Question about Frigidaire FRA052XT7 Air Conditioner
Removing cover to replace power cord
Trying to remove plastic cover to replace power cord but cannot get cover loose. There are two philip head screws on the side I removed, but something else is holding it. I don't want to force it (break it) so can anyone can steer me in the right direction???
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
voodoomox
  • 1689 Answers
SOURCE: Door handle has come loose
re-attaching the door handles will require you to dettach the front door cover from the actual front door (as shown on the "parts manual") some of the units circuit may run through the door so be careful in removing the front door cover.
once it is removed, the handle mount will be exposed, place the screws if need and use compatible bushings to make sure the screw will be locked in place.
refer to the link below to get the Parts Manual and the Wiring diagram of your firdge.
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FFU14K2CW&User=&Search=Search
good luck, i sure hope you get this one working in no time.
-voodoomox
Posted on Jul 28, 2008
  • 40 Answers
SOURCE: loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Posted on Feb 23, 2009
  • 306 Answers
SOURCE: Lightbulb replacement refrigerator
Most shields push in then down to engage them so push in and lift straight up. They are tight so will take a little pressure to remove. They have 2 or 3 tabs.
Posted on May 02, 2009
Sea Breeze
  • 4654 Answers
SOURCE: I have an FRS26R4AW6 side by side. I am trying to
Click Here=> FRS26R4AW6 then go to page 15 This is what the user manual that goes with your model. The page is too larger to upload here and the manual will prove helpful for you. If you need Adobe click here=> adobe.com and download the latest version of Adobe 9 free addition. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on Mar 18, 2010
The electric cord on my hand held percussion HoMedic Masager is loose. How can I open it and fix it?
What is the model of your HoMedic Massager?
If it has a rubber grip on the handle, you can take it off by simply sliding it towards the power cord, with effort and a little patience.
Once the rubber grips are off, you will find 1 screw hidden under the grip, 1 screw near the power cord, and 5 screws on the head, take all the screws off.
Once you've unscrewed all of the screws, unscrew the 2 vibrating heads then take the unit apart.
Good luck.
Jul 22, 2014 | Homedics Health & Beauty
Diismentling of PHILIPS az-1880
Remove the ten screws at the bottom. There are three hidden screws at the back just above ,one is left of antenna , another is at the middle back just half inch from top and the last is at the other end. These screws are covered with round plastic so this plastic cover needs to be remove first by either drill or small flat screw then you can remove the remaining three screws to open the the unit.
Oct 18, 2012 | Philips Az1880/12 Cd/Mp3/Usb radio Philips
How do i open the case to add ram e.t.c.... zx6961 series
You were right by removing the support bar, that's the first step. Now all you have to do is use a small flat head screw driver and pry open the case on the edge between the black and silver plastic. Don't get to aggressive, take your time going all the way around, it should just pop off. Have fun.
Jul 25, 2011 | Gateway ZX493131e Notebook
POWER BUTTON STUCK IN MOGEL # GFDN240ELWW
I took off the front panel by removing the philips head screw behind the control knob. The front control panel will lift straight up. Remove the 6 philips head screws which secure the control board to the inside panel. When you lift up this module you will see the power button. It is made from cheap plastic including the hinge. Only way to repair is to either super gluie the hinge or replace the entire control panel. I think this is an extremely poor design, especially coming from G.E.
Jul 24, 2011 | GE GFDN240ELWW Dryer
How to remove battery from norelco t 800 can not get to come apart after removing 1 screw on grip
Disassembling the Norelco T800 is quite easy -- once you know what to do!
* Remove the single small Philips screw that you can see near the power connector
* Twist (hard) the cutter depth ring past 9 and it will come loose.
* Now remove both the ring and the guide piece that it moves up and down
* Now pry off the cutter head (black piece of plastic)
* Now remove the metal clip that you find under the head -- press down on the two free ends and pry the other end of the clip loose.
* Now release two plastic tabs that we under the rotating ring.
* Now I just pried the two parts apart by inserting a small screwdriver and twisting. I'm not sure if there are any more tabs that can be released at this point.
* Now you can remove the circuit board (which is held in my a couple of plastic tabs).
Now you can replace the *single* NICD 600maH battery (AA size). The longest bit of this step was heating up the soldering iron!
Reassembly is the reverse.
Philip
Nov 08, 2010 | Norelco T 800 Beard Trimmer
How to raise bars on 05 road king classic
Remove headlamp trim ring with one philips head screw on the bottom. Remove headlamp by removing the several philips head screws around the outside. Remove the top trim by removing the 5/16 nut on the top inside the nachelle. Remove the riser cover by removing the three philips head screw, two are under the fork lock cover with can be removed by popping it off with a small screw driver. Once the cover is off you can now losen the riser caps with a 1/4" allen and position at desired hieght. Retighten and reassemble the rest in reverse order being very careful and double checking your work. Good luck!
Sep 03, 2010 | Harley Davidson FLHRC Road King Classic...
I am trying to open the outer casing of the vacuum
There is a push in type flat plastic switch trim cover over the metal housing surrounding the switch.. You must unplug the cord, gently pry around the trim cover and you will find a screw, an irregular one underneath holding the switch in place. DO NOT OVERTIGHTEN when reinstalling this one or you will crack the switch.
Once removed the rear housing will come off. Then you will see several new philips round head screws holding the front housing onto the vac.With all screws removed the housing should open easily but there may be dirty film inside holding the halves together. The fan shaft will unscrew revealing the fan, a spacer behind and perhaps two different spacer washers. Install the new fan hand tight, washers and spacers in same order...
Good effort figuring this one out. Please post back with results.
Oct 29, 2009 | Vacuums
Replacing pull cord on weedeater
there is another t20 screw in the neck of the drum. once removed you will expose the drive clutch. soak it good with WD40 then unscrew it from the shaft. if you have all the housing screws out, you should be able to simply remove the housing to expose the pull cord assembly, screwed to housing.
Aug 06, 2009 | Ryobi Garden
Power cord on flat iron broke
This is a very common problem. Only way to fix it is to replace the cord, which is not all that easy. You'll need TWO regular philips screwdrivers (size #2) plus a couple of little ***** philips screwdrivers. And a soldering iron, solder, and heatshrink.
Start by popping off the two plastic covers on the hinge area. Sometimes they break: they're not really necessary anyway. Use the two screwdrivers on the screws on each side of the hinge: one will eventually come loose. Take the screw out, then use a screwdriver to push out the hinge pin. Keep track of any washers that might fall out. Carefully remove the big spring, and lay the two halves of the iron out flat. On the control side, there are several screws that hold the covers on: remove those carefully. If the cord is the kind with the swivel thing, you'll have to take out all of those parts. There will be two wires going from the cord into the circuit board: sometimes they are attached with tiny screws, sometimes they are soldered. You have to solder a new cord onto those wires.
You can buy replacement cords at most hardware stores, or steal a power cord off another (broken) appliance. Two-wire cord is preferred: flat irons don't use a ground wire.
Cut the power wires in the flat iron: they are usually blue and brown. Brown goes to the black wire on your replacement cord, blue goes to white. Strip the wires carefully, slip the heatshrink on, solder, then slip the heatshrink over the repair and heat it to seal it up.
Now the hard part is trying to secure the new cord, since it doesn't fit the way the old one did. I usually put a big zip-tie on the cord, which is then captured when you put the covers back on.
Once the cord is repaired, you can re-install the covers. Don't tighten the screws too much, they are really easy to strip out. Carefully insert the legs of the spring into each half of the iron, then hold them together while you slip the hinge pin back in: it's a little tricky. Then use the two screwdrivers again, this time to tighten the screws. If the plastic covers aren't broken you can snap them back in if you want.
See? I told you it's not that simple. But since a new iron is, what, $100, it's worth a try.
Good Luck!
chris
Jul 24, 2009 | Oster 76076-010 Hair Trimmer
Removing the stand on Insignia LCD 26F TV
My insignia 26 inch dvd combo TV stand can be removed by removing the access cover to your input connection. There are eleven black phillip-head screws. The three bottom screws also hold the plastic base cover in place. Remove all eleven screws and pull the stand out from below. The four philip-head screws on the back center of the TV is for the location of the wall bracket mount. Good luck.
Jan 26, 2009 | Insignia LCDTV26 26 in. Television
Frigidaire FRA052XT7 Air Conditioner Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
