Tv has gone dark and a shade of green - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,283 Answers
What is the brand name and model number to your PTV? Provide more details please. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you check the site in Timeslide option, which can be selected from the dropdown list at the top left side of the display window, it will make search easy.
Posted on Apr 23, 2013
Vizio 55" Inconsistant Dark Screen
you have to open the back cover to check weather the screen back light need replacement. usually if the lamp is almost black in color it needs replacement. the backlight is covered with metal shield installed at the upper portion and lower portion of the panel of the tv.
Nov 01, 2012 | Vizio VF Televison & Video
My Vizio SV470XVT1A, when turned on has vertical green lines, when playing a movie the lighter shades of color are good but all the dark shades have green vertical lines through them. I am trying to fidure...
All plasma an lcd TVs have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They can sometimes be fixed, but it is a pain. An yes I have done it, and the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Aug 03, 2010 | Vizio SV470XVT 47 in. LCD TV
TV images have gone green
power might be to low for it
Apr 16, 2010 | Toshiba 32HFX71 32" TV
My sony grand wega gives a blue shade on the black background which is the problem
HI, Check the menu set up of the TV. There should be an alignment feature that aligns the blue, red, and green colour projectors. If the blue is out of alignment that is likely why you can see it on the dark backgrounds. The set up normally puts a white cross on the screen and you select each of these colours and then move the cross over the white on with the arrows on your remote. Once all are aligned correctly you shouldn't be able to distinguish between different colours and hopefully this should get rid of your blue shade.
Oct 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Dvd movies have green shade on tv
Check to make sure that *all* the RBG cables are properly inserted into the dvd player. We had the exact same problem for the past year only to discover that the R cable (for red) was not pushed in...hence, all dvd movies had a green hue to them.
Mar 08, 2008 | Televison & Video
Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on amir.dhawan@gmail.com
Dec 30, 2007 | LG Flatron 295LM 22" LCD Monitor
Red/pink shades in dark areas happens only 6ins down from top
Sounds like you have a cap that leaky or a ic thats getting hot,
if you want to try and fix it yourself get a can of freeze it
http://www.chemtronics.com/products/product.asp?id=78
and when the problem appears spray the can on each (ic or cap) part till the problem goes away.
Dec 03, 2007 | LG DU-42PY10 42 in. Plasma HDTV
GREEN SHADE ON LEFT SIDE OF TV
Any TV repair center should be able to run a degauss coil over the unit and see if it's caused by the tube being magnetized. If that doesn't fix the issue then they can install magnets on the outside of the tube to clear that green shading issue.
Nov 19, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Televison & Video Logo
Top Televison & Video Experts
