Question about AKG Perception 120 Microphone
How would I go about hooking this mic to a Toshiba laptop? What would I need?
I'd like to hook this mic to my laptop to record, not sure exactly how to do that though.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 71 Answers
You will need an external mixer, interface, or phantom power supply.
Posted on Feb 06, 2014
Background noise on vocal track
There is no doubt that sound on PCs and laptops can be a pain, and I have had to run a mixer output through the mic socket before now, such is the insensitivity of the PC's inputs. But you have done this, which implies that the mic input is not being connected to the sound system. You should have some controls of the way the sound is connected - try the Control Panel (assuming you have Windows) and opening up the sound applet. You won't get anything through Audacity etc., until the system is delivering. Sorry I can't be more specific.
Dec 28, 2013 | Computers & Internet
How do you find a dvd recorder that does not need and external tuner? Does the new tv's have a tuner that you can use with the current dvd recorders
U have cables or satallites tvs services hook up.U can record VHS tapes and used any DVD/VCR recorder machines hook up.Because the pay services does convert the signal back to analoge tv signal so u can record VHS tapes.
May 12, 2011 | Toshiba DVR620 DVD Recorder/VCR
My mircophone is broken? dont have money to fix? any cheap ways to still use
WOW this is an expensive camera, I would first HIGHLY recomend spending the money and send it to a good electronics or camera shop and have them fix it.
If this is not an option here are a couple or things you can do. Since this is a higher end camera it
should have a mic jack, if so just hook in a good microphone and it should work fine.
A couple of words of warning before tying the next solution you could permanetly mess up your
cameras sound. While this method theoretically possible, some companies intentionally make this
very hard. Often companies will use hair thin wires or wires that are so short thier is no way to
patch into them. Also, since this description doesn't use standard hardware you should disclose
this repair to anyone who might wish to buy the equipment if you decide to sell it. Also, the mic
that I've suggested may not be as good of quality as the original Sony. You can use
any mic of about the same size so long as it has wires to tie into.
If your not real familiar with electronics get a buddy with some experience repairing electronics to help.
If your really adventurous, you could take the mic assembly apart and put in a new mic. Just get a good compact mic like a KOSS M5 and splice off the end then shave the wires. Then carefully
take the mic assembly on you camera apart look for a small disk made of two magnets an a
fillament with 2 wires disconect the wires from the disk and hook them up to the shaved wires
from the KOSS microphone (one wire from a lead the other to the ground of the KOSS microphone). The KOSS mic will have 3 wires two sources/leads and a ground you might have to play around with it to figure out the wires and get it working properly. If your mic assembly has 2 mics figure out which wires are the lead by hooking them up one at a time (to the wires that originally were hooked to the internal microphones) with the ground on the other wire and trying them. Once you figure out which are the lead wires hook them each up to the old mic wires and take the other side and hook them both up to the ground. once you have it all wired back up and any splices insulated (elecrical tape should be fine) you should be able to re assemble the mic with the new microphones installed.
If the mics for the camea are intergrated into a circuit board the same method will work but
the old mics will need to be desoldered and the leads from the new mic will need to be soldered
where the old mics were. If this is the case get a buddy with some experience with electronics to help you.
Method three use an external recorder. For this method just record the sound with another external
device like a digital voice recorder then use an editing program like Sony Vegas to add the sound to your video. The hard part is syncronization. A clicker may help create sound tags to align the video with the audio with the sound.
May 04, 2011 | Sony Handycam DCR-VX2100 Mini DV Digital...
Iam having probloms geting my microphone to work and having a problom hooking up my speakers
this model needs to be hooked up to an amplifier for speakers to work..it has no audio amplifier inside...as for the mic's..you'll need to make sure you have the mic inputs that you are using selected in the setup menu..there are the xlr{3 pin} connectors and the 1/4" connectors..check the setup
Jan 08, 2011 | Tascam 2488 Portastudio Multitrack...
Webcam recorded audio have interferance
make sure you only use 1 mic .if that dont work try pluging in a diff mic. most laptops have built in mic's it might be bad disable it in control panel and use new mic
Oct 07, 2009 | Toshiba Satellite A135-S2386 Notebook
Scratchy mic noice
try to reduce sensitivity of your mic if you can or simply reduce lever of recording which at the same time should reduce sensitivity. ..or get yourself one of cheap logitech mics and record through them
hope this helps
peace
Jul 30, 2009 | Toshiba (P000257700) Microphone
How to connect mixer an amp to laptop?
How is everything hooked up?
Mic to Mixer, and Mixer to Laptop? Or is your mic connected directly to your laptop?
To do this properly, you will need a secondary audio input device of some kind that accepts line level input. Microphone inputs are intended for low level signals, and are not going to accept the input form a mixer properly. (you can get it to work, but it will generally be distorted)
There are various USB or PCMCIA audio input card options that aren't too expensive. Once you have that, you would need to route your music and microphone through your mixer, and the output of the mixer to your audio input device.
Mar 20, 2009 | HP Pavilion dv9000z Notebook
AKG Perception 120 Microphone Logo
64 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Vito Vacirca Jr.
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
