Question about Dell Dimension 4600 PC Desktop
Dell crashed with cd still in drive - how to remove disc?
Left a disk in the drive overnight with computer left running.  Next morning computer not working, cannot eject disk, turned off computer and when turned back on, on/off button just flashes yellow - nothing works.
    Novelist:
  • 166 Answers
To manually eject a CD look for a little pin hole usually below the cd drawer. Unfold a paper clip and stick it in there and push. The cd drawer should come out a little. Also sometimes you can hold down the cd eject button as the computer is powering up and it might eject.
The flashing yellow light seems to be a more serious problem. Do you have any ABCD diagnostic lights on the rear of the machine?
It may be either a bad power supply or bad motherboard (capacitors bulged or leaking). You can visually inspect the motherboard by looking at the capacitors (look like little tiny soda cans). If any are bulging or leaking any fluid then they are bad. They should be perfectly flat on top. If you feel adventurous you can take apart the power supply and look at it also. Just make sure it is unplugged.
Posted on Mar 12, 2009
How do I copy a data CD?
jax0696,
Below are the steps to make a data disc.
Step 1
Insert the CD you wish to copy in your CD/DVD drive.
Step 2
Click "Open folder to view files using Windows Explorer" on the AutoPlay pop-up.
Step 3
Click anywhere in the right-hand panel and press "Ctrl" and "A" to select all the files and folders.
Step 4
Press "Ctrl" and "C" to mark all files for copying.
Step 5
Click "Desktop" at the top of the left-hand folder tree.
Step 6
Click "New folder" at the top of the window. Type "TEMP," and press "Enter" twice to rename and access the folder.
Step 7
Press "Ctrl" and "V" to copy the CD to this temporary location.
Step 8
Eject the data CD when copying is completed and insert a blank recordable CD.
Step 9
Press "Ctrl" and "A" to select all files in the "TEMP" folder. Click any file and drag them on top of your CD burner in the left-hand panel.
Step 10
Click "With a CD/DVD player" in the "Burn a Disk" dialog box that pops up. Click "Next."
Step 11
Right-click the CD burner and select "Burn to disc."
Step 12
Enter a disc title or keep the default one. Click "Next" to copy the files.
Step 13
Right-click the "TEMP" folder, hold the "Shift" key and select "Delete" to remove temporary files and bypass the Recycle Bin.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 20, 2013 | Dell Studio Hybrid Desktop Computer
Dell inspiron 600m cd/dvd code 19
ac7h,
Tell me what driver you downloaded, AND how you installed it?
http://www.dell.com/support/drivers/us/en/19/Product/inspiron-600m
Removable Storage
The method is to;
1) Click on the blue Download File to the right.
2) On the next page under the bold subheading - Choose Download Method, make sure there is a green dot in the small circle, to the left of -> Single-file download
If not; click in the small empty circle to the left of Single-file download
Now click on Continue in the blue oval.
A small window will come up.
Make SURE there is a Green dot in the small circle, to the left of -
Save File.
If not; left-click in the small empty circle to the left of - Save File
Go below in the window, and click on OK.
A small download window will come up.
Allow the file to fully download, then DOUBLE-click right on the file name.
To the far left in the next window click right on - Extract all files
At the bottom of the next 3 small windows, click on -
Next, Next, and Finish.
If you are not asked to restart your computer do so.
(Start > Turn Off Computer > Restart)
When Windows fully loads again, you should get a pop-up out of the system tray, "Found new hardware device"
And perhaps another one, "Found xxxxx CD/DVD drive"
No?
Wait a few minutes, let Windows run.
Turn the computer off normally.
WAIT 1 minute, turn the computer back on.
Still no?
I suggest then that the optical drive is bad. (CD/DVD drive)
One screw removed from the bottom, (ALL power removed), then slide the CD/DVD drive out to replace,
http://support.dell.com/support/edocs/systems/ins600m/en/sm/index.htm
http://support.dell.com/support/edocs/systems/ins600m/en/sm/upgrades.htm#1019383
http://www.discountelectronics.com/category?product_model=134&category=1&product_type[11]=11
Optical drives are a mechanical device, and rated in hours of usage.
Eventually they wear out, and go to the great optical drive graveyard in the sky. (What?)
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 23, 2013 | Dell Inspiron™ 600M PC Notebook
Windows vista crashed. changed bios to load xp. worked. old files on hidden drive. problem is cant connect to internet. driver files on hidden drive. Now what? Try to find driver and load it?
Patricia,
Left-click on Start, then Right-click on My Computer.
Left-click on Properties at the bottom of the list.
Left-click on the Hardware tab.
Left-click on Device Manager.
Once Device Manager has fully loaded left-click on the + sign, next to Network adapters.
What Ethernet chipset are you using? Intel, or Conexant?
http://www.dell.com/support/drivers/us/en/19/Product/dimension-1100
Communications (6)
A) Intel - Driver 9 /5/ 2006
B) Conexant - Driver 10/ 21/ 2005
Network (3)
A) Intel - Driver 12 / 1 / 2005
If you have an Intel chipset suggest you download AND install both Intel driver files listed above.
Burn to a CD disk. Put it in your optical drive of the needed computer. Go to My Computer, and DOUBLE-click on the drive letter, of the optical drive with the CD in it.
DOUBLE-click RIGHT ON the file name.
Follow the instructions of the Installation Wizard.
(Just click on Next, Next, and Finish)
Driver: Small piece of software that allows the Operating System to communicate with a device.
Windows XP is the O/S, the ethernet chipset is the device.
When asked to restart the computer - No.
Turn the computer completely off, then after 1 minute turn it on.
(Hard Start)
Still no?
Ethernet adapter card is shot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3350631&CatId=200
Regards,
joecoolvette
Sep 27, 2012 | Dell Dimension B110 PC Desktop
How to eject a cd in a dell XPS m1330 when the hardis has crashed and the disk inside isn't a operatindg system disc
Straighten a paper clip and insert it into a tiny hole below the CD drive tray. Push the paper clip gently into this hole and the CD tray will pop out slightly. Pull the tray out to the fully opened position so you can remove the disc.
Dec 28, 2011 | Dell Computers & Internet
How do I format a 4xto10x hp cd-rw disk? I have a hp pavilion XT973 and am running windows XP home edition.
Hi garyandjeri
Under Windows XP , you need a third party software to format your cd-rw disks like Roxio or Nero .
Best regards ,
fanaudi .
Apr 18, 2011 | Computers & Internet
My burner on my dell e 5400 wont let me play or burn disc what can i do you can reach me at chuckspolishing53@yahoo.com
A) Clean the optical eye of the CD/DVD burner. If the laser optical is dirty it won't read disks.
The laser optical eye is located in the bottom of the CD/DVD drive.
You can,
1) Turn the computer on, open the CD/DVD drive tray, and then turn the computer off.
Unplug the computer from power.
Use a can of compressed air for computers, and spray towards the bottom.
After you are satisfied the optical eye is clean, let the computer sit for 3 minutes.
Then plug into power.
Open the drive, try a disk.
2) Use an optical cleaner disk. The disk usually has small brushes on it, which you are to properly apply a few drops of cleaner to.
Then the drive tray is closed, and the disk does it's job.
There are many variations of disk cleaners, the above is just one example.
B) You may have driver problems.
A Driver is a small piece of software that the Operating System uses to 'communicate' with a device.
{Windows XP is one example of an O/S. A CD/DVD drive is one example of a device}
Sometimes Windows is a 'funny animal'. Files tend to be corrupted. A Driver file may be fragmented.
You have to 'slap Windows around' a little bit.
1) Left-click on Start, then Right-click on My Computer. (Windows XP)
2) Left-click on Properties at the bottom of the list.
You are now looking at the System Properties window.
3) Left-click on the Hardware tab at the top.
4) Left-click on Device Manager in the middle.
5) When Device Manager loads, left-click on the + sign next to > DVD/CD-ROM Drives.
6) Right-click on the drive's name.
7) Left-click on Uninstall.
A Microsoft 'squawk box' will come up.
"Warning, you are about to uninstall this device, ya-da, ya-da"
Click on OK.
(It is Ok)
8) Now close all windows, go back to your desktop screen only.
9) Turn your computer off. WAIT 1 minute, then turn your computer on.
After Windows loads you should see a pop-up of of the system tray at the bottom of the screen,
"Found New Hardware", and perhaps another pop-up after that, "Found XXXXXX CD/DVD drive"
If your CD/DVD drive doesn't work now, I suggest it's tiem to buy a new one.
Mechanical devices in a computer are rated in hours of usage, and your optical drive, (CD/DVD drive) may be at the end of it's 'Life-span'.
Example,
http://www.amazon.com/Notebook-Burner-Drive-Latitude-Optiplex/dp/B0042WQ3QC
Dell Inspiron E5400 Service Manual from Dell Support,
http://support.dell.com/support/edocs/systems/late5400/en/sm/index.htm
Click on > Optical Drive on the right side.
Regards,
joecoolvette
Dec 02, 2010 | Computers & Internet
I need to remove a disk from a Sony NEC Optiarc AD-7640S
CD Stuck in Device
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Dec 23, 2009 | Computers & Internet
If the computer is left on overnight, it won't completely boot up in the morning. It makes noises, but does not establish a connection with the monitor. I have to crash it down and turn it on again.
it may happen if the computer gets heated up............den check ur hard disk and make sure there is no problem in it and connections also......... and check ur systems fan also
Jul 10, 2009 | E-Machines eMachines Desktop PC
PC not reconizeing **** drive
Try this, "Start" "run' type in "regedit" then ok, in the left field click the "+" next to "Hkey_Local_Machine" + next to "System', + next to "CurrantControllSet", + next to "Control", + next to "Class", then click on {4D36E965-E325-11CE-BFC1-08002BE10318} then in the right field, right click on "upper filters" then delete, right click on "lower filters" then delete, restart pc. See if this works for ya.
Jun 25, 2009 | Dell Computers & Internet
HELP - think my dvd/cd drive is corrupted
The link below will take you to the Dell download site for the Inspiron 1501. You can download all of the drivers from there.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_1501&os=WW1&osl=en&catid=&impid=
Download the BIOS flash and run it first. Next go to the Device Manager and uninstall the CD-ROM device. Run the driver for the CD to re-install it. Install any other device drivers that you downloaded. When you have them all installed, restart the laptop.
Good luck and please let me know how it works out for you. Especially if you need further assistance.
~ Spoem
Apr 01, 2009 | Dell Inspiron 1501 Notebook
Dell Dimension 4600 PC Desktop Logo
122 people viewed this question
Alun Cox
