Motherboard failure Dear sirs, In mid October I had had assembled a PC using the following parts: Motherboard: MSI K9N2 SLI Platinum. CPU:9950 AMD Phenom x4 Processor 2.6 Ghz Graphic Cards: Two Nvidia GTX 280 Geeforce in SLI configuration. RAM: 4x Kingston KHX6400D2/2G. Power supply: Thermaltake Cablemanagment 1500W. During the first month, the 1st motherboard was burned. It was replaced by the local dealer using the warranty. Two weeks later the 2nd motherboard burned too! A week before the 3rd motherboard was burned!!! All three motherboards were burned during the use of Microsoft's Flight Simulator X through Vista Ultimate operation system. Somebody could tell ''do not use FSX again'', but that is the reason that set up that machine! It is like someone is pulling the power cord. There is also a smell of burning plastic for some seconds. Can you make an estimation of what is possibly destroying the motherboards? Thank you in advance. George from Patras (Greece).
  • 1 more comment
  • gtsimis Mar 12, 2009
    Dear sirs,
    Dear sirs,
    I hope it will work when I'll get the new replacement motherboard.
    Thank you!
  • 527 Answers
Sir,
It all depend upon with settings. It run only on high with AA enabled, running at 1024x768 and I get around 10-40FPS.  high (aircraft ultra) settings DX10 with AA and get anywere from about 25 FPS to 80FPS. Check with settings and bios for fan speed....
Go through these links
link 1
Link 2
Link 3
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on Mar 12, 2009
  • 350 Answers
Dear gtsimis , Thursday 03-12-2009 2:37PM EST USA
Large industrial and military computers are super-cooled for just this reason.
The game you want to play is awesome and hot! It runs fast and it runs hard! It uses more electricity (heat) the faster it goes so.....
Listen to the other FixaYa Experts and COOL THAT BABY DOWN!
Motherboard failure - f758ae6.jpg jackiaria
    President:
  • 948 Answers
I don't see a problem with the components you have listed. Tell us about your computer case. This configuration needs a lot of cooling, tell us about your processor cooling, video card cooling, and case cooling.
  • 19,396 Answers
RE: "During the first month, the 1st motherboard was burned. It was replaced by the local dealer using the warranty. Two weeks later the 2nd motherboard burned too! A week before the 3rd motherboard was burned!!!"
The only parts that can cause this problem are fans and the power adapter.
Fans are rather unlikely, as the motherboard will shutdown before blowing when overheating is detected.
If your motherboard is blowing the on board video chipset , then add an additional fan on the video chipset.
If the motherboard is blowing on any other point, then replace the Power Supply Unit, that is the only part that can cause the MB blowing in this way. In rare circumstances I know that a faulty CPU can blow the motherboard, but I have never seen anything like that in 20 years repairing, while I have seen a lot of bad PSU blowing the motherboard.
That should have been done immediately after the first motherboard blew.
  • 564 Answers
This is the Problem with your power supply.
Please check your power supply and it should be compatable for this motherboard.
Thanks!!! PREM
    Sergeant:
    Novelist:
  • 277 Answers
Get your whole machine checked at any local repair center as what is getting short and where the circuit is getting short .the fault will be easily located as when checked with a multimeter as what is getting short in the circuit.
    Brigadier General:
  • 3,614 Answers
make sure that a proper / correct wiring on the mobo was installed. esp on the auxilliary USB port
  • 4 more comments
  • micromaster
    micromaster Mar 12, 2009
    you must also provide or install an additional blower / fan to give a air supply and exhaust the heat outside
  • micromaster
    on what part or specific area that the mobo has been burned? is all of the 3 mobo has all the same affected part
  • micromaster
    are using a USB joystick?
  • micromaster
    the FSX has nothing to do for the accidental burn / malfunctioning of the mobo. this is all hardware issue compatibility of the parts
  • micromaster
    can you please attach photo here, as we can see how your CPU has been set up.
  • micromaster
    good to know..
    Novelist:
  • 113 Answers
What type of case are you using? itss is so very important when you have a system like that to vent it very well. the system runs more efficiently the cooler it is, and when it gets hot, has to work harder, therefore producing even more heat that can eventually burn your board. thats why you smell it for a few days before it stops working.
i suggest adding some additional exhaust fans and posibly aliguid cooled system.
but for now you can always do the gamer thing, take off the side panel and point a fan at the motherboard. that should hold you over till you get the chance to make the necessary adjustment.
    Top Expert:
  • Computers & ... Master
  • 79,851 Answers
U are causing to much heat to build up during the use of the flight sim, either stop using the sim or install the biggest case fan you can fit in, also make sure the processor has the very best cooling u can buy, remember heat is the worst enemy of all electronics, the more air flow the better, fans are cheap.
  • yadayada
    yadayada Mar 12, 2009
    up grade the cooling of the case and circuits and your problem will go away, flight sim's use a tremendous amount of computing power, that means lots of heat, do as I suggest u won't be sorry.
    Sergeant:
  • 320 Answers
Its the power supply problem that is getting overheated and burning all the mother boards.replace the power supply as well as power cord.
  • 412 Answers
How old is the main board?
ask for warranty if you have.....
  • remoteserver Mar 12, 2009
    you can use master cooler cabinet to control overheating.
    Genius:
  • 1,550 Answers
More likely you have a bad IDE cable or hard drive causing a short and murdering the IDE port
  • SAM ANDERSON Mar 12, 2009
    It is definitely issue of cable or hard drive fault in your system due to which *********** board is getting burned .
I want complete motherboard driver
First verify that the board model is MSI K8N Neo4 Platinum/SLI. The following drivers may not work for any other board model.
There are two ways to download the drivers. First try the MSI live update utility. It will search for and automatically download the required drivers.
You can get the Live Utility from this page.
If somehow the utility does not work, go here and download the drivers manually one by one.
Please note that MSI does not provide all drivers for every OS and the board may not be compatible with newer systems.
Dec 04, 2010 | MSI K8N Neo4 Platinum/SLI Motherboard
It does not work. The motherboard has "died". I would like to purchase a different MB to replace it. What recommendations do you have? I have/had an MSI K9N2 SLI Platinum Socket AM2 ATX Motherboard
I recommend this board here, it is completely compatible with what you have now. It is a bit smaller than your board physically, but will definitely fit in the same case you currently have and will work with your components. Before you go to the link please make sure you click YES below my answer here to indicate it was helpful to you, it would mean a great deal to me if you could do so. Thank you so much, here is the link:
http://www.amazon.com/gp/product/B003CBXV6O?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B003CBXV6O
Oct 11, 2010 | MSI K9N2 SLI Platinum nVidia nForce 750a...
What cpu should i use
The Motherboard uses the AMD socket 939 so you should probably check out the AMD Athlon 64
Jun 17, 2010 | MSI K8N Neo4 Platinum PCI-E (NON SLI)...
Replace motherboard
There is no need to get an exact replacement motherboard, most likely it is out of production if it is more than 6 months old.
The desktop case has and motherboards have standard configuration mounting holes. I sugest you work out what your computing requirements are and go to your friendly computer shop and purchase a motherboard.
Most of the existing components will be compatible but the RAM and CPU may not, you need to check this out.
Sep 10, 2009 | MSI K8N SLI Platinum Motherboard
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Firmware motherboard: MSI K9N Platinum (MS-7250)
You'll find it here. 31 down on the list.
http://eu.msi.com/index.php?func=prodcpu2&prod_no=251&maincat_no=1#menu
Jul 03, 2009 | Computers & Internet
MSI K9N4 SLI-F / Vid Card question
Hi, for the best graphics always go for dual graphic cards. This is the best way to obtain realistic 3D effects. The onboard audio chips is every bit as good as stated, MSI systems are equal to the best but at a lower price. The only change I can see that you need to make is to install a better power supply. A minimum 500w is needed with your system and if your budget allows then anthing up to 600w. Have fun with your games. Regards mistyman
Sep 21, 2007 | Intel Motherboard
Computers & Internet Logo
174 people viewed this question
David Payne
David Payne
