Question about Epson Office Equipment & Supplies
My epson DX4400 prints apparent nonsense instead of the document. Also it doesn't spool through until you cancel the print job it prints the same stuff over and over in the top corner.
  • fiend_85 Mar 12, 2009
    I tried that and it didn't work. Thanks though, have found it prints PDFs so am just converting things I want to print into that format.
  • Epson Master
  • 19,396 Answers
When printer prints a set of character that has nothing to do with the docuument, instead of the current document, then there is a logical problem.
This is usually due to a corrupted driver software, only in exceptional occasions you have a printer with a faulty control board.
To start unplug printer USB, empty the printer cue from control panel, replace USB cable, and test a different USB socket.
If that did not help, then download and reinstall printer driver software from the link below:
Epson Stylus DX4400 : Drivers & Software
If reinstalling the software dod not work, and all the above did not help, then the printer is faulty.
Posted on Mar 12, 2009
Cancel print job with a linux operating system
HI,
You've sent a print job to your printer and the green light is blinking, but the printer is not printing. The light blinks for a very long time.
The blinking light indicates that the printer is recieving your print request and will print shortly. If the document you are attempting to print is very large or contains many graphics or images, the printer must spool this data into its memory before printing. This can take quite a bit longer than usual. PDF files are notorious for taking longer than other document types.
In this case, it is best to wait a period of time before taking action. Give the printer 10 minutes and see if it prints.
If it does not print within this window of time, do the following.
1. In the bottom right corner of your screen, you will see a small printer icon. Double click on this icon to open the printer job menu.
2. You will see your print job located there, with other information, including its status.
3. Select the job by right clicking on it and select Cancel.
4. The job should cancel itself.
5. Unplug the printer, removing all power and leave it sit for a couple of minutes.
6. Plug the printer back in and allow it to go through its start up phase until the "Ready" indicator light is solid. This indicates that the printer is ready to recieve jobs.
7. You may now attempt to print again.
Thanks,
HP Printer Support
Jul 16, 2014 | HP Office Equipment & Supplies
A print job, although cancelled, doesn't leave the printing list.
Please try this approach:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Feb 24, 2012 | Lexmark X1270 All-In-One InkJet Printer
Printer model: HP Laserjet M1522nf. When we give print it says printing but we could not get the print document
I assume you have no problems using your printer until today.
If that is true, then you may want to cancel all jobs in the
print queue first. The easiest way is to do the followings:
Open Notepad and type the following lines:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
Save it in your root directory as: C:\DeletePrintJobs.cmd
Create a shortcut for it and move it to your Desktop
Now everytime you have print job(s) that got stuck in the print queue,
go to your desktop and Double Click on the DeletePrintJobs.cmd
It will clear all pending print jobs in the print queue and allow you to
print new jobs again.
Jul 18, 2011 | HP LaserJet M1522nf Multifunction Printer...
Printer will not print, job sits in queue until I switch off, when I switch on job prints.
Try this:
>Start menu
>Printers and Faxes
>RT click on the printer > choose properties
>Click on the advanced tab and confirm that the "start printing immediately" is slelected along with "Print spooled document first" and Enable advanced printing feature.
> Click okay try printing a test page
If this does not work then....reinstall your printer driver
Jun 15, 2010 | Epson Stylus Photo R300 InkJet Printer
I tried to cancel printing jobs once in progress and had no succe
Printers will hold the documents in the memory of the printer. Windows holds the documents until they are received by the printer.
Go to the printer and cancel the job, then open the printer by double clicking on it in Printer and Faxes (if in XP) and cancel the document from the menu while the document is highlighted. (document, cancel)
A trick I have used is to remove the paper from the printer, wait until the last sheet is printed and turn off the printer. Windows will pop up with an error that includes cancel the print job.
Jan 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Prints nonsense instead of print job
turn off ur printer disconnect it frm computer and check ur computer where there is pending printin left by you,if yes cancel all the pending printing and connect ur printer back to computer and turn it ON,u shall not face the problem.
Nov 29, 2009 | Office Equipment & Supplies
How to cancel a print job that has multiple copies selected for the print job
Click Start
Click Control Panel
Click Classic View
Click Printers
Double-click the active printer to open the "job-queue" window
Select the file to be cancelled
Right-mouse click on the selected file, and choose cancel.
Nov 17, 2009 | Microsoft Windows XP Professional for PC
Unable to cancel print queue
You can cancel a print job from within Windows by going to Control Panel -> Printers and double-clicking on the appropriate printer. Right-click the print job you want to cancel and select Cancel from the context menu. Anything already sent to the printer will continue to print.
You can also cancel a print job from the printer by pressing Cancel on the control panel. This applies to whatever is currently printing.
(You may want to remove any paper from the paper tray first.)
Clicking the cancel print icon stops the job from continuing to spool, but whatever is still in the printer's memory will continue to print until exhaused or the job is cancelled from the printer's control panel.
Apr 14, 2009 | Office Equipment & Supplies
When printing documents from my PC documents always sent to queue
Go to control panel, printers. Set your defaults there. You probably have spooling enabled. Uncheck it and your print job will go to the printer, rather than to spooling. Spooling is like rolling the print job up on a spool until the whole thing is processed, then unwinding it to the printer.
Feb 17, 2009 | Lexmark X3550 All-In-One Printer
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
292 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
