Question about Jensen Btm15 Add On Bluetooth Module
Jensen bluetooth no mic output
Bluetooth jensen vm9213
Call the bluetooth fairy (Allready) Guy,
Nov 23, 2012 | Audiovox Jensen Vm9213 Dvd Video Bypass...
How do I get GPS & bluetooth stufff to go with this system ?
You need the Jenson BTM15 (bluetooth module) and the Jensen NAV105 (gps) in order to have navigation and bluetooth connectivity thru this head unit.
http://www.mobile.jensen.com/accessories/?sku=NAV102
http://mobile.jensen.com/bluetoothcarkits/?sku=BTM15
These units sell for around $50 (btm15) and $200 (nav102) on amazon.com
Jan 28, 2011 | Jensen Vm9214 Car Video Player
Activate mikrophone on ps3
•Your headset should appear as the audio input/output device. If not, just use the D-pad to highlight the Input line, then scroll until you see yours. Any microphone you have used with your PS3 will be listed, but only the current one will be available to select.
•Set the "Microphone Level" to 4. You can change the level any time if needed.
•Speak into the headset, and the level bar at the top of the screen should move at the sound of your voice.
You can also view a list of Bluetooth accessories you have registered in the "Manage Bluetooth Devices" tab under "Settings".
If your mic doesn't appear there then try pairing it again.
There are more ways to configure the audio input and output that can be useful:
•Set the input to (your mic) and leave the output on (default)- one person can chat with the other players, and the replys will play over your TV speakers rather than into your mic. Great when sharing one console because everyone can hear the team talk.
•Set the input and output to (default)- you will hear the game sound and voice chat through your TV speakers but won't be able to talk back. Great if you don't have a headset, or if you want the room to hear the team chat.
•Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works. I will add info on that as it comes in.
In Game XMB:
•All of the functions in Audio Device Settings are available when using the XMB via the PS button during a game. You can set the input/output, mic level, and device. You can test your mic, and pair a new BT headset while in game.
For more help you can try these links:
•Video Walkthrough (thanks jonny k)- http://www.youtube.com/watch?v=8tSItLGLsX8
•Playstation 3 Users Guide- http://manuals.playstation.net/document/en/ps3/current/index.html
•Step by step picture giude (Thanks kman79)
3. Troubleshooting
General:
If you are having trouble with a headset after it is paired with the PS3, there are a few things to check first:
•Make sure your headset battery is charged and working. Be aware that some brands/models will need to be paired again after each recharge. It's not a problem, it's just the way those models work.
•Make sure your controller is charged. Lots of strange things happen when the controllers don't have enough power, like dropouts and headset interference.
•The headset should be set as the input/output device from the XMB.
•For Bluetooth users, make sure there are no other Bluetooth devices in use near your PS3. Also try to eliminate any other radio frequency interference if possible.
•For USB users, make sure the connection is secure and there are no wire breaks.
•Update your console to the current available firmware
Jun 12, 2010 | Sony Playstation 3 (PS3) Console
How can i attach a bluetooth to ps3 plz help
Hello my friend this should help you out.
please remember to leave a positive rating for me and a testimonial if I helped you out!
1. CompatibilityThe PS3 supports only one headset at a time. Multiple players on the same console will have to share.
Bluetooth:
  • The PS3 uses Bluetooth version 2.0, and is compatible with all earlier versions (1.0, 1.1, 1.2). 2009 may see version 2.1 Bluetooth headsets hit the market, so you will have to try it for yourself on PS3.
  • All brands of Bluetooth headset should work with the PS3.
USB:
USB (wired) Headsets can also be used with the PS3.
  • Any of the PS2 compatible USB headsets should work with PS3 games.
  • USB headsets are required for PS2 software used on the PS3.
Not Compatible with Bluetooth Stereo Headphones:
  • The Bluetooth audio signal for PS3 only carries voice chat. The game sounds and music are played through your TV or stereo receiver only.
  • If you want to listen to the gameplay with headphones then they will have to be compatible with your TV or stereo receiver.
2. Setup
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
If you're using a USB (wired) headset, just plug it into one of the ports on the front of the PS3 (the system should auto-detect the USB headset).
Mic Test and Volume Setting
After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.
  • Your headset should appear as the audio input/output device. If not, just use the D-pad to highlight the Input line, then scroll until you see yours. Any microphone you have used with your PS3 will be listed, but only the current one will be available to select.
  • Set the "Microphone Level" to 3. You can change the level any time if needed.
  • Speak into the headset, and the level bar at the top of the screen should move at the sound of your voice.
  • Set the input to (your mic) and leave the output on (default)- one person can chat with the other players, and the replys will play over your TV speakers rather than into your mic. Great when sharing one console because everyone can hear the team talk.
  • Set the input and output to (default)- you will hear the game sound and voice chat through your TV speakers but won't be able to talk back. Great if you don't have a headset, or if you want the room to hear the team chat.
  • Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works.
and here's a video in case you are a visual learner.
Mar 26, 2010 | Sony Video Game Consoles & Games
Trying to hook my bluetooth headset to my playstation three what do i need to do
Bluetooth Headset Setup
In Game XMB:
Feb 06, 2010 | Samsung WEP460 Bluetooth Headset
How does the blue tooth work?
CLICK HERE for your user manual.
This unit does not have any bluetooth capabilities.
SEE HERE and HERE
Technical Specification
Thanks for using FixYa - A FixYa rating is appreciated!!
Feb 08, 2009 | Jensen VM9510 Car DVD Player
Am having problems with setting up my bluetooth headset for ps3
the problem of it is compatibility here's the step1. CompatibilityThe PS3 supports only one headset at a time. Multiple players on the same console will have to share.
Bluetooth:
  • The PS3 uses Bluetooth version 2.0, and is compatible with all earlier versions.
  • All makes and brands of Bluetooth headset should work with the PS3.
USB:
2. Setup
  • Set the "Microphone Level" to 4. You can change the level any time if needed.
  • Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works. I will add info on that as it comes in.
In Game XMB:
  • All of the functions in Audio Device Settings are available when using the XMB via the PS button during a game. You can set the input/output, mic level, and device. You can test your mic, and pair a new BT headset while in game.
3. Troubleshooting
General:
  • Make sure your headset battery is charged and working. Be aware that some brands/models will need to be paired again after each recharge. It's not a problem, it's just the way those models work.
  • Make sure your controller is charged. Lots of strange things happen when the controllers don't have enough power, like dropouts and headset interference.
  • The headset should be set as the input/output device from the XMB.
  • For Bluetooth users, make sure there are no other Bluetooth devices in use near your PS3. Also try to eliminate any other radio frequency interference if possible.
  • For USB users, make sure the connection is secure and there are no wire breaks.
  • Update your console to the current available firmware.
Nov 13, 2008 | Video Game Consoles & Games
Jabra bluetooth adapter A210
hi,
you have to connect the jabra audio jack to the audio source, to the speaker output of your receiver for example. If jabra detects the source it will work. If you cut the connection, jabra watch for a while if something happend and than stops the transmittion. Hope that helps
Oct 26, 2008 | LG Jabra A210 Bluetooth Adapter for...
One works but the other doesnt
in most samsung phones there is an option setting right key by the screen that will route the call through the phone or the other divice i think you may have to switch it in a call first though
May 08, 2008 | Jensen WBT210 Consumer Microphone
Using Motorola Blue Tooth with PS3
Yes you can. Just go to accessories or audio device settings. Have your headset on and hit connect bluetooth device. The key it asks for should be 0000. If that doesn't work do a quick search online and you should be able to find one that works.
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
Jensen Btm15 Add On Bluetooth Module Logo
16 people viewed this question
Top Jensen Radio Communications Experts
Mike Charette
Tom Chichester
Markku Vuorensivu
Markku Vuorensivu
Level 1 Expert
Are you a Jensen Radio Communication Expert? Answer questions, earn points and help others
