Question about iWorld Cassette Adapter for iPod and MP3
Cassette adapter constant buzzing when put into the cassette dock
Bose troubleshooting
Sounds like it's either a problem with the connector on the iPod or on the dock. To find our which see if it works okay on another dock - if you know anybody with one our text it on a demo model in a store. Or it could also be the plastic dock adapter - take our the adapter and try docking without the adapter.
Jun 20, 2014 | Bose SoundDock digital music system...
Defective cassette adapter for iphone 4s. stuck in side of the cassette deck
take the deck apart, get the tape and put it back together or see if you can find someone who fixes decks and ask them to take the tape out
Jun 16, 2012 | Dynex Mp3 Stereo Cassette Adapter Dx-ca103
Says "protected" and buzzes when new tape is put
Hello make sure that your cassette don't have a broken tab on bottom of tape if tabs are Ok send your unit to adjust the procttioon record Switch you can send your unit,Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Oct 27, 2010 | Dictaphone 2750 Desktop Cassette...
I have a Latitude D630 laptop and I recently purchased a docking station to use with it. I tried my laptop's PA12 Power adapter When I initially connected everything and placed the laptop on the dock an...
Try updating to BIOS to version A16 from http://support.dell.com Ensure you are not attached to the docking station when flashing the BIOS. Once updated, connect the 90W adapter to the docking station, connect your laptop to the dock, and power on using the docking station power button.
Nov 13, 2009 | Dell Docking Station for Latitude D600
Loud buzzing when I insert a tape in my car's stereo
Hiya, first try a normal cassette, see if that plays OK. If so the deck is probably fine, if not then the deck is faulty (probably not serious though and just a loose wire on the head).
If the connection between the tape and MP3 is a cable, the fault is quite likely there (if bluetooth then not). I strongly suspect the cable from the previous issues also.
Best of luck
Jul 15, 2009 | RCA RS2640 CD Shelf System
Stiletto 2 ''buzzes'' when car is running
You have an impedance issue. Typically this happens when you are using the fm transmitter and the interferrence is being introduced from your cars' electrical system. You can fix it cheaply by using a cassette adapter or direct auxiliary connection.
Jun 15, 2009 | Sirius Stiletto 2 Satellite Radio Receiver
Old Dock New iPod (won't always charge)
http://www.griffintechnology.com/products/firewire-to-usb-converter
Just bought it, haven't tried it - seems to be a very cheap and easy solution!!!!
Jul 12, 2008 | Bose SoundDock digital music system...
iWorld Cassette Adapter for iPod and MP3 Logo
219 people viewed this question
Top iWorld Car Audio & Video Experts
xxxxxx xxx
Are you an iWorld Car Audio and Video Expert? Answer questions, earn points and help others
