Question about Mitsubishi SL2U Multimedia Projector
How to check lamp timer
I'm about to buy a second hand Mitsubishi SL2U projector and would like to know how much time is left for the bulb before I buy. Is there any way of checking? I've had a look at the manual and it doesn't offer anything.
    Champion:
  • Mitsubishi Expert
  • 225 Answers
Bulbs do not really have a certain lamp life they only have a lamp timer. You will want to be sure you can get a replacement lamp they can go anytime between 0 and 6000 hours.
Posted on Dec 19, 2013
Shuttle83
  • 1139 Answers
SOURCE: Projector will not project light (Mitsubishi LVP-X80U) LCD Proje.
Hello toma_leonard,
First check your lamp to make sure it is seated properly in the socket.
Then check all of your interlocks (see your manual for locations), these are usually located on any hatches or doors that allow access to the lamp and or fan area. Once you check your interlocks make sure the filter and fan area is clear of dust, (some projectors have air flow sensors), and the recheck the interlocks. Once this is done , If the interlocks are not broken, or the lamp fuse blown, the projector should be working. If not it is the lamp that needs changing.
I know this may be expensive, however these lamps do go bad, as much as we wish they would not.
If you still feel it is not the lamp, have a technician check the voltage levels to the lamp and the levels of the control board circuitry.
I hope this helps,
Thank you,
Shuttle83
Posted on Nov 20, 2008
rylee_smith
  • 8619 Answers
SOURCE: need to find lamp run time
Hi!
In normal conditions and 270W SHP lamp (lamp low mode: 220W); Shut down time: 1500h/2000h (at lamp low mode) and it may vary due to variation in continuous or intermittent usage.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 21, 2009
projdoc
  • 2237 Answers
SOURCE: the projector comes on, shows an image, then shuts off
power supply problem. the capacitors are probably drying out. it takes a boost of power to strike the lamp, and if the power supply can't handle it, it shuts down. replace the power supply.
Posted on Aug 18, 2009
  • 8909 Answers
SOURCE: Mitsubishi SL2u projector: Projector was recently
I suspect the lamp cooling fan. Check the fan for debris or damage. If it were the sensor, it would be showing fault mode and not even start up. Hope that helps.
Posted on Nov 16, 2010
news775
  • 699 Answers
SOURCE: HOW DO I CHECK LAMP LIFE FOR MITSUBISHI SL4SU
If you go into the menu of the projector.
Find the lamp status or info command.
It will tell you the current information.
Please dont forget to vote this answer was helpful and accept my answer.
Many thanks
Posted on Feb 20, 2011
How to know if HC5000 lamp is out
Lamp timer mean nothing in the end its just a light bulb and can go at any time.
Dec 05, 2011 | Mitsubishi HC5000 LCD Projector
How to reset the bulb life to 0 on a sl4su it
hi,
Do the following for reset the lamp hour to zero.
Reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for 5 seconds.
OK
Sep 21, 2011 | Mitsubishi SL4SU ColorView Multimedia...
How to reset xl9u mitsubishi projector's lamp
Reset of the lamp operation time
Plug in the power cord, turn on the lamp, and reset the lamp operation time by keep
pressing the left arrowand the right arrowand POWER buttons on the control panel at the same time about three seconds.
Jul 20, 2011 | Mitsubishi XL9U LCD Projector
I changed the bulb and the power lights wont come on
Certain Mitsubishi projectors have a built in bulb life timer, and are programmed to not allow a projector to power on unless the bulb is replaced and the bulb life timer is reset. Its a simple process:
1) Make sure your projector is plugged in.
2) Make sure the main power switch is on.
3) Hold the left arrow, right arrow, and power button on the control panel of the projector (not remote) for 3-5 seconds.
4) Release...
This will reset the bulb life timer to 0000 and allow for normal power up barring any other unforeseen issues.
Mar 07, 2011 | Mitsubishi HC3000U Multimedia Projector
I just replaced the lamp bulb in my projector but when i turn it on it still says lamp approaching shutdown. How do i reset lamp??
You need to reset the lamp timer as follows:
Plug in the power cord and reset the lamp operation time by
holding down the LEFT/RIGHT ARROW KEYS, and the POWER buttons on the control
panel at the same time.
Feb 22, 2011 | Mitsubishi HC1500 DLP Projector
How do i reset lamp
Power on the projector. Press the left and right arrow keys and the power key on your remote to reset the lamp timer. The three keys must be pressed simultaneously to reset the timer.
Read more: Mitsubishi SL2U Bulb Replacement Instructions ' eHow.com http://www.ehow.com/how_7313866_mitsubishi-sl2u-bulb-replacement-instructions.html#ixzz1dQh2wmwh
Dec 19, 2010 | Mitsubishi SL2U Multimedia Projector
Mitsubishi SL2u projector: Projector was recently dropped and now within 10 seconds from turning it on the Lamp - Temp indicators turn RED and the system shuts down. I suspect a thermal switch of some...
Nov 16, 2010 | Mitsubishi Office Equipment & Supplies
TURN PROJECTOR ON. FAN TURNS ON NO LAMP, RED SATUS LIGHT COMES ON
Bulb timer has expired. Press the left arrow, right arrow and power switch simultaneously for a few seconds. The projector should power up, but this indicates that a new bulb is required and should be fitted as soon as possible, as there is a risk of the old bulb exploding.
Sep 15, 2009 | Office Equipment & Supplies
We recently replaced the bulb in my projector, but it continued to flash "replace bulb". Today, it was running fine then suddenly shut down. The power light is on, but the projector is not on.
IF you did not reset the lamp counter, the unit will shutdown. To reset, press the left and right arrows along with the power button for at least 3 seconds. That will reset the timer. Update this if that does not resolve the problem.
Dan
Dec 17, 2008 | Mitsubishi ES100U Multimedia Projector
Blinking bulb light
Hi there
You must always reset the lamp timer when replacing a bulb.
Dec 11, 2007 | Dream Vision CINEXONE Multimedia Projector
Mitsubishi SL2U Multimedia Projector Logo
139 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
