I need Norsmen orientations - Office Equipment & Supplies
Pictures are oriented wrong
you need to put them in seperate files and tag each file for identification..if not the computer will randomly pull out what it wants..
Jan 15, 2014 | PixiModo Reflection 15M 15-Inch Digital...
Change screen orientation
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
b>
Dec 14, 2012 | Dell Computers & Internet
Acer One screen orientation: How do you change it
Hold down the ALT+CTRL keys, then push the up arrow key to reset the screen to the default orientation.
Jan 12, 2010 | Acer Aspire One PC Notebook
Orient watch service
I need vikings orientations
Jan 14, 2009 | Orient Watches
Monitor displaying everything horizontally
Some monitors don't give orientation feedback to the video card to auto change the orientation when you move from a horizontal screen to vertical. what you need to do is get to display properties and advanced settings (right click desktop > properties > settings > advanced > video card settings > orientation) - you should find an option to change the orientation of the display - correct it accordingly. if the settings are not being saved after you restart, you need a video driver update - find it on your manufacturers website.
Jan 13, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Orientation sensor got stuck
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Sep 17, 2007 | Canon PowerShot A95 Digital Camera
29 people viewed this question
k24674
jasbo
jasbo
