Question about Ricoh Aficio SP C242SF
Paper jam broke my ricoh AFICIO SP C242sf
When removing a paper jam, a plastic bar running across the printer broke off. It has pegs on either end and "teeth" on one side which face away from the opening. Each peg also had springs on them. This piece is seen when opening the front panel and is under the section labeled to change from paper to envelopes. Can I order this part and repair it myself? What is this part called? What do the springs hook to?
SOURCE: Ricoh Aficio AP2000 Laser paper jam
Found solution myself.. The paper sensor arm with flag and sensor was missing from the exit side located on the fuser assembly.. Customer apparently broke off prior to calling for us to repair. Solution-replaced fuser assembly clean and tested works great
Posted on Feb 07, 2008
Joed911
  • 4338 Answers
SOURCE: paper jam in Ricoh Aficio 1515MF
Go to this link, and click on "How to clear misfeed a,p,y"
http://www.ricoh.co.uk/KBase/KBLink.cfm?ProductUID=1878
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 11, 2008
Cogz
  • 1326 Answers
SOURCE: RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Posted on Jan 25, 2009
  • 86 Answers
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
  1. Check CN983, it may be disconnected on the IH inverter.
  2. Defective IH inverter - replace IH inverter.
  3. Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Posted on Mar 01, 2009
  • 4 Answers
SOURCE: paper jam indication, but cannot find the paper that is jammed
I would check to see if the paper is even making it out of the tray. A lot of times, the feed rollers can get dirty, and the printer will display a jam if it doesn't feed in time. If the feed rollers look ok, then I would check and see if the feed rollers are even turning. Sometimes the motor that turns the feed rollers wears out.
Posted on Apr 27, 2009
Aficio spc242 service call sc543
There may still be small fragments of the paper jammed in the machines roller system that you might be able to get to.
At worsethe roller has teeth busted on the gears and pulleys.
Aug 03, 2014 | Ricoh Aficio SP-C242SF - 21 PPM Flatbed...
How to change feed roller on RICOH Aficio SP C242DN ?
1. remove all the cartridges.
2. remove the waste toner bottle.
3. rear cover
4. left cover
5. paper feed clutch
6. close the top cover and front door.
7. pull out the tray.
8. stand machine with the rear side facing the table.
9. slide the paper feed shaft to the left side.
10. remove the paper feed roller.
Jul 09, 2014 | Ricoh Corp Aficio SP C231N Laser Printer
How to reset error code ricoh sp c242sf
SP5801 THIS PROGRAM MAKE RESET IN ALL RICOH
https://youtu.be/-DGnULMHtD4
Nov 15, 2013 | Ricoh Aficio SP C242SF
Paper jam c
Unable to print troubleshooting and routine maintanance chapter in user's guide
Mar 23, 2013 | Ricoh Aficio SP-C210SF Printer
How to open front cover for ricoh aficio c820dn printer as it is displaying message " open the front cover to check the paper jam"
Hi there !
You have to open the front cover means that you have to oper the toner compartment and check for the paper jammed inside.
Did it helps your or you find the paper jammed.
Jan 29, 2011 | Ricoh Aficio SP C820DN Laser Printer
Ricoh SP c221sf Aficio upper misfeed jam? What's that all about? There is no apparent paper misplaced anywhere in the paper path.
I had the same error. In my case one of the two springs in the paper tray was missing (on the floor behind the printer) so there wasn't enough force to push the paper up to the pickup roller. After I installed the spring the error cleared and printing resumed.
May 18, 2010 | Ricoh SP C221SF Aficio Printer
Ricoh Aficio SP C420dn Printer. The printer at
sc491 is a high voltage output error. Combined with your jamming issue, it sounds like a possible electrical problem somewhere. A good first step is to turn the machine off and unplug it, then take off the covers and reset any connections or cables you can get to.
If the problem persists, you should have a service technician take a look at it because it might need a board replaced.
Apr 27, 2010 | Ricoh Aficio SP C410DN Laser Printer
My Ricoh Aficio SP-C210SF Printer jams almost every other print i make. What should I do?
is the machine new?
check the paper size, check the paper tray -if the paper end fence is loose(the paper should not move around).
try using fresh paper(from a sealed pack)
Jan 07, 2010 | Ricoh Aficio SP-C210SF Printer
Ricoh Aficio SP C411DN printouts can be rubbed off of paper or lables
Fuser pressure roller is worn. Fuser is sold as part of the "maintenance kit"
Apr 16, 2009 | Ricoh Aficio SP C411DN Laser Printer
Ricoh Aficio SP C242SF Logo
200 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
