Question about Sony VAIO VGN-FJ270/B Notebook
Tip Top where do you pot your code in
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 114 Answers
Where it says enter code here
Posted on Apr 24, 2013
UNSCRAMBLE THESE LETTERS TO MAKE 3 WORDS
Did you mean 3 words which make sense together? How about 'rocket lab pilot'
If they don't have to make sense together there are many possibilites
A Bitter Pollock
A Brooklet Clipt
A Blotto Prickle
Cab Kite Trollop
Cab Tike Trollop
Cab Triplet Look
Cab Plotter Kilo
Crablike Lop Tot
Crablike Pol Tot
Crablike Plot To
Crablike Lot Top
Crablike Lot Opt
Crablike Lot Pot
Tieback Poll Tor
Tieback Poll Rot
Tieback Poll Ort
Tieback Roll Top
Tieback Roll Opt
Tieback Roll Pot
Tieback Troll Op
Tieback Toll Pro
Balletic Pork To
Blacker Pilot To
Blacker Toil Top
Blacker Toil Opt
Blacker Toil Pot
Blacker Lip Toot
Blacker Pi Lotto
Blacker Pit Tool
Blacker Pit Loot
Blacker Tip Tool
Blacker Tip Loot
Backer Pill Toot
Backer Pilot Lot
Backer Toil Plot
Backer Lip Lotto
Backer Tilt Loop
Backer Tilt Polo
Backer Tilt Pool
Bracket Pill Too
Bracket Oil Plot
Bracket Pilot Lo
Bracket Toil Lop
Bracket Toil Pol
Bracket Lip Tool
Bracket Lip Loot
Bracket Lit Loop
Bracket Lit Polo
Bracket Lit Pool
Bracket Poi Toll
Cable Kilt Troop
Placebo Ilk Tort
Placebo Ilk Trot
Placebo Kilt Tor
Placebo Kilt Rot
Placebo Kilt Ort
Back Little Poor
Back Politer Lot
Back Loiter Plot
Back Toiler Plot
Back Peril Lotto
Back Triple Tool
Back Triple Loot
Back Litter Loop
Back Litter Polo
Back Litter Pool
Back Tiptoe Roll
Back Tie Trollop
Back Rootlet Lip
Back Petrol Toil
Back Plotter Oil
Back Tooter Pill
Black Politer To
Black Polite Tor
etc etc
Dec 14, 2016 | Miscellaneous
Why is stove top displaying symbols not recognizing pots? Had stove 6 weeks, pots are correct and been used on this stove. Displaying on all 3 cooking areas.Can I correct it or is it faulty?
lets review this
please advise readers
maker of cook top so they can find the user manual
model or how old helps also
its not a gas cook top
you have the right type of designed pots for that cook top
but you get no heat radiating to the pot base
when pot is in contact with the heat area
Aug 17, 2016 | Cooktops
I have a pride go go ultra x scooter... I purchased it, and it had no top dash at all... I put a new throttle pot, and a whole new dash assembly... It runs great... Then I turn the speed pot to fast......
7 flash code is: Throttle control fault.
1. Check wiring for open/short circuits.
2. Check the throttle set-up.... The ohms should be very close to each other when placed checking forward and reverse on set up.
Aug 24, 2014 | Pride Mobility Products GoGo Ultra X...
How do you clean a metal coffee pot?
To clean your metal coffee pot you can pour boiling water into the pot and add a few drops of liquid dishwasher cleaner. Leave it to sit overnight and in the morning tip it out and rinse it out carefully before you use it.
Feb 25, 2013 | Home
How do I use vinegar to clean my coffee pot? I heard it was a good method but have no idea what to do with it.
For a 12 cup coffee maker. Fill the coffee pot (the part that holds the water) with 6 cups of vinegar and then top up with water until you reach the line. Now turn it on as if you were making regular coffee. Once the hot vinegar has come through, pour it into the water cavity and run the cycle again.
Now you can tip the vinegar out and clean out the coffee pot with soapy water. Run another cycle but with plain water this time and after that you should be able to use your machine without any leftover residue from the vinegar.
Feb 25, 2013 | Home
E01 code on west bend slow cooker - how can I fix
Your crockpot is giving you an error code EO1. Now you need to know how to get the code off of your crockpot so that you can use it.
Here is a tip that will tell you how to fix the EO1 error code.
West Bend Crockpot EO1 Error Codeheatman101
Jan 14, 2011 | West Bend 84496 6-Quart Slow Cooker
Bunn coffee drips slow
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
1) Unplug the NHB
2) Remove accessories like the pot and basket
3) Bring NHB over to the sink
4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
5) Place the top cover and flow stopper aside.
6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
8) Return the NHB to the upright position in the sink.
9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
14) Tip the unit as in step 7 to drain the tank water out.
15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
16) Repeat steps 13 and 14 once.
17) Repeat steps 11 through 14 three times.
18) Clean the pour reservoir cover, swing lid and flow stopper.
19) Put the flow stopper back in place.
20) Attach the top cover.
21) Clean the exterior of the NHB.
22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
23) Turn the boil and warmer plate switches on.
24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
26) Allow water to drain from brew spout until it stops draining.
27) Empty pot.
28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
29) Clean brew spout diffuser and replace back in the brew hat.
30) Clean the pot, pot lid and brew basket.
31) Wait ten minutes for the water in the tank to boil.
32) Brew your coffee as you normally would.
The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
Apr 05, 2008 | Bunn NHB Coffee Maker
Does not brew a full pot of coffee
1) Unplug the NHB
27) Empty pot.
Oct 29, 2007 | Bunn NHB Coffee Maker
Sony VAIO VGN-FJ270/B Notebook Logo
21 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
