Question about Watches
What size screwdriver is required to remove the screws on the braclet of a ladies accutron courchevel 26R28?
  • 2,334 Answers
All screw heads in watch bracelets are usually 0.8mm - 1.30mm in diameter. In my experience screwdriver with the blade width of 1.00mm was good for unscrewing the bracelet screws in majority of cases. So, I would advise to buy a screwdriver with 1.00mm wide blade.
In case if you realize that the bracelet screws are a tiny bit smaller than your brand new screwdrivers blade - do not panic but use the sandpaper or any sharpening stone. Just a few strokes from both blade sides will reduce the width of the blade to the required size and you will be able unscrew the screws with ease.
In case if you brake the tip of the blade, use the same method as described above, just in this case reshape the blade. As the size of the blade is quite small, it is easy to do and takes very little time.
And,yes, the blade can be reshaped plenty of times, not just once or twice. In fact it can be reshaped and sharpened till you run out of metal.
Do not forget to rate, please.
Posted on Mar 12, 2009
How can I remove the back to replace the battery?
If there are tiny little screws attaching the back, you need the smallest metric Phillips head screwdriver in the set you purchase at a dollar store. Be sure to save the screws carefully as you will need to reinstall them.
Nov 08, 2015 | Invicta Special Edition Lupah Ladies...
Can:t remove back from Fossil watch BS9839, TO REPLACE BATTERY
you need watchmakers screwdrivers you can get them and other tools aswell off ebay ,,,,click on the link below,,,,,,,
http://www.ebay.co.uk/sch/i.html?_trksid=p5197.m570.l1313&_nkw=watch+makers+screwdrivers&_sacat=0
Aug 01, 2012 | Watches
How can I remove link pins to adjust metal band from Raymond Weil ladies Tango 527462? One side of the pin has a slot head but a very small screw driver fails to turn the head. The other side has a flat...
Raymond Weil watch braclet has a screw. Twist it, and then push from the other side. You may need to buy a set of basic tool for about 10 dollars from Amazon. Good luck and enjoy your watch. Alan Anderson
Nov 09, 2010 | Raymond Weil 5360-STP-00328 Wrist Watch
How do I tell what model Accutron I own? I obtained it as a graduation present in 1972. The serial number is H233723.
The only people who are likely to be able to answer your question is accutron (assuming that they keep records that far back- which they might).
Go to http://www.bulova.com/brands/accutron/accutron.aspx?brand=accutron and scroll down to the bottom of the screen and click on "contact us"
Oct 31, 2010 | Accutron Extra Value 26R05 Watch
Hello i'm trying to get the back off to put a new battrey in i have ian daniels with a braclet type band ladies
Check out directions here:<br /> <a href="http://www.watch-batteries.com/Changing_a_battery.htm">http://www.watch-batteries.com/Changing_a_battery.htm</a><br /> Best regards.<br /> Jewel
Aug 30, 2010 | Watches
How do I remove the back of my Bulova Accutron 98E09 watch to replace the battery?
mcdevito75 here, You will need a screwdriver to use in the slot for the battery cover or a coin, once you have the tool for the slot turn the cover just a bit and lift it off to get to the battery.
Jul 31, 2010 | Caravell Bulova Caravelle watch
Does my 2010 invicta corduba have pins or screws in the braclet? how do I remove them? They look like screws but juts spin around both way when i turn them.
Sometimes the split ends of pins look like screws. If the slot is extremely thin its a pin A screw slot will be a bit wider. I pin removal toll inserted into the smaller end should do the trick.
Apr 30, 2010 | Invicta Corduba Skeleton Techno Strap...
How do i size the braclet on a 11L00 watch
Search here in my TIPS how to do that. All bracelets are covered.
Feb 05, 2010 | Wittnauer 11L00
I bought a webner swiss military standard issue watch with a braclet deployment band. My wrist is tiny....how do I adjust the size?
Take the watch to a watch shop and ask them to shorten it for you. (doing it yourself can be difficult as special tools i.e very thin probes, may be required.
Jan 20, 2010 | Watches
I have fitted a new battery to ladies Bulova Accutron watch . Should the watch just start going again or is there another process required . The watch has not gone for a number of years . My mother...
I think it required cleaning for movement any expert watch maker will do it ,,, and if you are in chicago we can clean it.
From
Amfix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph : 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Aug 27, 2009 | Bulova 95U08 Wrist Watch
Watches Logo
117 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
