Question about Acer Aspire 5100-5033 Notebook
Startup i downloaded an upgrade file and now windows cant repair itself during startup
I am doing the system restore now, I believe this should work. Thanks
Posted on Nov 05, 2008
    Novelist:
  • 135 Answers
If you rerun the windows setup and run the install function rather than the repair, making sure it's in the regular "windows" folder ("WinNT" if you're using windows 2000), then the setup should retain your personal settings, programs, desktop, etc. Such as this quote is referring to in this paragraph: "There are two primary installation scenarios: clean installation or upgrade installation. A clean installation is performed onto a new/formatted empty hard drive or to overwrite an existing OS. An upgrade installation retains existing settings and applications."
Posted on Aug 04, 2007
    Brigadier General:
  • 6,966 Answers
Hi, You may want to try starting windows, press F8 and select Start Windows in Last Known Good Configuration (or something like that) or Safemode and then do a System Restore. Hope this be of some use to you, Pls post again how things trun up and/or if you need further information. Goodluck and kind regards.
0F00:075D
Sounds like a faulty hdd.
Try "startup repair" which preserves your existing user files:
How to automatically repair Windows Vista using Startup Repair
If you don't have the Vista DVD from which to boot to perform the repair, download just the repair disc from here: Windows Vista Recovery Disc Download — The NeoSmart Files
Feb 20, 2014 | Dell Precision M4500 Notebook
Dell Inspiron 1440 notebook failed to start windows
You probably have a mbr virus. Try this:
Download The following iso listed below. It is the latest version of the Kaspersky rescue disk. You need to burn it to a CD with a program like Imgburn (Which is also FREE like the iso file). Then you need to boot from the CD and run the scanner. It should fix you right up.
Kaspersky rescue cd download:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
Imgburn download:
http://majorgeeks.com/downloadget.php?id=4870&file=15&evp=0636b68877cb69b15faa3374cb1dcd89
Aug 17, 2012 | Dell Inspiron 1440 Notebook
Continuously rooboot itself?
Hi.
When the laptop keeps rebooting shortly after Windows starts loading the reason is usually because the system files loaded by Windows at startup are corrupted.
Windows cannot complete booting and keeps restarting.
The fastest way to Fix the problem is by reinstalling Windows.
If Windows is installed on the same directory of the existing system performing an upgrade installation, the setup process will preserve all personal files, most installed software and settings.
Before reinstalling Windows you can try starting in safe mode (eg. on XP pressing f8 on startup). If the computer starts in safe mode, go to system restore and perform a restore to a date before the problem occurred. Unfortunately when the computer keeps re-booting ut will hardly start in safe mode. Often reinstalling Windows is the only option available.
Aug 02, 2010 | Acer Computers & Internet
Where can I find info to setup bios. also how do I upgrade bios
For this you need to know the exact model of your motherboard. Your current BIOS firmware version can be seen in the BIOS setup window itself ( Press DEL key during your system startup to enter into BIOS screen)
Your motherboard should have Flash BIOS so as to upgrade its firmware. All latest motherboards will have this type only. Goto your motherboard manufacturer website and search for latest BIOS firmware for your exact model. There itself you can find the utility required for BIOS. download that utility and using which you can update your firmware. Please do update your BIOS only if it is required.
I hopt his is helpful to you
Dec 31, 2009 | Computers & Internet
When switching on goes straight to startup repair cant get windows and it says no problem found
Get out your install discs and re-install the operating system and re-download the updates.  You got a corrupt startup file somewhere.
Nov 06, 2009 | Acer Aspire 6530-5143 Notebook PC
My laptop is slow at opening windows, takes about 5mins, i tried defragmenting it but wont work, also the search etting installations keep appearing when i trun on my laptop, any suggestion please??
i guess ur using a licensed and 'updated' antivirus..
howevr, hv aglance ovr the software strength..look for startup items (the programsloaded during startup)..download n install n run 'Statup ControlPanel'..
http://www.pcworld.com/downloads/file/fid,7976-order,4-c,desktop/description.html
andmicrosoft kb890830..remove the unnecessary boot item(s) or do post me acomplete list of startup item that the Startup CPL is showing (in itzevery tab), i'll guide u..
also u may use 'Advanced System Care Pro' to fix all at a time..
always better to get supervision frm ur system admin/vendor....
Oct 29, 2009 | Compaq Presario M2000 Notebook
I cant install plstek opticpro ut16 scanner in my pc
Try this steps before you install
1. Start -> Click Run
2. Enter msconfig and click ok
3. Click Startup tab
4. Uncheck program that you don't want to startup
You can disable programs that you don't want automatically load when you start your computer. By disabling these programs will help your computer startup faster.
5. Click Ok and restart
Now you should notice that your computer startup faster.
My Hot Tips to Make Your Computer Faster:
* Regularly check your startup folder to prevent malicious programs installed itself without your knowledge.
* Delete the temporary files from Temp folder (Start > Run > %temp% > delete all files).
* Upgrade your RAM to makes your computer boot faster : )
I hope this article can helps you to make your computer faster..
Aug 13, 2009 | Plustek UT16 USB Scanner
Unmountable_boot_volume computer stop its operation
your hard drive is having problem, plz try by formating the hard drive
May 19, 2009 | Computers & Internet
Startup repair failed. cant get to startup screen
did you back-up your important files?, if you did, then you need to reformat your hard disk drive (hdd) and reinstall new system.  but if you didn't backup your important files, ask for help at the service center near you, cause it need another hdd to backup some files.  then if you have nothing to lose on your hdd then go ahead to reformatting. sometimes that error occur when it didn't undergo proper shutdown
Dec 14, 2008 | Dell Dimension E521 PC Desktop
Acer Aspire 5100-5033 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
