Question about Apple iPod nano
I have a lot of music on tape cassettes
How can I download music cassettes to my Ipod without buying an expensive converter?
  • Anonymous Mar 26, 2014
    use ti lisen to cassett tapes on waikman can i put on i pod
  • 4 Answers
You will need three things.
1. Cassette player with a mini headphone jack
2. cable with male mini jack at each end. (usually can find at a dollar store.)
3. Audacity (Open Source audio program)
Hook up the cable to your cassette and to the line in on your sound card. Turn volume on cassette player to 3/4 or so.
Download and install Audacity. Press play on the cassette player, press the record button in Audacity. When done press stop, and under the File menu you can Export to an MP3. You can read the Audacity help menu for more options on copying and pasting to create a new file for each track, and for fading in and fading out to get a smoother start and finish to each track.
Posted on Mar 13, 2009
I need instructions on how to transfer cassette from a boombox without headphone jack to PC.
The problem is that there is no sound output you can use if it has no headphone jack. If the aux jack was an out, then you could use that. It is possible to make a jack socket, by breaking into the speaker connections. But you would need a soldering iron and a headphone jack socket to do that. You would also have to build the jack into the unit. As I don't know if you can do that, I would suggest finding a cassette player secondhand that does have headphone jack on it. There must be plenty around since cassettes are not that popular now. If it's a commercial music tape, it would probably be cheaper to buy the digital version of it. But if it is a personal recording, then the cheap cassette player is your best option.
Nov 24, 2017 | The Audio Players & Recorders
Tip
How can I connect an iPod to work through a car stereo?
<p>An iPod can store hundreds of songs makes it an ideal source for music on your car. Buy an adapter is the easiest and cheapest way to connect your iPod to your car stereo system. Do you know which adapter fits you best and know how to use the first steps to expand their musical possibilities. <br /> <p><br /> <p>Tape deck <br /> <p>1. Buy an iPod adapter cassette player, if your car has a cassette player. This is one of the easiest and cheapest way to get your iPod to play music from a car radio. A cassette adapter is shaped like a tape with a wire connected to an end. <br /> <p><br /> <p>2. For a cassette adapter or a store of electronic music in good standing. This adapter is relatively easy to find and can usually be purchased for less than $ 20. <br /> <p><br /> <p>3. Slide the cassette tape in the car. Take the end of the cable and connect the headset to your iPod. Select a song to your iPod and press the "Play". Be sure to order the car stereo's cassette player. <br /> <p><br /> <p>FM Transmitter <br /> <p>1. Purchase an FM transmission adapter if your car has a cassette player. This type of adapter connects to both your iPod headphone jack or car cigarette lighter and stream music via FM radio signal. <br /> <p><br /> <p>2. In an FM adapter to send any electronics store. This adapter is a little more expensive than a cassette adapter. Make sure you have an FM transmitter instead, for many FM stations broadcast from a transmitter can only be transmitted to a unit to buy. This gives you more options when you're in certain areas where FM stations are vague or nonexistent. <br /> <p><br /> <p>3. Connect the FM transmitter for the iPod to a lighter (depending on model purchased). Turn on your car's FM radio and find a channel that is unoccupied. Adjust the transmitter to the channel number exactly the same and then to match the iPod. For example, 99.1 FM if you find a free channel in your area, the FM transmitter on 99.1 reading. Connect the iPod and press "Play." <br /> <p><br /> <p>Extra- <br /> <p>1. Purchase an additional cable if your car has an auxiliary input panel. This type of iPod adapter is one of the easiest ways for your iPod to play music in the car. <br /> <p><br /> <p>2. Find a reputable shop and buy an electronic overhead. This type of iPod adapter is usually sold for about $ 10. <br /> <p><br /> <p>3. Connect the cable to the extra auxiliary input on the dashboard of your car and plug it into the iPod headphone jack. Make sure the sound of the car is in standby mode. Select a number and press the "Play" button on the iPod to the music to start. <br />
on Aug 09, 2011 | Apple iPod touch
HOW DO I GET SOFTWARE FOR JENSEN JSCR50 CASSETTE USB
Either by purchasing a new unit from Amazon.com as linked below or by .zip file download from the attached links. Jensen Cassette Tape to MP3 Converter Free Download Streaming Internet...
May 18, 2014 | Jensen Pyle Cassette Tape Archiver And...
Converting cassetts to CDs.
If the laptop has an audio in socket then all you need is one of these: Amazon stock them. 3.5 plug to two RCA plugs.
Mar 25, 2014 | Sony Dual-Deck Cassette Player/Recorder...
Instruction Manual for model 2034
there is no manual,
Tape-2-MP3 Converter/Player
Convert your cassette tapes to Audio CD or MP3 files with 3 simple steps! Connect portable cassette player/converter to PC or Mac via USB cable. Transfer by Installing provided software and simply press "RECORD" while playing the tape. Create MP3 files from transferred audio to burn to CD or import to iTunes for use on your iPod device.
USB-to-Computer Recording
Convert from cassette to digital formats directly to your PC or Mac computer via USB cable and simple Audicity® software, both included.
Feb 17, 2014 | Encore Technology Portable Cassette...
Download music on mp3 player
You need some hardware to convert tapes to MP3 files.
Check out this WEB site for equipment.
http://cassette-to-mp3-review.toptenreviews.com/
Jan 30, 2013 | Coby MP-610 MP3 Player
I have a JVC KD-95 Cassette Deck. My left speaker Comes and goes lots of crackling. When I turn off the deck it crackles loudly then fades. my speakers work fine when using cd, radio etc.
Probably it's the playing head; must be damaged or worned out.. Accept fact; cassette players are outdated. make a listing of your favorite music and stat finding them on line.
By the way, even youtube rips are better quallity then thos cassette recors.
Aug 23, 2011 | JVC TD-W118 Single Cassette Deck
How to record a cassette tape to a cd
Your question is posted under a "CD Shelf System" heading. If you really have one of these, the answer is "you can't". The CD player is a player only, not a recorder.
On the other hand, if what you're asking is how to transfer cassette tapes to CD using a computer, there are a couple of ways. One is to connect a cassette player (boom box, component system cassette deck, etc.) to the line-in jack of your computer's sound card. Download and install Audacity, which is free software for recording and editing sound. Then you can record the sound from your cassettes as you play them into the computer.
Another option, If you want to be fancy and spend a little money, is to buy a USB cassette deck. It automatically converts the cassette audio to digital and sends it to your computer over a USB cable. Recording software is supplied (sometimes the Audacity program mentioned before). Several companies make them. Here's one from a company called ION that some friends of mine have, and it seems to work well for them. They've been converting a lot of tapes of family members, and Audacity has been good for cleaning up tape hiss and enhancing the sound.
Either way, once you have the sound in your computer and processed to your liking, you just need to burn it to a CD using whatever burning software you have. (I use CDBurnerXP. It's free, easy to use, and does everything needed for normal CD and DVD burning.)
Aug 10, 2011 | Crosley 4-in-1 Entertainer CD Shelf System
Converting cassette tapes to CD's
we can convernt cassette to CD in the PC with good sound card I am using creative sould blaster or audio gy it is not expensive hardly in indian currence of Rs.18oo/- you can purchase from any computer shop. or go to creative site and see models.
Sep 04, 2008 | Audio Players & Recorders
MP3 Cassette Adapter Not Working
hi.....can you check if the rola ( that has teath and roling the tape ) in ur cassette adapter is actually turinig easy because whith the new cassettes if it is hard they swich the sides thinking that the tape finished if they hard try to losen them......hopfully that wil work
Jun 27, 2008 | Alpine TDM-7561 Cassette Player
Apple iPod nano Logo
119 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
