2009 | 2004 Hyundai Elantra
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
