Question about Inverter Aims Pure Sine Wave Power 2000/5000w
Want To Install a 1250 W Power Inverter on a Class A Motorhome
My wife and I dry camp with our A Class Motorhome. There are restrictions on when you can run the generator to provide 110 V.
I want to install a Power Inverter that will handle TV, VCR etc.
My motorhome electical system 110V outlets has two lines from fuse panel. One handles crubside of motorhome (Refrigerator, water heater, furnace). The other handles roadside (TV, Mico Wave) I am interested on providing inverter power to roadside only.
My plan is to hook the Power inverter to battery cables that are hooked to the Power converter (which would not be operating since there is no 110V provided from generator or shore power) Hook the out let of the inverter to the roadside outlet line therefore providing power from batteries. I plan on installing a breaker/switch which would allow the inverter to work on when the other power sources are isolated.
Am i on the right track on slovong this problem? Any help would be appreciated.
  • dljacks48 Mar 14, 2009
    Thank you!
    I really appreciate the help! I thought I was on the right track and you have confirmed it!
  • 21 Answers
You are definitely on the right track. When you choose your power inverter consider the following: buy the inverter for around 40% more of your anticiapted load. You will need a double pole transfer switch to isolate the inverter from the generator(and visa versa). A simple double throw double pole switch with fuse or breaker protection should do it. You wouldn't necessarily have to isolate the curbside circuit as the double pole double throw switch would simply be switching the power from the existing generator to your new inverter for only the roadside circuit; i.e. you don't need to worry about the curbside power source as it will always be connected to the other branch circuit. Even if your generator or other source came on the system would be protected no matter what the the roadside configuration was set to as only one source of the 2 roadside power sources would be connected at any give time to the roadside circuit. The six dots represent the connecions for the double pole, double throw switch; shown supplying the new inverter to the roadside circuit while the source from the existing generator or inverter is disconnected via this switch from the roadside circuit:
existing * *------* new power inverter; switched to source
Middle 2 dots represent your roadside circuit and represent the "throw arm" of the switch. Safe and simple! If you don't have a voltage meter for your batteries you can purchase one for a few bucks. Just run it across the terminals so you will know battery condition as it is being drained (you may already have this indicator) You can find a transfer switch at an electrical supply place, maybe even Lowes. Make sure you get the switch that will be in a protected enclosre. The enclosurre can be purchased seperately if you can't find the switch/enclosure package together.
Good luck....gary
Posted on Mar 14, 2009
  • Gary Redden Mar 14, 2009
    My drawing got shifted around when I uploaded it.
    Here it is again:
    * *-----* new inverter
    existing cvtr
    3rd post- My ASCI sketch gets reformatted when I upload my response. Feel free to contact me and I'll send a sketch if you need one. Gary
My motorhome 1986 chevy honey wont start fuel pump has no power
is it class "a" or class "c"motorhome----was the unit in a accident--check inertia switch
Nov 08, 2012 | Cars & Trucks
Intermitten power loss
what kind of motorhome is it if it has a inverter it may be kicking in and out due to low voltage or a bad cell in the batteries
Feb 08, 2012 | Sharp R-1850A Convection/Microwave Oven
I have a 1250 watts inverter and i wanted to know if i can connect it to my 2003 ford explorer without connecting it straight to the battery
Let us look at the math. 1250 watts at 120 volts is w=va Watts equals volts times amps. Or in this case 1250 divided by 120 volts = 10.41 amps. But what is the 12 volt side capable of drawing. 1250 watts divided by 12 volts. 104.10 amps. This is more than what the average cigarette lighter or power port can provide. So, yes you need to connect directly to the battery, you can use a relay rated for 100 A in between the inverter and battery to control the power to the inverter. I would use a good #2 copper welding cable for the power leads. Now, if you are not planning on using the whole 1250 watts, then you can use a #4 welding cable (it is very flexible) for power leads.
Jan 21, 2011 | Inverter Aims Pure Sine Wave Power...
Does my ford motorhome have a gas shutoff switch 1991 ford sprinter v-8 7.5 liter
Most pickup based motorhomes have 2 fuel tanks, you may have a tank selector valve that is electric or vacuum operated. Check underneath and follow the fuel lines from the tank to the front of the engine, somewhere in between you may find that the fuel hose goes to a valve that is used to switch between the 2 tanks ie: main fuel tank and auxillary fuel tank.
Mar 29, 2010 | 1991 Ford Econoline
Fuel pump does not work- 1999 ford super duty class a motorhome
Check your vehicles safeties. Your ECM is probably programed for engine shutdown if it senses low oil pressure or low coolant level. Do a preliminary check.
Apr 28, 2009 | 1999 Ford Super Duty F 550
Newly installed g inverter GA25VA not starting up ? Help
Check that you have power reaching the unit, you may have tripped out on the main distribution board of the house.
Feb 02, 2009 | Heating & Cooling
Extra long in car adaptor.
hi you could always get an inverter for this job you can charge it up throught the cigeret lighter and the use it like a normal plug socket in the wall. you can get them from truck stops and camping shops hope this helps.
Dec 31, 2008 | Mintek MDP-1815 Portable DVD Player
Inverter Aims Pure Sine Wave Power 2000/5000w Logo
777 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
George Scott
George Scott
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
