Question about Home
Shower When turning the power on the shower don't turn on
Get a normal shower lol
Posted on Apr 25, 2013
keemo68
  • 1263 Answers
SOURCE: Triton Millenium Power Shower
generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Posted on Sep 03, 2008
  • 68 Answers
SOURCE: shower/spout
The valve is installed upside down and needs to be reversed. There is a diverter in the valve that gives the spout priority. When the valve is upside down it gives the shower head priority. Thats why it runs without the diverter being activated. You will need to get in the wall from one side or the other. Cut the valve out and either flip the faucet Or change the direction of the diverter depending on the style of valve.
Good Luck, Phil
Posted on Dec 10, 2008
frcs68
  • 1605 Answers
SOURCE: shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Posted on Jan 13, 2009
jonbrown725
  • 73 Answers
SOURCE: Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Posted on Jan 17, 2009
  • 297 Answers
SOURCE: 1/2 water through shower head 1/2 through tube
patmac make sure the clear hose is a overflow first. then make sure all connections are correct,sounds like an areator problem,some after market shower heads don't come with one you can purchase one at your local plumbing store.
Posted on Jul 27, 2009
Shower walls
You have got a lot of moisture behind your wall covering. Is that a plastic or fiberglass shower wall liner? You are going to have to tear out the shower walls, clean the studs, replace insulation and put in new walls. You must stop the leak too! You could be growing a lot of mold in the cavity behind your wall.
Jul 06, 2013 | Tools & Hardware - Others
How do i remove the faucett handle for a moen t2444nh monticello single shower handle
it may have build up from water and soap on white viniger will clean all the hard ater build up off in order to tiurn it
Dec 23, 2012 | Moen T2444NH Monticello 1-Handle Posi-Temp...
My galaxy aqua 2000 shower has started to cut out the last 2 after 10 mins. I'll turn it off n leave it for 10 mins ten turn it back on then it will happen again. I've taken the head off n
my Galaxy Aqua 2000 Electric Shower keeps running (cold water) even after swithing power OFF it used to completely shut down b4..what should I do 2 rectify the problem ...Please advise.... Thanks a bunch
Oct 18, 2012 | Galaxy Aqua 2000
I have a delta 1400 series bath/shower and for the life of me, I can't figure out how to get the shower to work. I turn the knob to the left to adjust the temperature. However, I don't have an...
I had the same problem. My building manager showed me that you have to yank the circular portion at the end the of spout where the water comes out downward and the water will be diverted to the showerhead.
Aug 29, 2011 | Delta T13420 Chrome Classic Single Handle...
My steam shower is dripping water when it is turned off... all water is turned off.. please contact me since my water is dripping and is costing me money! the drip is where the steam comes out.. my number...
You have to turn main water off to house, then in side shower head is a gasket / otherwise known as a 0-ring, that needs replacing. Yes, a 50 cent part is causing this. If you don't know how to replace shower head 0-ring, just take shower head to any home depot,they will put it inn for you. Just make sure you turn main water line to house off, otherwise real leak. Let me know if helps. Thanks mike
Jun 22, 2011 | Thermasol Electrical Supplies
Installed a moen L82694cbn shower /tub combo. With the temp lever between the hot and cold settings the water backs up and comes out the showerhead along with coming out the faucet. With the lever all the...
I don't know if you had the mixing valve out or got it turned around but, try taking the handle off and operate the shower without the handle, in other words, turn the valve so the left side of the valve is now in the up position and just stick handle on and make sure you have your full range and hot and cold water. Two other possiblilities are, if you did not runwater before installing new valve, you may have gotten trash form the lines, plugging your valve. If you can't resolve the problem by mearly turning the mixing valve, you may want to remove it, make sure it's nott plugged and turn it 180 deg:
http://www.youtube.com/watch?v=J-SNBNijfQc
This is a video on how to remove the valve.
Jun 20, 2011 | Moen & One Handle Tub & Shower Faucet
Bought this shower head and need to remove old one from pipe
The pipe that the shower haed attaches to is just a chrome plated brass nipple. On the shower head, there should be either a hex type looking nut or, two flat spots where you can puy a pair of channel locks or pipe wrench on to turn off counter clockwise. The"nut", so to speak, will be a part of the shower head. Sometimes, the nipple will want to turn also. In this caes, you will need a second pair of channel locks to grasp the nipple. You may want to put a rag on the nipple, because the teeth of the channel locks may hurt the finish. Once you have the old shower head off, turn your water on and let it run for a couple of seconds to clear any debris out of the line. If you don't you may clog the new shower head with the junk in the lines. Turn off water apply teflon tape or thread sealant, if desired and screw the new head on clock wise. It shouldn't need to be overtightened.
Jun 14, 2011 | Brasscraft ACE" ADJUSTABLE SPRAY Deluxe...
I have an American Standard shower that drips out the shower head. When other faucets are used in the bathroom the water pours. I replaced the cartridge put it still drips.What could be the problem?
Hi kwbaker!
Assuming the cartridge is new and the water drips at both hot and cold settings, I would check your shower head. It is not uncommon for debris to collect in the screening there and clog the spray nozzle.
To check the shower head you'll need to remove it from its piping. Use two tools--I normally use an adjustable wrench and a strap wrench--to hold the wall pipe and simultaneaously turn the shower head counter-clockwise. The cresecent wrench grabs the hex-head of the shower head, while the strap wrench holds the chromed piping without scratching it.
Be sure you don't lose the rubber washer inside the pipe-to-shower head connection!
Once the head is removed, look inside it at the pipe side. You should be able to see into the mechanicals of the shower head--very often I'll see bits of rust or scale. Oftentimes its enough to rinse the pipe side of the head under a sink; in extreme situations it can be easier to replace the entire shower head.
To replace the shower head, use two tools in the same manner in which the head was removed: crescent wrench to turn the shower head, strap wrench to hold supply piping. This time, however, turn the shower head clockwise until it tightens snug.
Hope this helps!
--Joe
Nov 12, 2010 | American Standard One Handle Shower Only...
Home Logo
42 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
