Question about XRS-9430 12-Band Radar/Laser Detector
Need to know the size of the replacement fuse for the lighter plug.
    Problem Solver:
  • 13 Answers
Sometimes the lighter fuse run something else try 10.
Posted on Aug 11, 2013
Why does my cigarette lighter keep blowing fuses every time I plug something into it
First make sure you have the right size fuse in it look at your owners manual it should tell you what size to put in there sometimes people blow a fuse and replace it with a weaker fuse it will work for a while till they plug something in that overloads the fuse then blows and if they sell the car the new owners don't know this they just keep replacing it with same type fuse that's in it. Second make sure whatever it is you are plugging in doesn't have a short itself try plugging in something different and see if it blows then if it doesn't then you know where your problem lies.
May 26, 2014 | Cars & Trucks
Cigertte lighter
I am not exactly sure of your problem of just saying cigarette lighter, but I assume you are saying it is not working. If this is the case, most likely it is a fuse. Look in manual if you can not find right fuse or where fuse panel is. However the fuse will be marked as cig or cigar and if that is so, pull out fuse, and replace it with same amp. It will be marked. The fuse you can easily get at any auto parts store, such as shucks, or Napa, or auto zone. Cig lighters often blow because with all these devices now a days we plug in them, they get a lot more use then years ago. For example they were actually designed originally to light cigars or cigs, but now we are plugging in i phones, computers, phones, etc,,,, so they get a lot more use and sometimes we overload the fuse and blows. I tell all my customers that it is nice to have a couple back of cig fuses in the car. There real cheap they normally come in a little tiny plastic pill size clear box, and run under 5 bucks and normally at least 5 fuses in the box. I hope this helped your problem, again I was assuming by your only posting of your problem stating cigarette lighter, Please let me know if this advice helped, or if not, let me know what else i can do for you, thanks Mike
Jun 26, 2011 | 2000 Ford Focus
Where is the fuse for the cigarette lighter is a 2000 ford ranger? Neither one of the lighters work. I also need to know what size fuse it is.Thanx
This is most likely not a fuse issue if it is the fuse box under the dash of the drivers side and its unfortunately a process of elimination to find the blown one. However i believe this is more likely to be an issue with the cigarette lighter unit and / or housing. These can be bought and replaced with minimal effort. See you local automotive parts retailer.
Jun 16, 2011 | Ford Ranger Cars & Trucks
Ok i have a 01 ford windstar the cig. lighter caught on fire. replaced fuse now it and to obd doesnt work. really need obd it is running like u know what. dont know why??
When your lighter lit on fire it could have melted the casings on the wires shorting them together. This would cause the fuse to blow every time you use the lighter. Also it is the same fuse for both the lighter and obd (which in your owners manual will be called Data Link Connector, or DLC). Replace the fuse but don't use the lighter. When you plug in the DLC it should work just fine then try the lighter. If fuse blows you have to fix the wiring to the lighter or possibly the lighter socket.
Jan 26, 2011 | 2001 Ford Windstar
I want to buy a heater to plug into my lighter outlet on my 1995 Ford Escort, but I don't know the amps of the lighter.
Look at the fuse panel to see what size fuse is used for the lighter. That's your amperage for the lighter outlet.
Dec 15, 2010 | Ford Escort Cars & Trucks
Cigarette lighter gone, tried to plug in charger for my phone..but no power tp the outlet..i guess..does it need a fuse, what size and where is fise box and fuse location diagram?
You can find the fuse box, under the steering wheel. Remove the plastic cover, and look on the back for the diagram to see which fuse to replace. Usually for the cigarette lighter there's a small size 15A fuse.
Nov 19, 2010 | 2000 Daewoo Lanos
Need to work a RAdar detector: whistler 1430
Does the unit turn on when you plug it into the lighter socket? If not, does the lighter socket power other 12 volt devices? IF the lighter socket works and the radar detector doesn't there is a fuse in the plug end of the power cord. Unscrew the tip to expose the fuse. Replace it with a 2 amp fuse from any auto parts store and try it again.
Feb 27, 2010 | Whistler Vehicle Parts & Accessories
Honda Civic year 1999
It would be fuse 27 in the underdash fuse box, 10amp
Feb 10, 2009 | 1984 Honda Accord
Lighter plug
First if you still have the old "lighter plug" unscrew the ribbed end cap of the cigarette lighter adapter and check to see what size the fuse is. If you don’t have it anymore it originally took a 1amp fuse. Do Not use anything bigger then a 1amp fuse....You can pick them up at your local electronics store like RadioShack. In fact they will have a cigarette lighter adapter for you just remember to take in your Cobra ESD 6000 Radar Detector...I hope this helps...Let me know... cbinny1
Oct 20, 2008 | ESD 6000 Radar Detector
Cigarette lighter stopped working
I had the same problem on my '97. I ended up taking out the lighter when I was replacing the LCD on the radio, only to find that somehow it had become disconnected. Not sure how it happened but it might be worth checking out to see if it wiggled loose. To get to the lighter: 1) Prior up the cover by the shifter (the one that also goes back to the seat heater). It is connected with snaps so pry slowly. 2) Once the panel is removed you will see screws that are holding in the ash tray/cig lighter. Unscrew those and the whole lighter/ash tray can be pulled out. It is also held in by snaps on the top.
Aug 08, 2008 | 1998 Lexus ES 300
XRS-9430 12-Band Radar/Laser Detector Logo
73 people viewed this question
Top Cobra Vehicle Parts & Accessories Experts
John Nolan
Jason
Are you a Cobra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
