Question about Sewing Machines
I want supreme vikings confrantanity orientations
  • Sewing Machines Master
  • 11,722 Answers
Search for:
Make Model manual
Posted on Feb 26, 2018
Iceland our final destination
Posted on Feb 25, 2018
Write your answer...Iceland is our final destination
Posted on Jan 26, 2018
    New Friend:
Write your answer...iceland our final destination
Posted on May 01, 2015
How do you wind a bobbin on a Viking 6570 sewing machine?
Unfortunately, I'm unable to locate a web site or video for this beautiful machine. You can get a user manual from Husqvarna/Viking here:
Husqvarna Viking sewing machine manuals
Service manual here:
Viking Husqvarna Sewing Machine Service Manuals
Not your model, but may be helpful:
Demonstration Video of Vintage Viking 6690 Sewing Machine
viking husqvarna 6440 sewing machine
Aug 03, 2017 | Sewing Machines
I need viking orientation
http://www.husqvarnaviking.com/
Nov 19, 2014 | Sewing Machines
Husqvarna viking sewing machine bobbin
Could the part number be 4011770? I've found the Viking 7 bobbins here: http://www.mysewingmachineparts.com/top-quality-metal-sewing-machine-bobbins-4011770-husqvarna-viking/ . Another site with them is http://www.sewingpartsonline.com/bobbin-viking-4011770.aspx . This bobbin is compatible with the Husqvarna Viking 7, 49, 51, 52, 21 & 21E . It probably will work for other machines. Sears also has them listed as 11770: http://www.sears.com/generic-viking-sewing-machine-bobbins-sewing-machine/p-SPM6124767105?prdNo=1&blockNo=1&blockType=G1 .
I also found these bobbins: http://www.amazon.com/Viking-Metal-Bobbins-5-pkg/dp/B000YZ5QSC . The part number appears to be 1702.
I hope this helps.
(googling Husqvarna Viking metal bobbins found a number of hits.)
Mar 05, 2013 | Husqvarna Viking 1
Viking Husqvarna #1 + - A bobbin was stuck on the winder and I pulled it off. The black metal clip broke and came flying off. Now the machine thinks it has a bobbin on the winder and won't move the sewing...
The black plastic ring must be put back on with it oriented correctly. It can be a bit tricky, but experiment different ways.
Another small part may have come off too. If you can't get it, a Viking tech can do it for you without much trouble.
Jul 10, 2009 | Husqvarna Viking 1
Husqvarna viking 770 bobbin sticks on rewind post
I believe that you mean the bobbin is stuck on the winder. If so, take the thread off of it and it will come off easily.
Wind your bobbin at about 1/2 speed until it gets 1/4 to 1/2 full, then you can speed up. Also, make sure that the presser foot is up if winding with thread through the needle. Always make sure that thread feeds smoothly to the bobbin.
The bobbins stick when you have too much tension on the thread or wind too quickly. They will actually squeeze down on the bobbin winder post. Removing thread generally solves the problem.
Jul 06, 2009 | Husqvarna Viking 1
Bobbin tension on Viking 350 Sewing Machine
Viking bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Mar 19, 2009 | Husqvarna Viking 1
Husqvarna viking 425
Try ebay or contact your local authorized Husqvarna Viking dealer. You can find a local dealer from the Husqvarna Viking website - http://www.husqvarnaviking.com/us/
Aug 17, 2008 | Husqvarna Viking 1
Sewing Machines Logo
528 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
