Question about KitchenAid Food Mixers
Housing unit When food is added to the bowl it stops working. If bowl is empty it works.
    Novelist:
    Scholar:
  • KitchenAid Expert
  • 134 Answers
That is usually caused by a stripped gear. It is hard to give you a good idea of what to check without a model number.
If it is a 4.5-5 quart regular mixer then it will most likely be a bad worm gear:http://www.mendingshed.com/kawormgear.html This would be a fairly easy repair. You will also want to check the other gears to make sure they are not damaged.
However if it is a 5 or 6 quart Professional mixer it will be more involved than that. You will want to take the mixer apart, inspect each gear (you will need to clean off the grease). Any gears that are worn damaged or nicked will need to be replaced. Also check the bearings, and the retainer pin. If these are bent or damaged they may need to be replaced. While you are in the mixer check to see if the transmission housing is cracked, if it is replace it with the new metal housing. If all of the above are in good shape check your planetary assembly, it is pressed together and could become loose causing the same issue.
Please let me know if you have any questions.
Posted on Apr 23, 2013
Why wont my food processor work?
[PDF]Food Processor - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/dlc-xp.pdf
CuisinartDough blade, metal chopping blade, 3 slicing discs, shredding disc, detachable stem... food processing technology plus the largest work bowl on the consumer ...
[PDF]Download Manual - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
Cuisinartwork bowl, cover and pusher ... The work bowl won't come off until the ..... DOUGH.BLADE. 12. The Pro Classic1" Food Processor can mix and knead dough in a.
[PDF]INSTRUCTION BOOKLET - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/fp-12dc.pdf Cuisinart12-Cup Cuisinart Elite Collection® 2.0 Food Processor FP-12N Series. For your ...RECOMMENDED MAXIMUM WORK BOWL CAPACITIES ... dough blade, adjustable slicing disc, reversible ...... immediately after use so food won't dry on them ...
[PDF]Premier Series 7-Cup Food Processor DLC-2007N - Cui
Jan 01, 2016 | Cuisinart Dough Blade Plastic for DLC-2014...
Beater on Kitchen Aid stand mixer doesn't touch bottom of bowl
Why would you raise the beater if you want it to reach the bottom of the bowl? You need to lower the beater. Turn the screw in until it just touches with empty bowl on high speed then turn it counter clockwise a 1/4 turn so it will just clear.
Mar 16, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Mixmaster mx001
Refer this issue directly to Mixmaster.
Mar 04, 2014 | Food Mixers
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
Food processor assembly
I'm going to take a guess that you can't get it to work....tell me if I'm wrong. The biggest mistake people make when assembling their food processors is putting the bowl on backward. It will not run if the bowl is on backward. The handle on the bowl should face the front of the base. Once you click that into place, put the blade on, then lid and lastly the pusher. For safety reasons, all of that has to be in place for it to work.
Jul 18, 2012 | Cuisinart DFP-3 Handy Prep 3-Cup Food...
Kitchenaid mixer leaking oil
Get a copy of the Repair Part List for your model at Kitchenaid.com
Grease inside the Planetary Assembly (the shaft is tight fit to the Planetary
plate at the factory and is not designed to be taken apart, so do not use
any hard object such as a screwdriver to separate them) over times can
turn to liquid and leak down the bowl. Removing the Planetary assembly
and adding Kitchenaid Food Grade Grease is not a task for a novice.
To properly remove the Planetary Assembly, you must work from inside
the Transmission Housing: Remove in this order: Retaining Clip(25), Bevel Gear(21),
Retaining Pin(18), Worm Follower Gear(19). Use a soft mallet to tap out the Shaft
of the Planetary Assembly(15). Re-assemble it in the reverse order.
Note: The Bevel Gear is extremely tightly fit on the shaft, and a pin punch
must be used to remove from the shaft.
Jul 14, 2011 | KitchenAid KP2671 Professional 6 Series...
D300 Floor Mixer faulty bowl guard switch
If you remove the bowl guard you will see a magnet that attaches on iy in a white housing.The scews come loose and prevent it from closing the switch.Also the switch which comes out of the top pedestal can be adjusted.Let me know.
Mar 29, 2009 | Hobart D300 Stand Mixer
Food Mixers Logo
18 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
