Question about Kenmore Refrigerators
Is there a vacuum that holds the door closed?
I have a model 106.55609400. Is there a vacuum that holds the door closed? My door will not close tight. What would be failing if I no longer get a good seal?
aborcass
  • 2651 Answers
SOURCE: oven door won't close tight
order and replace door springs part # 32052801 youll need 2
Posted on Feb 26, 2008
SOURCE: battery compartment
same problem , no solution, i e-mailed like 10 times to buy ine cover lid, i think they re out of business
Posted on Mar 16, 2008
SOURCE: My Amana oven door will not shut tightly.
twist a tesher like a roll and put it betwing the door and the frame of stove then close the door gently to bring back the hinges to position.
Posted on Dec 07, 2008
  • 38 Answers
SOURCE: oven door won't close tight - light stays on
Replace door hinges.
Posted on Mar 08, 2009
SOURCE: kitchen aid open door sensor alarm keeps going off door is closed
Open door and turn power off then on twice. Then press the Overtemp reset.
Posted on Aug 08, 2009
Frigidaire mfu17f3gw6 upright freezer won't get below 20.
that indicates that the door seal is too hard and not sealing properly
have it replaced and the problems will possibly be solved
what is happening is that on closing the door
the cold are creates a vacuum that holds the door closed for a few seconds until the temp evens out, the same as for freezers
when that vacuum is not being created , it means that the cold air is still allowed to leak out past faulty door seals
Jun 15, 2018 | Frigidaire Refrigerators
My microwave no longer starts when the door is closed. You have to hold the door tight for it to work. Door is not shutting tightly enough.
On the DMT2420, that's a bad bottom door switch, or possibly that switch's mount.
The service manual is here and the parts list is here. You can order Dacor parts by part number from the Pros here.
Feb 11, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
Remotes don't work, keyless entry won't work, wall remote some
Check to make sure the door sensors are pointed at one another and the small light on each one is lit and not flickering. If you cannot get both lights to come on then your sensors have failed.
Jul 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sub zero freezer door no longer vacuum seals when the door closes. There is nothing obstructing the door.
Make certain that the freezer fan motor is operable. Otherwise, contact an appliance service company.
Feb 20, 2010 | Freezers
Freezer door stays ajar after closing the refrigerator door.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 16, 2009 | GE GTS22KBP Top Freezer Refrigerator
Top freezer door does not close tight
Sounds like the top hinge is loose. If the hinge has a cover, remove it then hold the door in the correct position and tighen the hinge screws.
Aug 31, 2009 | GE GTS22KBP Top Freezer Refrigerator
Trunk release for 2000 mercedes s 430 not working properly
Trunk can be lock separate from the doors valet try unlocking the trunk with the key lock it with the door.Read the owner manual it will tell you about valet parking.
May 17, 2009 | 2000 Mercedes-Benz S-Class
HBW 0777 Liftmaster Garage Door Opener
steve it sounds like the two eyes are not lined up to communicate with one another and complete the circuit so the door will work. This is a safety feature. Begin by seeing if adjusting the eyes will line them up and tuen on both green lights. Also be sure the wire to each light is still connected.
Apr 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Nov 17, 2008 | Maytag MER5755QAS CleanDesign Electric...
Refrigerators Logo
118 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
