My pc wont reconize any memory card Bigger than 2 GB
When I put my 8 GB card into the same spot I put my 2 GB card my pc will not even reconize it is even in. The drive will completely disappear. H: drive
  • 1 more comment
  • redbikelilly Mar 13, 2009
    I couldn't tell ya how many watts I am getting.
  • Shadow1989 May 11, 2010
    Some readers have limitations.  Let me know your computer manufacturer if the reader cam with it, or the manufacturer and model of the reader and the memory that you are using.
  • Thomas F. Schneider May 11, 2010
    Flash drives? What does the book say that came with the computer?
    Was it made to run a flash driver bigger that 2gb? Was their even a larger that 2gb flash drive available when your computer was manufactored?
  • 3 Answers
Hi, you need to check your power supply to see how many watts it is. If you have a low wattage PSU then your 8GB card may need more watts to run. If you have a ow wattage PSU get a new one with more watts. Hope that helps.
Posted on Mar 13, 2009
SD Card Full
When you install a larger SD card it will be a fresh empty memory card. Your existing 8Gb SD card will still have the the 5 hour gig data on it.
You can insert the 8Gb SD memory card into an USB memory card reader and plug this into the USB port on your computer. The computer will see this SD memory card and adapter as an external storage device. You can then open the audio folder on theis SD memory card and copy this file to your computer.
Mar 25, 2013 | Tascam DP-008 8-Track Pocketstudio
I want to buy a new rig , main purpose is to use for 3D Animation and Rendering(After Effects,Photoshop, Premiere,Maya, Nuke, Fusion Etc.)I have set a config in my mind Intel Based PC, But I need...
The processor is too weak - get at least an i5, best would be a quad core i7; the hard drive will be filled faster than you thing - bigger is always better; get some faster memories - at least 1666 MHz, 4 GB is bare minimum, get a 64bit OS and 8 GB for real performance; the power source is at the limit - for best result get one of 600W; as for the video card the best for photoshop is Nvidia Quadro CX, even ATI Fire will be better than any gaming card.
Jun 13, 2010 | Intel D865GBF Motherboard
My Mac doesn't reconize my 8 GB SanDisk microSDHC memory card
Go into Finder-preferences and select under devices: external disks
Nov 25, 2009 | Electronics - Others
My computer wont reconize my 4 gb microSD for my lg enV 2. ive put it into the adapter and into my laptop but it doesnt show up. it is unlocked
it may be if ur usb cable not good or ur card reader, if u use cardreader for reading ur data. if it plz change ur cable or card reader. and any way when u connect ur mobile with pc then show some configre 2 ur mobile. then select from that usb settings.
Jul 27, 2009 | Cell Phones
When i insert my 8 GB micro SD card it says the same thing.
Your 8GB card is considered "high capacity". You will need an SDHC USB card reader to read it.
Jun 24, 2009 | SanDisk 8GB microSDHC Memory Card with...
Dosen't reconize 8 GB SDHC memory card
Older model printers won't recognize high-density memory cards.
2 gb is probably the largest to be used in your printer.
Dec 26, 2008 | Epson Stylus RX500 All-In-One InkJet...
Trouble with expanded memory
The Sansa Express was only designed to hold up to a 2 GB Micro SD card because that is as much expandable memory it was meant to read. Anything bigger as in your case will cause the player to go slower than normal as it tries to read the card and after a while, it will most likely freeze. If you try it with a 2 GB Micro SD card, it should work.
Dec 10, 2008 | SanDisk Sansa MP3 Player
Memory card
i believe they are only capable of 2 gig, get a brand new 2 gig for around $7 online, and the device should recognize it, i have the brand name kingston, my problem now is, i cant sync music, if u figure that out, let me know
Oct 20, 2008 | LG Vu CU920 Cellular Phone
PUT NEW XD PICTURE CARD TYPE M 2GB CARD NOT INITIALIZED
A lot of times you can't just put in a new memory card especially one that is bigger then the one you were using. Make sure that your camera is capable of using a 2 GB memory card. If it's an older camera then I would say that the 2 GB is to large for your camera to handle. Try and replace it with the one you were using to see if your camera is ok. If it does work then your card is to big. You can check the manufactor web site or google it.
Apr 24, 2008 | Cameras
Computers & Internet Logo
David Payne
David Payne
