Question about Whirlpool Refrigerators
Gs6shaxms00 How to tighten doors on side by side
Oven door handle one side not attached to door other side loose
look around the outer edge of the door a few screws hold the 2 halves together caution do it on a flat surface as the glass can fall out .
Sep 01, 2016 | Neff Ovens
Tighten door handle on Whirlpool Conquest refrigerator
You need to remove the handle befor eyou can tighten the mounting bolt behind it. T remove the handle just grab it and yank UP quick and hard. The handle will unclip and release, then you can tighten the bolt down and re-install the handle.
How strong do you have to be?!!! Trying that and it won\'t unclip. Not sure how hard to try--or will you break something?!!
You have to pull up pretty darn hard with a jerk. That is how both handles are removed on these conquest refrigerators
Sep 01, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Loose door handle thermador refrigerator
I'd appreciate thoughts on how to tighten THERMADOR not another brand refrigerator door handles. Model: KBUDT4860 A02 which is a stainless steel side by side 2 door freezer / refrigerator. Thanks.
tried the other suggestions above and damaged the surface.
Jan 16, 2013 | Thermador Refrigerators
Whirlpool gold gS6SHAXMs00 fridge not cooling on right side, but cooling in freezer side. Also, digital readout is blank and it stays about 60 degrees in the refrigerator section. The light bulb in the...
You have a bad control board. The control board is not hard to replace. It is located in the bottom of the unit inside the plastic control board housing on the back of the refrigerator. Just make sure the power is disconnected and the wires are placed on the new board where they were on the old board. Here is the control board to order.
The part comes with a 365 day, any part, any reason return policy.
Regards,
Richard Roth
http://appliancecafe.com
Nov 06, 2012 | Refrigerators
I have 3 door knobs on outside doors that are loose and need to be tightened. the knobs have come completely off sometimes when we go out the doors. how do I tighten the knobs so they are not loose?
On the inside side of the door knob, there is a decorative plate. Depending on which model door knobs you have, it is held on with a "set-screw" that might require an allen-wrench (looks like an 8-sided tool; usually in an L-shape), or just simply a screw driver, to loosen and remove it. Once you take the decorative plate off, there will be two very obvious screws that hold both sides (inside and outside) of the door knob together. Tighten these screws to tighten your knobs, then put the decorative plates back on again.
Feb 27, 2011 | Kwikset Professional Door Lock...
Door handle is loose, how can i tighten it?
Might have to remove the inner panels to tighten the handle inside the door .
Remove the inner linings toget access to the inside of the door .
Sep 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The post between the doors of my side by side refrigerator is hot. If you open the doors and put your hand on the outside,it is hot. I cleaned the bottom of the frig last nite and noticed the cooling fan...
The fan motor needs to be replaced . Pt # W10124096 , is the part number for the condenser fan motor ( compressor cooling fan ) . It costs about $ 100.00 for the part , but is easily replaceable ( 2 or 3 screws ) .
Nov 20, 2009 | Whirlpool Refrigerators
26 side by side with ice maker doesn't work
The water control valve can get clogged or fail. Follow the line from the supply( did you check for filters there?) to the bottom of the fridge. The valve may be just like the one on a washing machine. It has a wire filter in it too. Test it for flow, unhook the pipe to the ice maker and see if water comes out of it when it is energised. I made a test energiser out of a power cord with the same connectors that the valve has.
Apr 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Adora Side by Side Loose Handle
do the covers pop off to tighten screws on the handles
Oct 21, 2008 | GE Adora (DSF25KGTBG) Side by Side...
Handle loose on Refrigerator
To fix this you will need an Allen wrench small one there are 2 set screws on the inside part of the handle (on side toward the center) you wil need to tighten these to fix your problem
Feb 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
19 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
