Question about Garden
Ngk lamptimer s81nl
Is there a difference between a model # s81nf and a s81nl?
Spark plug gap for a Polaris sportmans 500 a 2010 year
0.028
http://www.polarisatvforums.com/forums/atv-repair-maintenance/14769-spark-plug-gap.html
BKR6ES(STOCK#6364) regular, or IRIDIUM BKR6EIX(STOCK#6418).Gap setting is .028.
That plug is used on all 500 HO from 2000-2011 Sportsman Models.
http://www.polarisatvforums.com/forums/atv-repair-maintenance/40754-500ho-ngk-spark-plug-number.html
http://www.ngksparkplugs.ca/results-motorcycles.cfm?model=empty&enginesize=500&make=POLARIS&apptype=ATV
Here is your manual. Spark Plug page 93. Page 123 says
Spark Plug / Gap NGK BKR6E / .035 in. (0.9 mm)
Different plug (E rather than ES) and gap. check the plug that came out.
http://cdn.polarisindustries.com/polaris/common/parts-manuals/9923420r01_lo_res.pdf
Jul 10, 2016 | Polaris 2004 Sportsman 500 H.O
Ngk cross reference chart
Here is a link that will let you see the different vehicles your plugs will fit. NGK Power Nickel Spark Plug Underneath the picture of the plug is a list of manufactures just click any of them and they open up a list of their vehicle brands that the plugs fit.
Mar 25, 2014 | 2001 Dodge Ram 1500 Truck 2WD
How do i reset lamp timers
this is written in the leaflet that comes with a new lampunit.
Each lamptimer has to be reset separately, this model has 2 different lamp units, AH-45001 and AH-45002
Reset should be done with a combination of buttons in standby mode !!
Oct 18, 2012 | Eiki EIP-4500 DLP Projector Multimedia...
Difference in NGK DPR6EA-9 and NGK DPR7EA-9 spark plug
The fourth digit is the heat rating of the plug, the bigger the number the lower the temp.
Mar 27, 2012 | Electrical Supplies
WHAT SIZE PLUG FITS KE 1977 KAWAZAKI
Hi and welcome to FixYa. I am Kelly.
The KE125 uses NGK B9ES
The KE175 uses NGK B7ES
The KE100 uses NGK B8ES
(You can use any suitable substitute using the NGK plug as a cross reference for other brands)
If I missed one let me know your Model please.
Thanks for choosing FixYa,
Kelly
Mar 26, 2011 | AMC Scrambler Cars & Trucks
Have replaced projector bulb,can not reset lamptimer
turn the tv ON: On the side of the TV press the menu and volume up buttons at the same time for three seconds. The 'reset lamp timer?' will appear on the screen. Press the OK button to accept. You're done!
Oct 22, 2009 | Vivitek Televison & Video
Plus UP-1100 Lamp Hours Rest Procedure needed. The lamp is replaced but no menu option for resetting hours and Google provides no answer.
To reset the lamp timer on the Plus UP-1100, turn on the projector, press the menu key, navigate to the power menu, go to the lamp timer, then press and hold the "power on" button on the remote control for 20 seconds - you will see the timer reset to 0000.
Aug 05, 2009 | Office Equipment & Supplies
How to choose the right spark plug for my bike?
only a handful will work with the motorcycle engine you own. Also different brands (NGK, Bosch, DENSO, Champion, Esc) will work better on different types of engines. As a general rule of thumb, use the sparkplug your manufacturer recommends for your motorcycle (same brand and part number). Unfortunately some spark plugs are very specific to a type of engine and make only for that engine such as the NGK ME8 for $34 per sparkplug, compared to the normal price of $3 per sparkplug.
Nov 10, 2008 | 1984 Yamaha XZ 550
Recommended spark plugs
I would go back with factory plugs. that year model is designed to run many miles and i would stay with factory. I have an 04 model of the same engine.
Oct 05, 2008 | Spark Plugs BR4HS Plug 10/BX #3322
Garden Logo
600 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
