Question about HP LaserJet 4650 Color Printer
Business cards get stuck in HP 4650
I am using Avery preformated business cards in a HP color laserjet 4650. I am feeding it in via the manual tray, but the cards get stuck. Do I have to change the paper type and if so, what setting do I use?
  • lawrencecoop Mar 12, 2009
    The sheet gets stuck just as it begins to exit the rollers into theexit tray. It looks like the printer is not expecting card stock.
  • jriggs256 May 11, 2010
    Where is the sheet of cards getting stuck? Is it even getting pulled into the printer?
  • 34 Answers
The card stock is most likely too heavy for the 4600. If you check the owners manual, you will most likely find this is "Out of media specifications".
Other color HP laser printers like the 2500 cannot move card stock well either.
HP will tell you that 'if the printer moves paper perfectly' it's not broken.
Posted on Mar 12, 2009
How do I print cardstock with Samsung ML-2510?
I found a manual for your printer here:
and under print media, it suggests limits of 60 to 163 g/m2 for the 2 trays. If you get some 160 g/sm2 card which is quite readily available, I think you will find it much lighter than the Avery business cards card, which from memory come in around the 200 - 220 g/sm2 level.
Even Avery quote this card as "heavyweight card stock", and although the say will print on all laser printers, it's my experience that they do not. Only on a laser with a flat paper path.
Mar 02, 2015 | Avery 5376 Perforated Business Card
What is the heaviest paper that you can use on a hp4600dn laserjet . I am looking to print out cards
It depends on the tray. In Multipurpose Tray 1: 16 to 53 lb bond (60-200 g/m2) media. The other tray(s) (depending on model) can only take 16 to 28 lb bond (60-120g/m2) media.
I hope this helps.
May 21, 2010 | HP LaserJet 4650 Color Printer Manual...
Paper goes through tray 1 the image prints landscape on portait
Try placing the business card sheet in the main paper bin instead of the manual feed or adjusting the print orientation from Portrait to Landscape or vice versa.
Sep 25, 2009 | Computers & Internet
Message "card slot not initialized
The HP Color LaserJet 4650 printer also has three flash memory card slots for printer firmware, fonts, and other solutions. The HP Color LaserJet 4610n does not include any available flash memory card slots.
■ The first CompactFlash slot is reserved for printer firmware.
NOTE Use the first flash memory card slot for firmware only. The slot is marked “Firmware Slot.”
■ The two additional CompactFlash memory slots in the HP Color LaserJet 4650 printer enable the user to add fonts and third-party solutions, such as signatures and personalities. The slots are marked "Slot 2" and "Slot 3."
--- These card slots are located inside the Formater unit. Most likely you either are missing the firmware card or it's defective.
Hope this helps!
good luck!
Aug 31, 2009 | HP LaserJet 4650 Color Printer
Lexmark won't print on Avery labels
The printer is expecting the label stock to be loaded into the manual feed tray, not the regular paper tray. If it does not sense anything in the manual feed tray it will not continue. If you are loading the stock in the tray, it may need to be pushed further into the try to trigger the sensor.
Jul 05, 2009 | HP LaserJet 4650 Color Printer
Problem with printing business cards with HP Lasterjet 1320
If the cards are getting stuck in your printer, you first need to make sure the cards are rated for laserjet. If they are, then many times the cards don't like going through the curves of the machine. I would set them to feed from the tray on the front, which should be tray 1, and I would select them to eject out the rear of the printer, which you should be able to accomplish through the print drivers depending on what software you are using to print them.
Please let me know if you would like further assistance with this matter. Thank you.
Mar 23, 2009 | HP LaserJet 1320 Printer
Hp laserjet 4650 crumples leading edge of paper
When you open the paper tray assembly you will see that on each side there is a silver bracket on each end of the paper tray that the paper sit under. You can bend these away from the paper in a sidways just a little and that will fix your problem. The paper is hanging on these plates as it feeds and is bending the paper as it feeds.
Oct 01, 2008 | HP LaserJet 4650 Color Printer
Printing business cards
Feed sheets through front manuel feed slot.
base tray is mainly for up to 90grm paper,anything heavier
can feed for a time but tends to fault.also try and clean the
paper pick up rollers regularly.
May 20, 2008 | Brother HL-2040 Laser Printer
Print Garbage
The reason your pictures come out dark and grey is that you have not set the paper thickness on your printer. On the back you will see a flip switch change this setting then feed your business card sheet in there and see the diffrence. Plus make sure your settings for your printer are set for a thicker paper this will fix your problem. Make sure though when done printing your cards that you set it back to the normal or you will have problems printing regular paper documents.
Sep 15, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP LaserJet 4650 Color Printer Logo
226 people viewed this question
Ben Johnson
