Question about Briggs & Stratton Garden
Turns over then dies
I changed the plug but problem continues
  • Briggs & Str... Master
  • 7,482 Answers
Hi Brian
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and cranking the engine or by pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 23, 2013
Hi my TV bush 50/211f not turning on still standby red light, I m change supply board still problem today I am changing main board and turn on. light change to Blue 10 sek back red and again
try this Press and hold the on/ off button Whilst holding unplug the plug from the wall Continue holding for 30 seconds Plug in the plug whilst continuing to hold the on/ off button Continue to hold for a further 30 seconds And the screen should come back on, good luck
shaun
Mar 11, 2017 | Bush Televison & Video
Changed the oil and plug wires now when it gets warm it starts to sputter and wants to die. it eventually dies. it starts back up but continually dies til the destination.
Change your fuel filter. If that doesn't help, have your fuel pressure checked. Sounds like a fuel problem, but may be elsewhere. I would start with the fuel filter.
Nov 13, 2011 | 1995 Toyota Corolla
Saw starts then dies. Changed fuel ine soaked carb
Check the fuel filter, air cleaner and muffler for plugging. Was the carburetor disassembled when soaked and did you use compressed air to blow out all passages? If the carburetor jet screws have been moved, preset them as follows: Turn both H and L screws CW to stops (lightly), then back out CCW each screw 1-1/2 turns. Start the engine and allow to warm up. Pull the throttle full on and adjust H CW until the engine speeds up somewhat but 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L CW until the engine runs fairly well, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that chain stops turning, but the engine continues to run. Hope this helps!
Mar 30, 2010 | Garden
Chainsaw will run for 10 minutes then dies,will not start again for about an hour. It is a 345
When it dies, remove the spark plug and make sure that it continues to make blue sparks. If nothing, try a new plug. If still nothing, then the ignition module is likely dying from the heat--replace it. If sparks continue, then try spraying starting fluid into the plug hole, replace the plug, and try to start. If it pops once or twice, then suspect a fuel delivery problem. Try loosening the fuel cap for a moment, then try to start. If it runs again, suspect a plugged fuel tank air vent. Try cleaning the engine area with compressed air, particularly behind the starter mechanism. Hope this helps!
Mar 19, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
2000 ford excursion starts and then dies immediately. Later, it starts and continues to run fine.
CHANGE PLUGS,WIRES,CAP&ROTOR CHANGE THE ELECTRIC COIL,REPLACE THE FUEL FILTER
Oct 29, 2009 | 2002 Ford Excursion
1987 cutlas ciera 3.3 v6, sputters and idle poorly before dying
locate the ECM under the dash on the right side in the side kick panel, gain access.do not remove it,light tap on it while it runs see it the motor changes.you probably need another ECM.I would have to have more info to help you better.
Jul 23, 2009 | 1987 Oldsmobile Ciera
I have a toshiba laptop, and in the last few weeks something weird started happening. When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries,...
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
Jan 04, 2009 | Computers & Internet
Garden Logo
132 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
