H50188 I brought this dsl mode/router and I ran the sftware that came with it and it says that it is ready, but cannot hook up to the internet and the internet light does not come on and call embarq and talk with the tech. support and they could not help me. how do I get hooked up so I can use the internet
    New Friend:
    Problem Solver:
  • 5 Answers
Please reset up your router and then set it up again..
Thanks.
Posted on Jan 13, 2018
  • 173 Answers
SOURCE: belkin wireless G router will not allow connection to internet
check for the physical cables, check if they are connected properly, if yes, try to reset the router and reconfig it
Posted on Jan 09, 2008
Bubbabear64
  • 2794 Answers
SOURCE: linksys router
unplug your DSL modem. Wait 30 seconds and plug it back in.
Make sure the router is connected to a DSL modem. Lately I have seen DSL modems connected to offices that are really routers. If thats the case it may not be talking because the DSL is address the gateway with the same address as the router.
The best way to test this is to see what happens when you disconnect your linksys router and type in http://192.168.0.1
in internet explorer.
If the DSL modem screen appears, it's configured as a router.
Then you will have to take the linksys router and turn it into a switch with a wireless access point. I
Posted on Jul 14, 2008
SOURCE: 2WIRE 2701 router
You must log on to the browser interface of the router (usually for 2wire they use 192.168.1.254) run the set up wizard it will come to a screen which asks for a key code, this key code is provided by your ISP, you can try one of these and see if it works
if you have a PPPOE connection (you have a user name and password to log on to the internet with use this one.
5225-26Q4-2262-22AS-B28F
if it is not PPPOE use this
5225-26P4-6262-22AS-B2E7
to manually configure the router use this
5225-2374-WG62-22AS-BJ7P
If these do not work call your internet provider and ask them for the key code.
after that you should be all set.
Posted on Aug 06, 2008
rwandrew
  • 115 Answers
SOURCE: linksys wireless router problems
Power down all the units. Power up the DSL first. After it is up, power up the router. After that is up, Power up the laptops one at a time. Let me know if this helps or not, there are other things to try after this...
Posted on Oct 11, 2008
  • 825 Answers
SOURCE: every time i hook up the wireless router to the
the problem you are facing is due to the double nat issue(the embarq modem provides the ip address in the range of belkin router, that is 192.168.2.1)...hardwire the pc to the lan port of router.
login to the router setup page(type 192.168.2.1 in IE)
in router setup page, click on lan settings and change your lan ip to 192.168.5.1....the problem ll get resolved...if still the status is not connected, switch off the router and modem and switch on it after a minute....it ll get fixed
Posted on Mar 29, 2010
Ipad dosent see it
Do you have any other wireless computer or device in the network?
Can you connect to the wireless network on any other wireless computer or device?
Try changing wireless channel on the router.
Make sure that SSID broadcast is enabled.
How to connect to the wireless network on iPad
Apr 22, 2012 | Hiro (H50188) Wireless Router
II gave my router to my mother it has already been set up for an encryption I gave them the passkey and it is not working could this be due to the fact she has dsl internet and I had cable
>No, it really doesn't matter what type of service you have.
>To get it fixed just make sure that if your mom uses a modem and you hooked the router to it, modem must be in BRIDGED mode before you can make the router work.
>To set the modem to bridged mode you need to contact your mom's DSL provider so they can walk through it
In the diagram below, if this is your setup, modem has to be on Bridged Mode:
Phone jack --- modem --- Linksys Router --- computer
Oct 18, 2010 | Linksys Wireless-G WRT54G Router
I have a dlink dir628 router and can not get internet access but can find the access point i got throught the config. but can not get internet through the router wired or wireless but hooked up my old...
if you have one dsl modem & one router means you have to cofig dsl modem in bridge mode and router in dynamic mode.if you have any dout call me 9740575949
Feb 25, 2010 | Computers & Internet
Bright house modem and desktop computer, trying to hook up wireless net gear router for 2nd desktop to get internet? How do I configure the cables?
Connect the lan cable from the dsl modem into the first port on your netgear router ..
make sure your dsl modem is on PPPoE mode so that it autoconnects..
Now just connect to your wireless router via your pc interface..
*Do add a network key to your wireless network to avoid unwanted access
Jan 19, 2009 | NetGear WGR614 Wireless Router
My DSL was installed. I am trying to hook up my linksys wireless router, when I do the internet does not work. What am I doing wrong?
modem type ? make sure it is on modem-only mode if it is a home-gateway type.
connect modem ethernet to router internet port (located next to the power port).
press & hold for 10 secs. the routers reset switch (until all lights blink).
launch the internet connection wizard & select "computer is connected to a gateway / internet connection is always ON"
Jan 14, 2009 | Linksys Wireless-G Broadband Router
How to hook up the Ethernet 5port Workgroup Hub Model No. ew5HUB
To start with please make sure it says router on it as the title says "Networking Hub". These are two different devices. If not return the Hub and purchase a Linksys Router then follow instructions below.
Assuming you have a router:
Before you begin unplug the power from the Cable or DSL Modem before you start as they will have to be powered on in a particular order I will discuss later.
Your cable or DSL modem will have a cable coming out of it that looks similar to a phone line except a little larger. The cable will say CAT5 or CAT6 or Ethernet on it.
On your Linksys Router there will be a ports/jack that you can plug the Cable into from your Cable/DSL Modem. You want to look for one labled "WAN" or "Internet". Plug it in then plug in the power to your Cable or DSL Modem. When the "Ready" light is on the modem, plug in the power cable to your router.
The next step is hooking it up to your computer. There will be anywhere from 1 to 8 more ports available on your Router that is number 1,2,3,4, etc. Plug another Ethernet Cable into any one of those ports. With the other end plug it into your PC or Laptop, there is only one port/jack on your computer that this plug will fit in. Power up your PC and voila, you should be on the Internet.
Please let me know if this solves your problem.
Thanks,
Adam
Nov 28, 2008 | Linksys Instant Networking Hub
Connecting xbox live to my d link 1005d
Is the PC's connected to the D-Link able to browse the Internet? Sometimes the MAC Address will bind to certain IP's and must be cleared out when the Router is replaced. Please unplug the power to the router, X-Box and Cable or DSL modem. 1st plug in the power to the DSL/Cable modem until the "Ready" light comes on. 2nd plug in the power to the D-Link Router, wait 30 seconds then plug in the X-Box, power on and test. If a computer plugged into the D-Link will browse Internet then this is the solution to your problem.
Adam
Oct 26, 2008 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
Just connected to cable modem from dsl
two things are you hooked up from the dsl to the router via Ethernet or usb is so check the settings in the router, it should be auto, so it could choose but lets not assume anything.may sure dhcp client or server is enabled on the router, if not it would not pick up the ip adddress from dsl.
Is the mac address of your computer hardcoded to your dsl, if it is then you would have to clone your pc mac to the router for it to work.
If this is not the case, try a different router if it works the router is faulty. if that does not work plug the dsl directly to the pc and go to start, run type ipconfig /all if you recieve an ip address and you can see a dns address from your isp and you can go to the internet, then the problem is your router, if not the problem is with you isp dsl, please contact them. was this helpful let me know.
Jun 03, 2008 | Computers & Internet
Can't get Trendnet TEW-432 router to connect to internet with motorola modem
I had this same problem. I was going to go ahead and call ATT and ask them to put my modem into bridge mode, but I messed around a bit more....
I went ahead and turn on PPPoE...tried to run the set up again. Well it worked. Not the internet connection is working through the modem. For some reason, the setup changed PPPoE back to DHCP Client, but it's working now. Give this a shot before calling ATT if you like. Good luck.
May 13, 2008 | Trendware TEW-432BRP Wireless Router...
Computers & Internet Logo
101 people viewed this question
Alun Cox
David Payne
David Payne
