Jvc tv not powering on
My jvc tv won't power on
    Problem Solver:
  • 9 Answers
Power board
Posted on Apr 24, 2013
tvtek
  • 1284 Answers
SOURCE: JVC AV-20F476
Intermittant issues are always the hardest to troubleshoot. It could be a loose connection or a component that breaks down under load or thermally.
Posted on Feb 15, 2007
  • 556 Answers
SOURCE: Lightning spike-dead sets
if it is relay problem you can make it direct just to check.check power supply output. as you say that eht ok than it due to stand by section of system control mcrpssr.
Posted on Sep 13, 2007
SOURCE: JVC AV-35750 TV
I changed capacitor C926 (1000Uf 16V) on main board. It solved the problem. I went with 1000uF 63V as it was readily available...it's okay to go with higher voltage. It was hard to fit it on because of the larger size but it worked.
Posted on Dec 07, 2008
Benimur
  • 6966 Answers
SOURCE: JVC 36" TV will not power on and has a blinking power light...
Hi and welcome to FixYa,
Almost always, when an electronic device/equipment fails when powered with and by a generator, it is the power supply unit (PSU). The PSU circuitry expects a fairly constant/stable power source (120 or 220). The output of the generator tends to fluctuate especially under varying electrical load. Additionally, the AC frequency (60Hz) of the generator's output also tend to vary which most PSUs don't like. A noteworthy point to consider is that the generator is floating electrically, its output has no reference to earth/ground.
If you are considering a DIY (do-it-yourself), foremost to inspect would be the PSU particularly the regulator transistor and determine if it outputs +5 and ~+135 VDC. Another to check would be the HOT (horizontal output transistor). If when the TV was used powered by a generator, there was considerable vertical rolling, the vertical deflection IC would also be a suspect.
A friendly reminder, exercise caution when repairing TVs. It stores up EHV (extremely high voltage). It would be to your advantage to reference a service manual (JVC AV-36D303) or at the very least a schematic diagram with voltage readings.
Good luck and Thank you for using FixYa.
Posted on Jan 05, 2009
ginko
  • 19396 Answers
SOURCE: JVC 36
Hi Dave: "My JVC 36" TV will not power on and has a blinking power light."
That means that the protection circuit has started because a fault had been detected.
If this happened after a power surge it is likely a faulty PSU board.
Try first leaving the set unplugged from power outlet for few hours, this will drain power, reset the protector, and fix problem related to accumulation of electrostatic charges on PSU power capacitors.
If unplugging does not work, that means that there is an internal fault.
If this happened after a power problem of some kind, that means that probably one of the capacitors on powr board had blown, and must be replaced.
The TV must be tested by a technician to find the fault.
JVC LT-22EM72 Solid red power indicator but tv won't turn on
Customer service told me to leave the unit unplugged for 24 hours.
Feb 22, 2013 | JVC Lt22em72 22-in Led 60hz 1080p Hdtv
My JVC flat screen won't turn on, tried unplugging and resetting. Stand-by light is still on. And it's attached to a surge protector than to the wall. I've only had this for 1 year.
More than likely its bad capacitors on the Power supply very common problem with most models. You can get repair kits or replacement power boards from www.tvrepairworld.com
Dec 09, 2012 | JVC LT-42X579 42 in. LCD TV
I have a jvc lt-32a220 flat screen and won't power
Power supply or microprocessor in the set---have you tried to unplug set and or box if used from power for a while and then power back?
Do I understand it is a new set?
Dec 09, 2012 | Televison & Video
Jvc tv won't turn on
Check its main power regulator section for damaged component/s
Nov 30, 2012 | JVC AV-35750 35" TV
My jvc dvd player xv-thc50 won't turn on
if your dvd player has no any power indicator at the front, the first place to be checked will be the power supply. look for a blown fuse bad component parts like shorted diode and an open resistance.
Oct 15, 2012 | JVC Televison & Video
Jvc lcd picutre won't show
as you said jvc lcd tv won"t show. if lcd tv have good power supply & main board. that will be inverter board gone in. replace it will be solve you problem. good luck!
Sep 03, 2012 | JVC LT-42X579 42 in. LCD TV
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
I need the USB firmware update utility for a JVC LT-32P679 TV.
my tv won't show a picture the blue light on the bottom left hand corner just keeps blinking
Apr 05, 2011 | JVC Televison & Video
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
