Question about Brother MFC 7420 All-In-One Laser Printer
I want to scan an multiple images and save it to a PFD format.
I have never done it ever and I can't figure it out. I am so frustrated right now. Anything will help. It's a Brother MFC-7420
    Problem Solver:
  • 6 Answers
This was not supported in control center 2. However, it is supported in control center 3 which you can download from the Brother website.
When our printer was attached to our windows 2000 machine, we could only scan a page at a time and then "print" the scan to a PDF printer. (We use DocuDesk). However, when we upgrade to a Vista machine and downloaded the new driver, the new control center supports PDF and multi-page.
Posted on Apr 14, 2009
Open up the Control Panel for the MFC on your computer. This was installed when you installed the software/driver for the printer when you first set it up. Put the page in the automatic feed, face up, head first. Click on File on the control panel and the sheets should start getting fed through. This instruction means that you are telling the scanner to scan (copy) what you have to an electronic pdf file. There should be a folder on your desktop that is called "scanned files". Once the scanning is complete, you can go to the folder and find the pdf file you just created. I have found that if I scan too many sheets at one time, the file gets too big (like 10MB!) -- keep it small.
Posted on Mar 15, 2009
    President:
  • 2,692 Answers
You , nor anyone else,cannot scan and save as an ADOBY PDF file. To creat a PDF file requires either the ADOBY writting software of another software that saves  in the PDF file format.    Scanners take a picture of what ever is layed on them and copies then by breaking them into  millions of dots and then saving as a picture in a format such as JPEG.   Sorry
  • dragonturtl8 Jan 31, 2011
    With Windows XP, ControlCenter 3 is not an option. As a result, I took the time to call Brother Support and scanning multiple pages from the flat-bed glass to a single file can be done through Scansoft Paperport, a component in the Brother Suite. I'm pasting the instruction from Brother Support below:
    Thank you very much for your inquiry. Our Search Engine found the following Solution from our Solution Database that matches with your Problem description.
    Description of Problem 100000012750
    How do I scan a document into PaperPort 11 SE using the TWAIN driver?
    Description of Solution 200000016388
    To Access the Scanner follow the steps listed below:
    1. Open PaperPort. Click START -> (ALL) PROGRAMS -> SCANSOFT PAPERPORT 11 -> PAPERPORT.
    2. If the Scan or Get Photo panel is not already displayed on the left side of the screen, click FILE -> SCAN OR GET PHOTO. The Scan panel should then appear.
    3. Under the scanner section click SELECT.
    4. Ensure that TWAIN has a check next to it and from the list of available scanners choose the TWAIN driver for your model brother machine. (ex: TWAIN: TW # BROTHER XXX-XXXX)
    5. Click OK. Your scanner should now be listed under the scanner section of the scan panel.
    6. Under Select a Profile you can choose from several pre-configured scanning profiles:
    B
How to change scanning from picture to pdf
once you have scanned the picture and saved it . right click on the picture icon. click edit. it should take you into a editing tool like paint . then click file . save as and then the bottom option you can change it to save as a pdf or png or jif, anything your heart desires
May 05, 2011 | Computers & Internet
How to scan multiple images into one pdf document
after scanning one page .. do not save the page but choose "add another image /page option " and scan accordingly.. and save the entire document after you are done with the scanning of all the pages.
Sep 30, 2010 | HP PhotoSmart C4280 Laser Printer
Want to change default scan format from .tiff to .pfd on Cannon Imagerunner 6570?
Additional Function>Communication Settings>TX Settings on left>Edit Standard Send Settings>File Format>Select PDF or Tiff>OK>Done>Done>Done
Jun 02, 2010 | Canon IMAGERUNNER 6570 Copier
The drop down menu does not give the option to have the picture scanned/saved jpg format which is necessary for certain sites such as shutterfly
Please follow the steps below to scan and save a Multi-Page PDF with Epson Scan.
1. Launch Epson Scan from your START, (ALL) PROGRAMS, EPSON SCAN.
2. If prompted, select your scanner model. Epson Scan will now launch.
3. Click the drop down arrow next to SCAN, select FILE SAVE SETTINGS.
4. Select PDF for IMAGE format. Click OK.
5. Click SCAN. Click OK to proceed (if prompted).
6. Once the image has scanned you will be prompted to click ADD PAGE or DONE.
7. Click ADD PAGE to scan more documents.
8. Once you have scanned all your documents, click DONE.
9. Your documents will now appear in the EDITING PAGE window. Click OK.
10. The multi-page PDF is now created.
Jan 16, 2010 | Epson Perfection 4490 Photo Scanner...
How do I scan multiple pages into one document
When Save as PDF file is selected: The Save as PDF file dialog box opens. Specify the file type, file name and destination folder.
Select from the following PDF file types:
PDF When multiple images are selected, each image is saved as a separate PDF file. PDF(Multiple Pages) Multiple images are saved in one PDF file. PDF(Add Page) Selected images are added to a specified PDF file. The images are added to the end of the PDF file. You cannot rearrange pages of the PDF file to which images are added.
Oct 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Scan a Multipage Document into a Single File
My scanner is a Cannon but the basic jist of what your trying to do is universal. You need to open up the software for the scanner and look for an icon that says scan to file. It sounds like you have already done this. If so you are very close in the step I mention to the setting you need to scan multiple pages into one PDF file. Once you find the setting to scan multiple pages be sure to not click "FINISHED" until your last page is scanned in.
LB
Nov 30, 2008 | HP ScanJet 2400 Flatbed Scanner
Epson 4490 Photo - multiple PDF pages
Hi. Yours probably scans as soon as you have a document in and you double-click, right? I went through this. Double click on the Epson Icon. Make sure the mode preference at upper right is changed to professional. It may start scanning and you have to wait until it's finished to scan again. When you start in professional mode, it brings up a rectangular menu--you probably didn't see this one before (I didn't before changing to professional mode). Now press scan. This gives you a "file save" choice. Chose the location you want. Under the location choice is the Choose Document type option--this is the second key--save as PDF. Now it will bring up that add a page, edit or save file. Professional mode, save as PDF.
Dec 15, 2007 | Epson Perfection 4490 Film / Flatbed...
Epson stylus photo RX580
When you see the File Save Settings window, you need to select the location, name, and format of the scanned image file you want to save.
  1. In the File Save Settings window, specify the file folder in which you want to save your scanned image. Click the My Documents or My Pictures radio button (Windows XP or earlier versions), or the Documents or Pictures radio button (Windows Vista or Mac OS X).
  2. If you want to select another folder, click Other, then click Browse (Windows) or Choose (Mac OS X) and select the folder. If you want to save your image on the desktop, simply click Other.
  3. Specify a file name prefix with an alphanumeric character string. A 3-digit number is automatically added to the file name, but you can change the Start Number if you like. If you are scanning multiple images at once, each image will receive a different 3-digit number.
  4. Select a file format. Depending on the format, the Options button may be available for making detailed settings.
  5. The check boxes at the bottom of the window give you these options:
  • Overwrite any files with the same name: Select this option if you want to reuse the selected file name and location and overwrite previous files with the same names.
  • Show this dialog box before next scan: Select this option if you want the File Save Settings window to appear automatically before you scan in Home or Professional Mode. If you deselect it, you must click the File Save Settings button to open the window.
  • Open image folder after scanning: Select this option if you want Windows Explorer or the Macintosh Finder to automatically open to the folder where your scanned image is saved when Epson Scan finishes scanning.
6. Do one of the following, depending on the currently selected scan mode:
  • Home or Professional Mode: Click OK. Epson Scan starts scanning.
  • Full Auto Mode: Click OK, click OK again, then click Scan. Epson Scan starts scanning.
The scanned image is saved in the file and location you chose.
For more information click here
Nov 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Brother MFC 7420 All-In-One Laser Printer Logo
1,565 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
